Lift kit
Discussion in '1st Gen Tundras (2000-2006)' started by 06Tundra1984, Mar 1, 2021.
  1. Mar 1, 2021 at 12:23 AM
    06Tundra1984
    06Tundra1984 [OP] New Member
    Drazen
  2. Mar 1, 2021 at 1:00 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome and do a search mode in the suspension threads and/ or 1st Gen builds.. Good luck.. Any pixs?
  3. Mar 1, 2021 at 6:26 AM
    How bout the RCD 6" lift? You're gonna need all the lift you can get to clear 35" tires. Buy once, cry once. Regardless of which lift you purchase, wheel choice for size and offset will have a huge impact on what fits and what doesn't. Tight wheel wells on the first gen Tundra. Lifting the truck doesn't make the wheel wells wider. Takes a lot of lift to get the tire moved down far enough to start clearing the upper radius of the tire, even then you have to be able to cycle the suspension without rubbing.
    Darkness and Glock 40 like this.
  4. Mar 1, 2021 at 7:20 AM
    06Tundra1984
    Drazen
    KNABORES I would love that 6” lift lol if it wasn’t almost 3gs, I looked it up and said a 4.5” should clear 35s do yoh think the tuff country one would be a good way to go
  5. Mar 1, 2021 at 7:27 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    RCD is the way to go. End of story.
    turboser91 likes this.
  6. Mar 1, 2021 at 7:28 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    I have that lift. Do yourself a favor if ya go with Tuff country. Get the 5". Comes with heavy duty spindles. I'd avoid the 4.5 just because of the spindle spacer.
    Darkness likes this.
  7. Mar 1, 2021 at 7:37 AM
    Not a fan of the construction of the Tough Country lifts, not as robust as the RCD. The ones that come with new spindles and not spindle spacers are preferred. All the spacer bits just cobbled between the factory ones look a little sketch to me. Probably fine for the look, but may not hold up to a lot of abuse.
  8. Mar 1, 2021 at 7:50 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Agree with all the above.
    Or get a saw :sawzall:
    And a welder :welder:
    Kimosabe, Wes_heppy and Hi06silver like this.
