"Knock" Sound When I Brake or Accelerate
Discussion in 'General Tundra Discussion' started by SullyMoto19, Jun 3, 2019.
  1. Jun 3, 2019 at 6:29 AM
    SullyMoto19
    SullyMoto19 [OP] New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    Hey guys, I just had an oil change about a week ago. Since then, I've noticed there is a decently loud "knock" when I brake. It's not continuous, just one "knock" and nothing more. IT's starting to drive me insane.
    I got under the truck last night and saw my sway bar is favoring the driver side and actually coming in contact with my lower control arm(?). I plan on taking the sway bar off anways, but I still don't think this is the problem.
    Anyone dealing with a similar issue? Would it be my brakes?
    TIA.
  2. Jun 3, 2019 at 6:45 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Did you do the oil change?
    What needs to be removed from your truck in order to perform one.
    I would check and see if tings were put back on right first.
  3. Jun 3, 2019 at 6:51 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    My 17 with 45k is starting to do the same thing only when I brake.
  4. Jun 3, 2019 at 6:51 AM
    SullyMoto19
    Tyler
    Houston, Texas
    I did not, took to a shop down the street. As far as I know, the only thing that needs to be removed is the skip plate. But I have yet to do my own oil change on the Tundra.
  5. Jun 3, 2019 at 6:52 AM
    SullyMoto19
    Tyler
    Houston, Texas
    mine is a 17 with 40k, so very similar.. never found out the issue?
  6. Jun 3, 2019 at 7:12 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    Mine does that because I used after market brake pads. My wife's 4Runner also did that until I replaced the brake pads with OEM Toyota pads. Toyotas don't seem to like after market pads. Check to see if that may be the problem.
    SullyMoto19[OP] likes this.
  7. Jun 3, 2019 at 7:16 AM
    Rngr188
    Chad
    Harrison AR
    No I was actually getting ready to start a thread here asking the same question. I lied about my mileage I'm actually at 41k just had the 40k service done this weekend they said brakes look good.
  8. Jun 3, 2019 at 7:16 AM
    SullyMoto19
    Tyler
    Houston, Texas
    I’m pretty sure I’m due for a break job. So it would make sense on the breaks
  9. Jun 3, 2019 at 7:17 AM
    SullyMoto19
    Tyler
    Houston, Texas
    Hmm.. But I can go over speed bumps and there is no knock. Almost want to rule the sway bar out. I’m thinking it’s the pads
  10. Jun 3, 2019 at 7:19 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Check and see if there are any bolts missing from the skid plate.
    They may have just put it up there with just the hangers
  11. Jun 3, 2019 at 7:21 AM
    SullyMoto19
    Tyler
    Houston, Texas
    Ok, I’ll climb under when I get home from work and check it out.
