lets beat a dead horse
Discussion in '2nd Gen Tundras (2007-2013)' started by nwtundra2012, Sep 22, 2025.
  1. Sep 22, 2025 at 2:01 PM
    nwtundra2012
    nwtundra2012 [OP] New Member
    2012 tundra
    ive read so much on the topic of transfer case and diff oil i think ive confused myself more then not. ive got an owners manual for this truck and it says for the t case recommended oil is 75w90 1.2qt so thats just regular old 75w90 gear oil correct no additives or anything crazy? im assuming not or it would say it. and for the diff gear oil it says LT 75W-85 GL5 or equivlent. 4.9qt. i dont think i have limited slip. its got a traction control button i can turn off and to my understanding that means the diff is open and the traction control just applies brakes to which ever wheel is spinning. do i have that correct? trying to figure out if i need the additive for limited slip or not. thanks
    Leo's first likes this.
  2. Sep 22, 2025 at 2:13 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    blenton likes this.
  3. Sep 22, 2025 at 5:15 PM
    nwtundra2012
    2012 tundra
  4. Sep 22, 2025 at 5:27 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    blenton likes this.
  5. Sep 22, 2025 at 5:30 PM
    Azblue
    The Dirty T ( ^_^)_且
    FrenchToasty, blenton and Leo's first like this.
  6. Sep 22, 2025 at 7:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    As stated we don't have a true lsd. I do have an aftermarket lsd, Speedmaster, that requires a 85w-140 conventional oil. But that's not what is stock.
    blenton likes this.
  7. Sep 22, 2025 at 7:05 PM
    nwtundra2012
    2012 tundra
    Good enough for me, just ordered 2 gallons of triax 70w90. Do you guys use Toyota trans fluid or do you use an alternative?
  8. Sep 22, 2025 at 7:06 PM
    nwtundra2012
    2012 tundra
    Gotcha. I thought I had read somewhere that the 2nd gen’s could have come with the lsd.
  9. Sep 22, 2025 at 10:37 PM
    blenton
    blenton New Member
    Like these guys said ^^^… a quality synthetic 75w90 all the way around will work great. You can use 75w85 in the diffs if you would like - it is usually a little more expensive and harder to find but zero issues running 75w90.
    To clarify a few things for you - 2007+ tundras were never offered with a mechanical limited slip differential from the factory. Like @Mdl, I’ve run an aftermarket LSD for quite some time - first an Auburn gear clutch type LSD, now a worm gear type Speedmaster. The stock AutoLSD system is simply traction control that will engage the rear brakes independently to limit wheel speed and send power to the wheel with traction. Many call it malarkey and useless, but it is very functional in the right circumstances when used correctly. The differential itself is an open differential, though. I obviously felt the need for more traction in all circumstances and upgraded.
    A note about the transfer case: in 2014, the transfer case changed from an Aisin to a Borg Warner unit, and the required oil type was changed to a straight 75w. Dealerships and many owners still use 75w90 in it without issue, but be aware that anybody suggesting straight 75w is referring to 2014+ tundras; your 2012 still wants 75w90.
    Regarding transmission fluid, I much prefer Toyota or Aisin WS ATF. I wouldn’t muck about with anything other than WS unless you have a justifiable need for different transmission behavior. Aisin is the transmission manufacturer, and Toyota owns Aisin. So in my book, both this ATF’s are well suited to our vehicles. General consensus - and my preference and practice - is to perform a drain and fill rather than a flush. I’ve done so every 30k miles since new on my ‘13 and am currently close to 230k miles with lots of hard use. You can do an drain and fill with every oil change (or sooner) if you are lookijg for cleaner fluid. There is a little procedure for it that you can look up here on the site. Simple, but a few things need to be followed closely. No more difficult than an oil change, IMO.
    Mdl likes this.
  10. Sep 23, 2025 at 5:20 AM
    nwtundra2012
    2012 tundra
    thanks for the clarification. I also plan on doing a drain and fill not a flush and at the 30k intervals. The truck has 50k on it now and I doubt it’s been done so I’d like to get it on a regular service schedule and keep everything as nice as I can
