LED Front Turn Signal Hyperflash ONLY when parking lights/headlights on
Discussion in 'Lighting' started by Bauldin, Sep 24, 2019.
  1. Sep 24, 2019 at 2:35 AM
    Bauldin
    Bauldin [OP] New Member
    2014 Tundra Limited
    I have been converting all lights to LEDs. Prior to installing LED front turn signals, I converted all the rear lights and my headlights. When I installed the front turn signal LED bulbs it was giving me the hyperflash. I purchased and installed 50W 6Ohms resistors and with my lights set to AUTO everything operated properly. When I got off work that night the hyperflash was back. I found out that when I turn my headlights and running lights off the hyperflash goes away. But as soon as I turn on my running/parking lights the hyperflash comes back. Any ideas?
    Front Turn Signal Bulbs:
    https://www.amazon.com/gp/product/B07H6TM331/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    Resistors
    https://www.amazon.com/gp/product/B00FDX6YAE/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
  2. Sep 24, 2019 at 5:30 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If you use 6 ohm resistors, you have to install a resistor in the turn signal circuit at each corner of the vehicle. The better plan is to use 3 ohm resistors at the rear only. I'm not sure how that is changed by headlights and DRLs being on, but the bottom line is hyperflash (a diagnostic saying you have a bulb burned out) is caused by insufficient resistance in the turn signal circuit when incandescent bulbs have been replaced by LEDs.
    Bauldin[OP] likes this.
  3. Sep 25, 2019 at 2:51 AM
    Bauldin
    2014 Tundra Limited
    I replaced the rear turn signals with the original OEM bulbs and the hyperflash went away! Thanks so much for your input, its greatly appreciated! Now to purchase 3 Ohm resistors!
  4. Jul 8, 2023 at 7:50 PM
    badmotofing3r
    badmotofing3r To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    Bringing back the dead with this thread but did the 3 Ohm resistors work? I installed “hyper flash free” LEDs for my rear turn signals and I have hyper flash only when parking lights or headlights are on. Thanks.
  5. Aug 8, 2023 at 1:30 PM
    PickupMan2008
    PickupMan2008 Gladys Knight Industries Two Thousand
    Quentin
    Orange City, FL
    2008 Black Double Cab 4x4 5.7
    Cover King seat covers, weathertech rain guards and floor mats NFab Light Bar w/ KC Lights 2010 Limited Grill mod topper bedrug Amazon tailgate handle with rear backup camera still working on mods
