King install - quick help
Discussion in 'Suspension' started by Boosted4runner, Oct 8, 2018.
  1. Oct 8, 2018 at 7:10 PM
    Boosted4runner
    Boosted4runner [OP] Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    so....the front resi Mount is very much hitting the factory plastic, which I can cut - but what about whatever is behind it!?
    SoCal619 likes this.
  2. Oct 8, 2018 at 7:10 PM
    Boosted4runner
    WA
    Front right - passenger
    - and I know I spelled install wrong lol
  3. Oct 8, 2018 at 7:12 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Those don’t fit ur truck. Send them to me immediately. I’ll even pay shipping
  4. Oct 8, 2018 at 7:13 PM
    Boosted4runner
    WA
  5. Oct 8, 2018 at 7:14 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    cut the plastic.
    have the resi in the mount prior to fitting it in(don't tight clamps too much might need to rotate if need)
    then you should be able to tuck away in there.
    try not to pull any or cut any of the AIP stuffs
  6. Oct 8, 2018 at 7:15 PM
    Boosted4runner
    WA
    Thanks! Sure seems like there isn’t any room. Must work though - 10-4.
    dcsleeper408 likes this.
  7. Oct 8, 2018 at 7:17 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Can you mount the resi on top of the platic?
    dcsleeper408[QUOTED] likes this.
  8. Oct 8, 2018 at 7:19 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I dont think so. cutting that little section just exposes the AIP stuff. He just needs to stuff the resi in between the mudguard and the frame
    831Tun[QUOTED] likes this.
  9. Oct 8, 2018 at 7:20 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Screw the plastic just pop the bottom plugs and rip it out.
  10. Oct 8, 2018 at 7:48 PM
    Boosted4runner
    WA
    Yes, thank you!! :thumbsup:
    Trimmed up the plastic and it fit back in there. It’s definitely sitting next to whatever that tank is lol.
  11. Oct 8, 2018 at 7:51 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Windshield washer fluid reservoir.
    Boosted4runner[OP] and SoCal619 like this.
  12. Oct 8, 2018 at 8:21 PM
    Boosted4runner
    WA
    Thanks!
    So are factory sway bars ditched too?
    Lmao!
  13. Oct 8, 2018 at 8:33 PM
    Boosted4runner
    WA
    LOL! My CNC machine is broken :rofl:
    SoCal619 and Darkness like this.
  14. Oct 8, 2018 at 8:46 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Ditch it!
    Casper421, dcsleeper408 and SoCal619 like this.
  15. Oct 8, 2018 at 9:55 PM
    Boosted4runner
    WA
    It’s been ditched. These Fing Kings took me just as long to do the front as it did my entire wife’s rig a few weeks back lol. These fuckers are long, heavy, and thick.
  16. Oct 8, 2018 at 9:57 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    See I told you they didn’t work for ur truck hahah
  17. Oct 8, 2018 at 10:48 PM
    Boosted4runner
    WA
    LOL!
    Going on the test-drive now :p
  18. Oct 8, 2018 at 10:49 PM
    Boosted4runner
    WA
    I have a serious bro-rake until I get the rear shackles in. Not sure I want to do it tonight.
    SoCal619 and dcsleeper408 like this.
  19. Oct 8, 2018 at 10:50 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Looks goood :thumbsup:
    anthonygan likes this.
  20. Oct 8, 2018 at 10:51 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
  21. Oct 8, 2018 at 11:14 PM
    Boosted4runner
    WA
    Fawk! Did 15 Miles, front right doesn’t seem right. Almost “clunking” and it’s sitting 1” higher than driver, but adjusted the same height. I’m going to have to pull the wheel and see if I can adjust on truck.
    Eta - guess it’s only 3/4” :-/
  22. Oct 8, 2018 at 11:22 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Check the clunking for sure. Very common to get the driver lean after lift.
  23. Oct 8, 2018 at 11:49 PM
    Boosted4runner
    WA
    Yea, I actually called Coach Builder and he sent me 3 CB shims, 2 for driver side 1 for passenger to account for lean. I had planned to run that setup, but after only doing 1 shim on passenger, and setting truck back down - it was pretty high. So I didn’t do 2 on driver, only one.
    I’m showing 12 threads on shocks + 1 shim, which should put me at 3” - which I think I am 2.50” driver and 3.25” passenger. Passenger just doesn’t feel right. I think I’ll just adjust passenger down a bit, I don’t want to lose ride quality.
