Leveling kits
Discussion in 'Wheels & Tires' started by Inzaine_tundra, Jan 10, 2020.
  1. Jan 10, 2020 at 10:54 AM
    Inzaine_tundra
    Inzaine_tundra [OP] New Member
    2019 Toyota Tundra TSS Off-Road
    Hey guys I’m new here and need some advice. I have a 2019 tundra with aftermarket 20” wheels and off road tires that came with the truck when I bought it. I want to put a leveling kit on there and I talked to a dealer and they suggested the Readylift 3” F/2” R lift kit. With that kit what wheels/tires would fit my truck without any modifications? Thanks guys
  2. Jan 10, 2020 at 11:25 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    Welcome. There's a lot of variable there but no one can answer your questions better than the 1st page of this thread. Tons of good info here:
    https://www.tundras.com/threads/official-tundra-wheel-and-tire-setups-pics-and-info.95/
  3. Jan 10, 2020 at 1:46 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Welcome from WI. With that 3/2 kit ReadyLift says you can fit up to a 35" tire on a 9" wide +25 offset wheel. I would be a little skeptical about the 35's and no rubbing. Depending on your budget there are definitely better ways to go at it than doing a spacer lift. Take a look at ToyTec. New coilovers in the front and shackles or aal's in the back will be the more popular suggestion from most of us on here.
    Inzaine_tundra[OP] and 15whtrd like this.
  4. Jan 10, 2020 at 2:23 PM
    Inzaine_tundra
    Thank you guys.
  5. Jan 12, 2020 at 6:59 PM
    I run that kit with 285/70/18s (34s) on a 0 offset wheel. As mentioned, look at the Toytec Boss kit. The ReadyLift is good for street use and no offroading, but the ride is stiffer. I will be switching over to coilovers at some point.
  6. Jan 12, 2020 at 7:19 PM
    Welcome from NY.
    You could always put Bilstein 5100's on the middle setting up front to level it.
  7. Jan 12, 2020 at 7:30 PM
    Rockanock
    Rockanock 21 Chevy 2500
    I’m running Bilstein 5100’s on top setting. My truck sits 100% level. 39.5 inches on all four corners. No shims and no shackles. However your mileage may very. Some guys end up having to use shims because they get a lean to one side of the cab to the other. My truck came out perfect. Didn’t have to run a diff drop because I am under 3” lift. If you go 3” or more you for sure want to do a diff drop. Good luck
  8. Jan 12, 2020 at 8:32 PM
    Inzaine_tundra
    So would I be able to run 20” wheels on that Readylift kit? I don’t much off-roading so I’m not worried about that.
  9. Jan 12, 2020 at 8:36 PM
    Inzaine_tundra
    Man I love the way your truck sits. So what size wheels/tires can I run with your setup. My truck runs a 275/55/20 and I’d like to give it a bigger size wheel (maybe 22) and a beefier tire. Would that fit with your setup?
