Keyless entry??
Discussion in '1st Gen Tundras (2000-2006)' started by Boatride89, Jun 12, 2021.
  1. Jun 12, 2021 at 5:58 PM
    Boatride89
    Boatride89 [OP] New Member
    J
    2006 tundra double cab
    None
    I just purchased a 2006 double cab. Seller had just 1 key?? The silver key?? So I bought a cheap key fob and went threw the programming process?? Door cycled one time. Like it should. But the key fob does not lock or unlock the doors???? Can some help. Thanks.
  2. Jun 12, 2021 at 6:16 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    On the back, what is the FCC ID #.....BAB237131- 056 ?
    Also, do you know what alarm system is installed....factory or port installed ?
  3. Jun 12, 2021 at 6:44 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Access cab and double cab have two different ways to program. Make sure you are using the correct instructions
  4. Jun 12, 2021 at 6:58 PM
    Boatride89
    J
    None
    It’s 2 wheel drive. We’re do u find the FCC ID?? Thanks.
  5. Jun 12, 2021 at 10:54 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    You have to find out if you have the RS3200 or RS3000 system on your truck, the FCC ID is on the back of the key fob , Toyota stealership should be able to tell you, tell them you’re trying to buy a remote for your truck and ask for the part number,(I’d call more than one location to make sure they all give you the same part number) google that part number and you should be able to find what FCC Id belongs to that part, make sure they check with your VIN#
  6. Jun 14, 2021 at 5:07 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
