Leaf Springs Squeaky
Discussion in 'Suspension' started by 4Runner, May 16, 2018.
  1. May 16, 2018 at 4:45 AM
    4Runner
    4Runner [OP] New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, ToyTec 3/1.5 BOSS Suspension Lift, TRD Exhaust, TRD Rear Sway, BajaDesigns Squadron Sport Fogs, HeadLight Revolution Stealth LightBar
    dealer cleaned them for free but didn’t help. Have this bad ass truck but sounds like an old clunker when I go over speedbumps or apply the brakes hard enough. You can bounce on the rear bumper and it sounds like a couple having sex in a squeaky bed....and yes, I checked under my tonneau and no one is the bed of my truck. :)
    Anyone else have this problem? New OEM springs will cost around 2400 installed. Wow.
  2. May 16, 2018 at 7:04 AM
    alpinepro4
    alpinepro4 New Member
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune
    Damn $2400 for OEM springs. I paid just over $700 for custom Alcan springs. Did they pull the springs apart and grease them? Sound like they are extremely dry.
    If you have the coin look into custom springs. Ride will be much better, and you can build what you want.
    Grey Wolf likes this.
  3. May 16, 2018 at 7:20 AM
    Nick T
    Nick T New Member
    Nick
    Do NOT grease leaf springs. Install new leaf spring isolators and make sure your leaf spring center bolt and u-bolts are torqued to spec.
  4. May 16, 2018 at 8:51 AM
    4Runner
    Columbia, SC
    They checked all the bolts. I gotta do something. I’m interested in leaf spring recommendations as well is the isolators. I don’t need anything beefy as maybe twice a year I’ll haul a 600# pallet of charcoal but other than that, nit much weight at all. Appreciate any input.
  5. May 16, 2018 at 8:55 AM
    15whtrd
    15whtrd I tried being reasonable, but I didn't like it.
    White 2015 Tundra DC SR5 TRD 4x4 5.7L
    TRD Pro suspension, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate.
    Maybe some dry lithium lube. I wouldn’t want to use grease as it will attract dirt but I don’t think you need to replace the leaf spring isolators this new. Douche them out real good with the hose let it dry then spray it with some dry lube. You may have to reapply when the squeak comes back but it should help for a while.
  6. May 16, 2018 at 9:00 AM
    4Runner
    Columbia, SC
    This is what the dealer did unfortunately.
    Researching the Alcans now. I like what I have read so far. Might give them a call.
    15whtrd likes this.
  7. May 16, 2018 at 9:01 AM
    alpinepro4
    Pat
    Sorry I was thinking dry lube not grease. Look into a new leaf pack if you decide to do something different. Guys at Alcan have been great to work with.
  8. May 16, 2018 at 9:04 AM
    15whtrd
    My front end squeaks. I thought it was the skid plate but no dice. I just like to pretend I have polyurethane bushings so I’m listening to the sound of performance LOL.
  9. May 16, 2018 at 9:11 AM
    joonbug
    joonbug bacon bastrd
    Joon
    NorCal - Dublin
    2015 DC 5.7 TRD off-road
    Not sure what the dealer did, but try washing them yourself. Gotta spray in between the leafs. Just doing that thoroughly will get rid of most of the squeak.
    NewImprovedRon, 831Tun and 15whtrd like this.
  10. May 16, 2018 at 9:14 AM
    15whtrd
    Maybe even jack the truck up by the frame so that the springs are at full droop. That way you can really get in there.
    NewImprovedRon, 831Tun and joonbug like this.
  11. May 16, 2018 at 9:20 AM
    scpete24
    scpete24 Dude
    Orange County, CA
    2016 TRD Pro Super White
    I have the same squeak, but it is coming from my coachbuilder shackles. Bounce on my hitch and sounds like people having sex in the back similar to the song Triville - Some cut (youtube it if you dont know haha). Got under there and could feel the vibration on my shackles when it squeaked. Worth a shot to check your shackles, might be them making the noise and not your leaf springs
    rocky_mtn_trd and 15whtrd like this.
  12. May 16, 2018 at 9:51 AM
    4Runner
    Columbia, SC
    Will check out the suggestions. According to my service manager, they separate the springs and clean in between them. There is a TSB on this. They did install my Toyotec adjustable shackle a few months ago. But they checked all the bolts and they think it is the springs. I’ll double check.
  13. May 16, 2018 at 10:00 AM
    4Runner
    Columbia, SC
    Yep....they checked the shackle so they are convinced it is coming from the springs.
  14. May 16, 2018 at 10:23 AM
    n2deep
    n2deep Overlander - Speed Glamper
    Mojave Desert
    2010 Tundra DC
    Camburg Long Travel -Front King/King Secondary Triple Bypass - McNeil Fiberglass Rear -ADS Triple Bypass Deaver K37 Method Mesh 35x12.5x18 Cooper SST Maxx
    take a can of WD 40 and start with the shackles till you figure out the point that is making the squeak. Then address that area.
    831Tun, TheBeast and 15whtrd like this.
  15. May 16, 2018 at 11:26 AM
    scpete24
    scpete24 Dude
    Orange County, CA
    do you know the TSB number? I could have sworn it was my shackles but maybe I was just feeling the vibration from the springs...
  16. May 16, 2018 at 11:35 AM
    TheBeast The Beach
    I used WD40 dry lithium lube. Works great.
  17. May 16, 2018 at 11:58 AM
    4Runner
    Columbia, SC
    I don’t. He just told me he replaced a pair one time and got called out because the bulletin spells out to wash.
  18. May 17, 2018 at 3:05 PM
    4Runner
    Columbia, SC
    Alcan Springs coming. Increased load a bit, going with OEM bushings (Alcan recommendation) and will be here in 4 weeks. Thanks for the input. Looking forward to my last mod....yea right.
    dcsleeper408 likes this.
  19. May 17, 2018 at 4:07 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I sprayed chain wax on the spring bushings. Worked for me.
    831Tun likes this.
  20. May 17, 2018 at 4:28 PM
    4Runner
    Columbia, SC
    Done that.
    Hoping the new springs will not only enhance my ride and add some weight capacity but eliminate the squeak. Well worth the $$ in my books. I’ll report back in about 4 weeks.
  21. May 17, 2018 at 4:42 PM
    rocky_mtn_trd
    rocky_mtn_trd Voided Warranty
    Jeremy
    Palmer Divide, Colorado
    2017 Tundra SR5 CM TRD
    Just curious, but what setting do you have the ToyTec shackles set at, middle or top? When I initially installed mine, I used the middle setting and it developed a squeak where they were rubbing a bolt coming down from the interior of the truck bed. I figured it out when I raised the shackles to the highest setting and the squeak went away.
  22. May 17, 2018 at 4:59 PM
    4Runner
    Columbia, SC
    Middle. Yes, I have clearance. I brought that to thier attention on install.
  23. Jun 27, 2018 at 12:58 PM
    4Runner
    Columbia, SC
    No more squeaks. Alcan to the rescue. Woot! Woot!
    Specs = stock height and 200# extra weight.
  24. Jun 27, 2018 at 2:29 PM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    what did these cost you?
  25. Jun 27, 2018 at 2:43 PM
    4Runner
    Columbia, SC
    An arm and leg but about 1/2 OEM. $1,078 delivered.
  26. Jun 28, 2018 at 8:50 PM
    texasrho83
    texasrho83 Teacher in a Tundra
    Charles
    Conroe TX
    2016 DC MGM 4x4
    I've done a little..
    I also had a squeak but didn’t mind it. Incidentally, I installed 2” Pro Comp Add A Leaves with isolators and applied lithium grease to the OEM pack while I had the leaves apart.
    Not a peep since.
  27. Jul 2, 2018 at 11:57 AM
    scpete24
    scpete24 Dude
    Orange County, CA
    Was your more of a squeak or a creak? when I bounce on my hitch my truck squeaks but when I'm driving around and there is some flex in the rear suspension its more of a popping and creaking noise. Wondering if it's my shackles or the leaf springs...
  28. Jul 2, 2018 at 12:12 PM
    iHacker
    iHacker New Member
    AR
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Is a good idea to check your spare tire, I had the same clunky sound in my Tacoma it was new at that point and took the truck to dealership, they cleaned and lubricantes the leaft springs but the clunky sound re-appeared next day.
    For some reason I checked my spare tire lowered completely and the put it back a bit tight and Like magic this eliminated the clunky sound
  29. Jul 2, 2018 at 12:18 PM
    scpete24
    scpete24 Dude
    Orange County, CA
    Thanks for the thought, I have checked and rechecked the spare. I'm running CB shackles so they are a bit bigger and I made sure the tire was not hitting/rubbing either and that it was seated properly under the truck. Did the dealership clean and lubricate the leaf pack for free?
  30. Jul 2, 2018 at 12:40 PM
    iHacker
    iHacker New Member
    AR
    Yeah they did that free under ToyotaCare, but that was for my Tacoma never had a similar issue in my Tundra
