Knocked the dust err rust off that....
Discussion in '1st Gen Tundras (2000-2006)' started by Hi06silver, May 2, 2020.
  1. May 2, 2020 at 8:40 PM
    Hi06silver
    Hi06silver [OP] Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Decided I was done looking at the surface rust on my rear bumper...thought I'd dive in. Well, most of you know how this goes. Always something else you should to while you do what you intended. I've been poking around underneath and thinking after this I'm just going to spray fluid film or wool wax in every nook and cranny. The receiver area is gonna be a PITA to wire wheel so spraying those two are my best thoughts to remedy.
    Meant to post this in: What have you done for 1st Gens...
    Hooptytrix, Darkness, bmf4069 and 3 others like this.
  2. May 3, 2020 at 3:57 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Wire wheel will just polish that crusty stuff. Hit it with a needle scaler from Harbor Freight. Then convert the rust with phosphoric acid and paint whatever topcoat you prefer. I went with black bed coating on my new bumper. Looks good!
  3. May 3, 2020 at 7:56 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    This is on my list of things to do as well....
  4. May 5, 2020 at 11:03 AM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Here's the after. Left off the factory hitch parts for now until I get it cleaned up and painted. New hardware ordered also but had to have bumper on to get around.
    The little red dealyo?! Awesome, for taking dog hair out of seats when detailing. We all need one. Works great on my Okoles. I never knew such a little thing existed good thing I'm single I just fell in love with it.
  5. May 5, 2020 at 11:37 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Mo' black! :yes:
  6. May 5, 2020 at 12:39 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Here are the part numbers if anyone needs them also...Yes I know it says lower control arm bolt. I checked, finding the same thing when I ordered. Guy said it's the same bolt with 2 different names and locations.
    90119-A0048
    Bumper Cover Reinforcement Beam Bolt
    4
    90119-12311
    Bolt W Washer
    4
    90119-A0259
    Lower Control Arm Rear Bolt
    2
  7. May 5, 2020 at 12:54 PM
    Professional Hand Model
    Hand Protectors
    Makes the truck so much cleaner looking. Looks like the finish turned out smoothly. What spray product did we use?
  8. May 5, 2020 at 2:13 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Thanks! And I think so too. It's all rattle can shit.
    I didn't clear. Didn't have clear on I before and lasted this long. If it fails miserably I'll either bite the bullet and buy a tube bumper or pay a body shop guy I know to do it. I figure it's a bumper, rattle can isn't that big of deal. No way I'd paint anything on the actual truck body panels that way.
    Just a note, that filler primer I wouldn't use again. Went to clean it before paint and it started to smear like the w/g remover softened it. Either it wasn't cured ( I gave it time instructions said), it doesn't like the other brand etching or it's junk...
    I'm going to let the inside of the bumper show some rust and then ospho it. I know, I know but needed it back on.
  9. May 5, 2020 at 2:20 PM
    owb2gp
    owb2gp New Member
    ID
    Lilly brush is great. Snatches up dog hair from the carpet like nothing.
  10. May 5, 2020 at 2:27 PM
    Hand Protectors
    That primer filler powders up too much. It does well if you sand it with 1500 and then wipe it terry cloth, but it almost completely disappears. I think, unless its rusted where you need to Ospho or Rust prime, we are better off just using the same Lacquer finish as a combo prime and then finish coat (on sound finishes).
  11. May 5, 2020 at 3:05 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    You don't like my finish? LOL. because no clear I assume? I do value your advice/input as well as some others. I could have finished better but need my truck. Really I need another car so I can spend ALL of the time I need to when I do these things
  12. May 5, 2020 at 3:10 PM
    Hand Protectors
    See my post #7 where I said I liked the finish and it looks good.
    My point in post #10 is discussing alternatives to the powdered primer.
  13. Sep 2, 2022 at 10:26 AM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    So I have the rear bumper off and cleaning it up again with some Ospho befor repainting.
    What exactly am I looking at here?
    Areas where it didn't actually turn the rust black but did what it's supposed to?
    Has more of a film on it after reactivated and then washed with dawn and water rinse. Whole thing was pretty much white til I wore wheel some parts of concern. Weird thing is those parts are not really wheeling off to show rust color near as easy as the parts that look bare.
    This is after 3 coats. There was no loose rust on there prior to putting the ospho on.
    First two pictures are pre-wash, Dawn water rinse.
  14. Sep 2, 2022 at 11:22 AM
    Jack McCarthy
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Not rust, rustic.
