LED Headlights-High Beam On Full Time
Discussion in 'Lighting' started by Jimjim47, Sep 24, 2019.
  1. Sep 24, 2019 at 12:43 PM
    Jimjim47
    Jimjim47 [OP] New Member
    2004 Black Tundra
    Lifted
    First Post so please go easy. I installed 1 led headlight and everything works great. After installing the second headlight, the high beams are on all of the time. The blue light is not on in the cab and can not switch them to low beam. Put the old light back in and we are back to normal.
    My guess there is not enough current draw so it acts like a light is out or something. Any way to "fool" the truck into thinking there is more load on the electrical system? i really like the brightness of the led lights.
  2. Sep 24, 2019 at 1:07 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Yes, you need a resistor. Someone with more knowledge should chime in as to which one...
  3. Sep 24, 2019 at 1:26 PM
    Headlight Revolution
    Headlight Revolution New Member Vendor
    Atlanta, GA
  4. Sep 24, 2019 at 2:33 PM
    Jimjim47
    2004 Black Tundra
    Lifted
    This is what I was looking for. Is there a less expensive version and can i function with just one?
  5. Sep 24, 2019 at 2:36 PM
    Atlanta, GA
    These would be the most affordable ones I could point you towards. And you will need both of them, one per headlight. Unfortunately you cannot get away with only using one, I apologize homie!
  6. Sep 24, 2019 at 2:41 PM
    Jimjim47
    2004 Black Tundra
    Lifted
  7. Sep 17, 2021 at 2:39 PM
    Chris_thomas360
    Chris_thomas360 New Member
    Tundra crewmax
    I’m actually having this same problem with my headlights I bought from headlight revolutions
