LED head and fog light conversion HELP
Discussion in '1st Gen Tundras (2000-2006)' started by banta4x4, Jul 18, 2016.
  1. Jul 18, 2016 at 10:09 PM
    banta4x4
    banta4x4 [OP] New Member
    Josh
    2006 Tundra Double Cab TRD 4x4
    285/70R17 BFG All Terrain KO2 17 x 8.5 Stealth Custom Series Stealth 6 Bilstein 5100/5150 F/R
    Hey guys, I know little to nothing about wiring or much about headlights at all.
    2006 Tundra DC with OEM head lights and fog lights.
    I had to make the switch to LED headlights with a slim ballast as the OEM bulbs seemed too dull for me. Once I replaced the OEM bulbs, the fog lights did not work. I switched it back to the oem bulb and the one particular side fog light did work... I'm assuming the ballast on the new LED headlight has something to do with the fog light not working properly. Also, when I toggle my high beams and when I toggle my fog lights, the high beams come on.
    Has anyone else had this issue? Not sure how to fix this at all... I've been itching to get my LEDs firing on all cylinders! :help:
  2. Oct 28, 2016 at 10:26 PM
    Riptide
    Riptide New Member
    New Mexico
    2003 Tundra SR5
    None...yet
    Old thread I know...did you ever figure this out though? My truck is doing the same thing.
  3. Oct 28, 2016 at 10:39 PM
    banta4x4
    Josh
    Never found out how to resolve this... just went back to oem bulbs and went with led fogs.
  4. Oct 28, 2016 at 10:40 PM
    Riptide
    Riptide New Member
    New Mexico
    2003 Tundra SR5
    None...yet
    Thanks for the update. I appreciate it!
  5. Oct 29, 2016 at 3:45 AM
    HWU
    HWU We like white!
    N.W. Ohio
    2003 White Tundra SR5
    Not sure where but I ran across the info but it was on this site. I too will be converting the headlights to a "brighter" bulb soon. The online site is...."Xenon HIDS .com. They offer wiring kits and harnesses that "bypass" the original wiring on the truck and goes straight to the battery. I would prefer that, no splice and dice into the original wiring.
    Riptide likes this.
  6. Oct 29, 2016 at 8:17 AM
    Unit09er
    Unit09er New Member
    is there a good website to buy after market fog lights for 04 tundra?
  7. Oct 29, 2016 at 8:20 AM
    Riptide
    Riptide New Member
    New Mexico
    2003 Tundra SR5
    None...yet
    I got mine from xenonhids .com. as far as I know the site just sells HID and LED bulbs though. Not sure if that's what you're looking for.
  8. Oct 29, 2016 at 8:22 AM
    Riptide
    Riptide New Member
    New Mexico
    2003 Tundra SR5
    None...yet
    That's the exact reason I went to LED, that way I wouldn't have to splice and dice something else to the battery. I've heard of people having good results with their HID kits though.
