Leveling my Tundra question
Discussion in 'Suspension' started by bfd300, Oct 18, 2018.
  1. Oct 18, 2018 at 7:52 AM
    bfd300
    bfd300 [OP] New Member
    I have searched the threads cant find a solid answer, all I want to do is level out the front. Which lift 2” or 3” spacer lift? Thank you
  2. Oct 18, 2018 at 7:54 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
  3. Oct 18, 2018 at 12:28 PM
    Lambeau
    Lambeau New Member
    2019 Black Tundra Platinum 4x4
    XP Package, 20” Rockstar, 295/60/R20 Nitto G2, Line-X Bedliner, Undercover Elite LX Tonneau Cover, Remote Start, NSV Hood Bulge Light Bar, Predator Running Boards, TacoTunes SQ1 Sound System, Toytec Boss front coilovers, Toytec Boss rear shocks, Coachbuilder +2 rear shackles
    Bilstein 5100s
    zcarpenter92 and 15whtrd like this.
  4. Oct 18, 2018 at 12:47 PM
    bfd300
    Yea thats my plan when the stock struts wear out or when I get new tires.
    Kinda taking the same path as I did with my tacoma
    Spacer then 5100’s down the road.
    Then exhaust, hidden winch. List goes on and on lol
  5. Oct 18, 2018 at 3:35 PM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    kill 2 birds with 1 stone and get the 5100's, get new struts and they will level out the truck. No need for spacers.
    zcarpenter92 likes this.
  6. Oct 18, 2018 at 3:43 PM
    Blueknights75
    Ron
    Clayton, NC
    6112’s at 1.9 setting.
    power80, Casper3 and snarkscarbine like this.
  7. Oct 18, 2018 at 4:09 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    :thumbsup:FYI..coil overs..no struts on our trucks.
  8. Oct 18, 2018 at 7:06 PM
    power80
    power80 New Member
    2018 Tundra Crewmax Limited 4x4
    Agreed! 6112's @ 1.9" setting. I added a pair of Coachbuilder +2 rear shackles and left the factory TRD off road rear struts alone. I occasionally tow and I did not want the truck squatting down the road. Could not be happier!
  9. Oct 18, 2018 at 7:35 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I’d say go with 5100’s, why add spacers when you can level with coilovers?
    Black Wolf likes this.
  10. Oct 19, 2018 at 10:56 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Mine is 3/1.5" via 6112 with a CB shim and top setting on each side and Toytec shackles with 5160. I stuffed a 37x12.5 tires, lol, without rubbing at full articulation and steering lock.
  11. Oct 19, 2018 at 10:59 AM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    How much cutting was involved? Now I want 37s :spending:
  12. Oct 19, 2018 at 11:06 AM
    matictundra
    Franco
    AZ
    I had my alignment guy shoved the LCA as far forward as possible (effectively higher neg caster) to gain body mount clearance without sacrificing toe and camber spec. Caster has virtually zero effect on tire wear anyways. I also did some trimmings, see the items circled in green in the pix.
  13. Oct 19, 2018 at 12:31 PM
    power80
    power80 New Member
    Bilstein 6112's up front @ 1.9" setting
    Coachbuilder rear shackles (CB +2)
    BFG K02 275/70/18
    Chucho and 32vsnake like this.
  14. Oct 19, 2018 at 12:47 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Wow 37s look good! Your truck looks very clean too!
    matictundra[QUOTED] likes this.
  15. Oct 19, 2018 at 7:02 PM
    ctraut5
    ctraut5 New Member
    Germantown,TN
    2019 Black TRD Pro
    Don't go over 2" in the front unless you are going to lift the rear as well. Good chance your truck will have reverse rake if you do. Also, I would go with the bilstein setup or something similar as opposed to spacers.
  16. Oct 19, 2018 at 9:25 PM
    mattyd170
    mattyd170 New Member
    Rio Rancho, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    Stock for now, but have TRD Rear Sway bar for it.
    If you just want to level the front and do nothing else, either do a 2" spacer on the front if you just drive around town and don't1do any real off roading or get Bilstein 5100's and use the middle setting. 6112 are nice, but expensive for just running around town. Measure ground to wheel well front and rear wheels on level ground to see the difference in inches. I am almost extactly 3" difference from to back. Gonna try to do my shocks this weekend and I will post results. I have noticed that people on here spend a lot of money, ie...6112, Kings, etc.... the majority of people can do a spacer kit, level out and be just fine.
