Largest Tire size for 2019 Tundra TRD PRO
Discussion in 'Wheels & Tires' started by ncomeau35, Jun 4, 2019.
  1. Jun 4, 2019 at 3:57 AM
    ncomeau35
    ncomeau35 [OP] New Member
    North of Boston
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    Hey guys, I just picked up my 2019 TRD PRO and while the truck looks bad ass, I feel as if I need to upgrade my tire package again...when I had it at the dealer, I initially was going to upgrade to 20" rims with larger nitto ridge tires. I was then informed by the dealer that I couldn't add the 20" rims and larger tires even with the stock TRD leveling kit. Therefore, i stuck with the stock TRD 18" rims and added a smaller size nitto ridge tire. Now, after a few days if riding around and checking out my truck from every angle here's what I've noticed... because I added the matte black trim flares, my tires seem to sit "inside" the wheel wells.
    Here's my question, what would be the largest size nitto ridge grappler tire could I install whilst keeping my 18" rims?? And would I need to add the spacers to expand the tires outward by using spacers, or would a larger tire do that for me? If yes, what size spacer would I need, and where to get it from?
    Thanks,
    Neil
    Reelman and TOYOTRD8 like this.
  2. Jun 4, 2019 at 4:35 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
  3. Jun 4, 2019 at 11:25 AM
    Rustynailz
    Rustynailz New Member
    2019 black trd pro
    What size do u have on now? I’ve been researching this last week and I think the largest without tubing or having to trim anything is 285/70
  4. Jun 5, 2019 at 5:34 PM
    RBDTx
    RBDTx New Member
    2019 Tundra TRD Pro White
    With no mods, no trimming, no removing trim or anything, the best I can come up with agrees with Rustynailz above. I would have gone with 285/70-18 if they were available in the tire I wanted. Almost every other comment for anything bigger seems to come from someone with shims, spacers, offset or something other than stock TRD Pro. Some say a larger size works but others with the same larger size say they had to remove a small front flap or something like that. E.g. Watt Maker has a 1” lift in rear; may be right on 295’s, but others suggest rubbing with 295’s in some positions or with some tires. I wonder about the use of 295’s on an 8” wide wheel; probably ok but I think some sites say 295 means use an 8.5” wide wheel. Personally I would choose a narrower wheel to avoid rock/damage to the wheel if possible, but there are some places that say 295 means 8.5” wide. I went with 275/70-18 because my offroad is on rock or shallow mud over rock and the difference in size really will not matter much and I wanted a narrower tire in the rain (southeast Texas)
    860Lunar likes this.
  5. Jun 7, 2019 at 2:32 AM
    ncomeau35
    North of Boston
    I'm currently running nitto ridge grappler P275/65R/18 but would like to go bigger, ideally to a 35" tire for a more aggressive stance. I was told I should be able to fit the 35's w little to no rubbing w out mods. My guess is the dealership didn't want to put anything on the truck out of spec, as I noticed my stock tires were the same size.
  6. Jun 7, 2019 at 3:19 AM
    Welcome from NY.
    escuzi_me likes this.
  7. Jun 8, 2019 at 5:39 PM
    ctraut5
    ctraut5 New Member
    Germantown,TN
    2019 Black TRD Pro
    I'm running 285/70r18 Ridge Grapplers with 1" Bora spacers on the stock Pro suspension and wheels with no problems at all.
  8. Jun 8, 2019 at 6:08 PM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    295/70r18 all day front mudflap removal is no big deal 2 bolts, that's it.
  9. Jun 8, 2019 at 6:43 PM
    Rustynailz
    2019 black trd pro
    Why did u put 1” spacers?
  10. Jun 8, 2019 at 6:47 PM
    Rustynailz
    2019 black trd pro
    What tires are u running? I’ve been looking at some and a lot are 12” wide. Would that run into the uca? And do u have full range of motion with 295’s without rubbing
  11. Jun 8, 2019 at 6:59 PM
    ctraut5
    ctraut5 New Member
    Germantown,TN
    2019 Black TRD Pro
    I wanted a little bit wider stance.
  12. Jun 8, 2019 at 7:40 PM
    proROB
    proROB New Member
    Robert
    Temecula, Ca.
    2017 Tundra TRD PRO
    295/70-18 not a single modification and no rubbing or contact anywhere full lock to lock.
  13. Jun 9, 2019 at 5:20 AM
    TRDProLife
    St.Louis
    Atturo Trail Blade X/Ts they do run a bit skinnier than others like the nittos or toys. They are still big ass tires.
  14. Jun 9, 2019 at 5:58 AM
    Rustynailz
    2019 black trd pro
    So if I went 295/70/18 I wouldn’t have to put spacers or trim anything? Might have to remove front mud flap.... with stock rims
    now what tire? Falken wildpeaks, cooper a/t3 xlt, or the BF Goodrich at
  15. Jun 9, 2019 at 6:15 AM
    TRDProLife
    St.Louis
    I prefer the A/T M/T hybrids like Nitto ridge grappler, Toyo open country rt, Atturo Trail Blades etc.
  16. Jun 9, 2019 at 6:33 AM
    Rustynailz
    2019 black trd pro
    Oh yeah forgot about the ridge grapplers
  17. Jun 19, 2019 at 10:25 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    man i cant decide if i want to keep my original pro headlights or upgrade to the LEDs... The leds are better but i kinda like that original trd pro look..
    Watt maker likes this.
  18. Jun 20, 2019 at 10:13 PM
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
  19. Sep 13, 2019 at 3:42 PM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    19, Limited, CrewMax, Off Road, Cement Gray
    None Yet
    Does anyone have the 305/65/18 on a stock Tundra ?
  20. Sep 13, 2019 at 3:43 PM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    I'm ready to pull the trigger on either the 295/70/18 or the 305/65/18, I would like to see the look of both . Thanks
    Owls5 likes this.
  21. Jan 31, 2021 at 12:13 PM
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    Hey. Did you ever do the 305s??? Im looking to do 305/60r18 ridge grapplers with 1.5 inch bora spacers. How did yours work out???
  22. Feb 1, 2021 at 11:27 AM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    No. I went with the 295/70/18 Ridge Grapplers . Looks larger and better
  23. Feb 1, 2021 at 11:59 AM
    TommyTundra
    Long Island NY
    2019 PRO
    Did you do any spacers???
    Any issues with your abs or vehicle stability control system with the larger tires??
  24. Feb 1, 2021 at 1:02 PM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    No issue at all . But I went with the Bilstein 5160/6112 combo fro Boss Offroad (703) 719-4410 . Awesome guys . went with the 1.9 inch on the front and 1" in the back . I have it 1" higher in the back . but I like a little rake. I also went with their Shackles and to get the 1" . Their Shackles can be adjusted but I installed it at the 1" Here is the links to their shackles
    https://boss-offroad.com/i-30498934...hackles-2007-2021-toyota-tundra-in-stock.html
    Here is the 5160
    https://boss-offroad.com/i-30498891...007-2020-toyota-tundra-sold-individually.html
  25. Jul 30, 2022 at 11:51 AM
    Eddy76
    Eddy76 TOY TND
    Eddy
    PHX.AZ
    Hello Tundras. Is it possible to combine both wheel and tire upgrade to a suspension mod like stronger and stiffer leaf springs in the rear with new upgrade stronger and stiffer lift shocks shackles wheel spacers and trd brake system rear and front as well for the front suspension. And also having air bags in the rear for more upload weight capacity? I'm at 7 ft height with Hankook Dynapro 35 12.50.18. I would love to lift it more at least another 12 inches with somer way wider wheels and taller but would like to go 21 inch wheels or at least 20's what do you recommend? Sorry to bombard with a lot of questions thanks in advance.
