leveling
Discussion in 'Suspension' started by Fox2018, Sep 7, 2020.
  1. Sep 7, 2020 at 9:08 AM
    Fox2018
    Fox2018 [OP] New Member
    have a 2018 sr5 off road tundra and had this for a couple months and getting to leveling it and first time doing it. do i need to buy a differential drop too??
    YardBird likes this.
  2. Sep 7, 2020 at 9:26 AM
    Welcome from NY.
    No, not if you are just leveling it.
  3. Sep 7, 2020 at 9:27 AM
    Fox2018
    thanks
  4. Sep 7, 2020 at 9:48 AM
  5. Sep 7, 2020 at 9:50 AM
    timsp8
    NY
    Yeah, 3”+ is usually when you need the diff drop. If you raise the back any, which it doesn’t sound like you are doing, look into the carrier bearing drop kit. I raised my back less than 2” and it helped with shudder.
  6. Sep 7, 2020 at 9:55 AM
    Fox2018
    alright thanks
  7. Sep 7, 2020 at 1:26 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome from Gettysburg address
  8. Sep 7, 2020 at 3:28 PM
    TheBubbaDude
    TheBubbaDude New Member
    2020 Tundra TRD Pro
    AJT Blackout Kit 1.25" Wheel Spacers NRG 285/70/18 Meso Customs TRD Start Button
    On this same thread, I'm considering removing one of the leafs from the rear spring to level it out. I have a 2020 TRD PRO and 3 shops I've talked to have told me I need a 3:2 lift to level it. I don't want to go any higher on the ride, bit I want to level it out so the rake is less substantial.
    Thoughts?
  9. Sep 7, 2020 at 3:35 PM
    Contact @Toytec Lifts they will guide you.
    TheBubbaDude[QUOTED] likes this.
  10. Sep 7, 2020 at 3:35 PM
    timsp8
    NY
    Pros are pretty level. If anything, I’d get a CB shim or 2 for the front. I’d never remove a leaf. The stock ones are soft as they are. Can’t image trying to ride or haul anything with one removed or potential for them cracking.
    jeremyd and TheBubbaDude like this.
  11. Sep 7, 2020 at 3:40 PM
    TheBubbaDude
    2020 Tundra TRD Pro
    It has a 2"OEM lift but there is still enough of a rake to tweak my OCD. Dealer told me there is something with the suspension that makes it a challenge to level. I can't recall at the moment but the shop he refers lifts to (4WP) had already told me the only thing available was a full lift.
  12. Sep 7, 2020 at 3:47 PM
    timsp8
    NY
    It isn’t hard and there are threads on here about the install. You don’t need a full lift to level it. 3/2 kits are for leveling non Pros.
    Measure your hub to fender on each wheel and that will tell you how much you need to add to level it. Some people add 1 to passenger side and 2 to drivers side to help with the lean. Each shim adds .5”.
    CB has full Pro kits too. He is a member on here and will answer any questions if you call him.
    https://shop-coachbuilder.myshopify...ilder-strut-coilover-shim-provides-50-of-lift
    https://www.tundras.com/threads/coachbuilder-from-ekstrom-design-llc.1828/
    @Coachbuilder1
  13. Sep 7, 2020 at 4:31 PM
    TheBubbaDude
    2020 Tundra TRD Pro
    Looks a little above my pay grade. I had to use the Owner's manual today to install spacers on my wheels LOL. I've reached out for some advice but I may need to keep looking around
  14. Sep 8, 2020 at 7:50 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    I haven't specifically heard of someone removing leafs to drop the rear end.
    One thing to note here, is since you have a 2020 Tundra, you are equipped with the TSS-P system, which is that big sensor in the grill there which is designed to read the road properly.
    Toyota builds the Tundras to have rake on them (Rear end higher than the front) for a couple reasons.
    1. For when you load the truck down/ tow you have a "Buffer zone" for it to squat down and sit level engage the "tow mode" properly.
    2. Having rake on the vehicle so the front sensor can read the road properly to insure all aspects of the TSS-P system are working properly. I have seen people level their 2020 Tundras out and end up having "issues" with alerts illuminating on their dash stating there is an error with the sensor.
    There are dealerships that can re-calibrate that sensor, and/ or (Can't remember the vendor) but they make a "adjustable" bracket that bolts onto factory location. (@T-Rex266 do you remember that vendor?)
    TheBubbaDude and T-Rex266 like this.
  15. Sep 8, 2020 at 7:53 AM
    AJT does the relocation brackets, I believe.
    TheBubbaDude likes this.
  16. Sep 8, 2020 at 8:13 AM
    TheBubbaDude
    2020 Tundra TRD Pro
    I'm familiar with this but it was my impression that the relocation bracket was for a grill replacement?
