Led Pods
Discussion in '1st Gen Tundras (2000-2006)' started by Justin_G, Dec 6, 2020.
  1. Dec 6, 2020 at 9:22 PM
    Justin_G
    Justin_G [OP] New Member
    Justin
    2003 Silver Tundra Access Cab
    Any one have a link or diagram on how to wire led pods into the reverse lights? Don’t really need a switch in the cab, them coming on when in reverse is fine. Just have no idea on how to wire it. No electrical experience.
    Tundra2 likes this.
  2. Dec 7, 2020 at 12:45 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Isn't it just a bulb to replace?
  3. Dec 7, 2020 at 2:45 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome with your first post!
    Tundra2 likes this.
  4. Dec 7, 2020 at 1:24 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    Welcome feom Vegas...
    just replace your reverse lights with some LED's from Amazon. I did the ones below and they are super bright. replace the ones in the bed lights also with the same.
    https://www.amazon.com/dp/B0728DYR9H/ref=cm_sw_r_cp_apa_fabc_q0PZFb60PHH33?_encoding=UTF8&psc=1
    Tundra2 likes this.
  5. Dec 7, 2020 at 1:30 PM
    Justin_G
    Justin
    I have reverse led lights. I have a spare bumper for my truck. I want to put led pods in the bumper. I just don’t know how to wire, them so they come on when I shift into reverse.
    Tundra2 likes this.
  6. Dec 7, 2020 at 1:33 PM
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
  7. Dec 7, 2020 at 1:35 PM
    TundraPHX
    Jared
  8. Dec 7, 2020 at 3:44 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    If you have the tow package, any reason you couldn’t tap on there?
    TundraPHX likes this.
  9. Dec 7, 2020 at 5:35 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    It's only 12V--won't kill ya to poke around...or WILL it?
  10. Dec 7, 2020 at 6:14 PM
    TundraPHX
    Jared
    What do they say? It’s not the volts that kill ya but the amps?
  11. Dec 7, 2020 at 6:56 PM
    APalmTree
    APalmTree 4x4 SKEPTIC
    Brandon
    SW Washington
    1 or 2... I lost count
    I don't know if this matches the wiring on your truck but on this picture that I found, and on my brother's 04, the black and white wire is the shared negative wire. If you tap your led pod straight into the wires behind the reverse light it would be negative to the black and white, and positive to whatever the other color is. You can tap into the wiring by stripping a little bit and soldering it, but if you have no experience it would be easier to use a "T-tap" which can be found at any hardware store or even Walmart has some. You just line up the wires in the t-tap and you clamp the connector together and it makes all the connections for you and allows you to tap into an existing circuit. The reverse lights are around a 18-22 gauge wire so you can properly size a t-tap.
    Tundra2 likes this.
  12. Dec 7, 2020 at 7:36 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I chose to run mine off a switch but if you only wanted them to run off reverse lights, that’s simple.
    Just tap into the positive reverse lights and ground it.
    Tundra2 likes this.
  13. Dec 9, 2020 at 8:06 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I recommend the use of a 4 pin relay. Wire as such:
    30 - Fused power from battery
    85 - Connect to ground
    86 - Positive input from reverse lights (tap the positive wire of the reverse bulb or the reverse wire at the trailer plug)
    87 - Positive output to your led pods. Ground the pods to the chassis.
    Siebler and 831Tun like this.
  14. Dec 9, 2020 at 8:45 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm with @artsr2002 on this one. It's far better to use a relay to avoid pulling too much juice through wires that are too small.
    Siebler likes this.
