Leaf springs
Discussion in 'Suspension' started by Mysticwolf, Oct 20, 2017.
  1. Oct 20, 2017 at 9:17 PM
    Mysticwolf
    Mysticwolf [OP] New Member
    Craig
    2011 Red SR5
    Toytec leveling kit, Magnum front and rear bumpers, PIAA fog & running lights, 20" Cree light bar, Cree 4" backup light in rear bumper, Gear 18X9 wheels 265X65X18 Master Craft tires. SABM.
  2. Oct 20, 2017 at 9:47 PM
    TheBeast The Beach
    Deaver K37 or Icon expansion pack (cheaper but retains some of the original leafs)
  3. Oct 21, 2017 at 5:50 AM
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Deaver, Atlas or Alcan are also good options. How much weight in the back and how do you use your truck?
  4. Oct 21, 2017 at 5:54 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I run ome at the suggestion of @Coachbuilder1 With his shackles. I wanted to eliminate rear block with my 6" lift. The ride is fantastic. Call David and talk with him about ome.
  5. Oct 21, 2017 at 8:04 AM
    Mysticwolf
    Craig
    2011 Red SR5
    I don't haul to much beside a pop up camper, and half a bed full of word when we go camping. But with just with that the rear sags more then I think it should,
  6. Oct 21, 2017 at 8:08 AM
    smslavin
    Hudson Valley
    Some stuff
    Deaver's k37s may not be stiff enough. I run their U748 springs which are 600lb springs. I've got a topper, drawer system and rear bumper.
    The OMEs with shackles could be a good bet for you.
  7. Oct 21, 2017 at 8:34 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    How much coin you want to drop?
    Icon is coming out with their RXT setup for the Tundra. Very versatile for those with added bed loads.
    Sunnier and dcsleeper408 like this.
  8. Oct 21, 2017 at 8:43 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    I run the ome’s. With stock shackles And really like them
  9. Oct 21, 2017 at 9:43 AM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Does your suspension hit the bump stops or bottom out while towing? Tundras sag pretty good but it’s normal unless your maxing out the tounge weight. Shackles or AAL can help the sagging.
    dcsleeper408 likes this.
  10. Oct 21, 2017 at 11:06 AM
    Mysticwolf
    Craig
    2011 Red SR5
    I have a Toytec leveling kit with shackles, need a little help with the load, my springs are getting weak, I don't have much arch left in them, that's why I am thinking of replacing them.
    831Tun likes this.
  11. Oct 21, 2017 at 1:33 PM
    Theyfzman
    Pa
    08 TRD
    I tow a 6x12 enclosed trailer total weight loaded it about 3700lb
    When I hook up the ass drops maybe 2 inches
    With those ome springs it put the rear up about 3 inches w the stock shackles just for a point of reference
  12. Oct 21, 2017 at 4:56 PM
    TheBeast The Beach
    this one looks like a good kit too: deaver pack + TC shackles + new bushings.
    Sunnier, Mysticwolf[OP] and SoCalDave like this.
  13. Oct 21, 2017 at 6:05 PM
    SoCalDave
    SoCalDave New Member
    Dave
    2016 DC 4x4
    Definitely a good option if you don't need to carry a load since K37s aren't that stiff.
  14. Oct 21, 2017 at 6:11 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I've got the same rear set up and not much arch. I'll be installing the Icon expansion pack in the next couple of days. It's sitting here staring at me.
    Sunnier, dcsleeper408 and joonbug like this.
  15. Oct 21, 2017 at 9:32 PM
    Mysticwolf
    Craig
    2011 Red SR5
    I have new bushings and shackles, so I don't need those, just springs.
  16. Oct 22, 2017 at 3:19 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    Along with my ome I added bags and a compresssor. Nicest riding springs i have ever had.
  17. Nov 4, 2017 at 8:36 AM
    trikebubble
    trikebubble New Member
    2014 Tundra TRD Off Road DC
    I have the OME Dakar leaf packs and Firestone airbags as well. (with stock shackles for now) I'm waiting on a Four Wheel Camper, so I wanted a setup to carry a load. I hauled about 1000 pounds of flooring last week, and the rear only dropped an inch or so (without inflating the airbags over there resting 5psi) So far I've been very happy with the Dakar packs, they help firm up that wishy washy ride, certainly make the truck feel more planted on the road.
  18. Nov 4, 2017 at 9:49 AM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    I also have OME/Dakar springs, CB +1 shackles, and firestone airbags. I like the setup, nice ride, no sag, although I hardly ever use the airbags. Dakars are worth the $
  19. Nov 6, 2017 at 3:16 AM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    I would NOT recommend Alcan, my truck has a ridiculous squat. Customer service is a joke. My leaf springs warped at 400 miles of normal driving and it keeps warping more and more. I received no resolution to fix my issues either by emails or phone response. So I lost $$$. I will be going with Atlas.
    Mysticwolf[OP] and Sunnier like this.
  20. Nov 6, 2017 at 6:29 AM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    I did the Icon AAL definitely a better ride then stock leafs. Raises the rear about 1.5 inches. But my leaf springs are in good shape if yours are flatting out I would buy a new set
    Mysticwolf[OP] likes this.
