Keyfob acting weird
Discussion in '3rd Gen Tundras (2022+)' started by 389 24/7, Jul 26, 2024.
  1. Jul 26, 2024 at 7:36 AM
    389 24/7 [OP] 125k on the gen3
    Oregona
    2022 TRD OR
    Nada
    Went outside to fire up my tundy a few minutes ago & the keyfob was no responsive
    Thought maybe the battery was dead in the keyfob, so I tried my spare....same result
    I used the emergency key inside the fob to unlock drivers door & my alarm started screaming at me for about 1 min
    I then tried to push start, no luck
    But a message appeared in the dash cluster advising me to hold the keyfob near the push start & then I tried the push start & viola the truck turned on
    Any thoughts?????
    Maybe this is in the manual
    But I'm your standard guy who never reads the manual, hehe
  2. Jul 26, 2024 at 7:42 AM
    ftp19601960
    ftp19601960 New Member
    '23 limited
    Tundrastruck91 likes this.
  3. Jul 26, 2024 at 7:54 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Somebody was using a replicator to copy your key code so they could steal your truck. The interference was causing the malfunction.
    I’m just kidding. I have no idea. lol. However….
    Tunrod and mrfreeman like this.
  4. Jul 26, 2024 at 4:51 PM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    My original key fob battery got low which triggered the dash cluster to let me know this,I took my 4 month old fob and swapped the battery along with the actual electronic fob and put that in my every day use one, AJT and the truck wouldn't unlock when I grabbed the drivers door handle nor would it accept a lock command when touching the door handle.
    So I ended up swapping the battery from new to old and all is good.
  5. Aug 2, 2024 at 5:09 PM
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    The other day I did something that caused a similar thing. I had to hold the key fob up to the push button. I can’t remember the circumstances though. Almost think I unlocked via app, went out to start it without the key…no. I remember there was an explanation in my mind anyway…
  6. Aug 3, 2024 at 11:43 AM
    jehremmy
    jehremmy New Member
    I've had all sorts of issues with my original fob, replaced the battery multiple times in the last year, but will still periodically not work. My 2nd one has zero issues and dealer found nothing wrong but thought maybe I store the fob to close to the truck...
  7. Aug 3, 2024 at 11:49 AM
    Yotaholic4life
    Yotaholic4life New Member
    24 TRD Limited CM LB, 23 SR5 8ft bed DC
    24 TRD Lift
    I’ve had that happen ! Not sure what I did to provoke the issue but same result . Message to hold key to start button and Varroom , travel on ! Weird safety feature ,, prolly caused by remote app usage can’t talk to key fob ? Who’s know lol
  8. Aug 4, 2024 at 7:03 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    My original Fob battery went dead at just 1 yr of service. Changed it. But twice in my trucks 13 months it has asked me to hold the fob to the Start button. Once recently and I never got out of the truck after originally turning it off. Very weird.
  9. Aug 5, 2024 at 4:23 AM
    Oregona
    2022 TRD OR
    Nada
    Got the new battery & all good so far
    I should swap the battery in my spare to be safe
  10. Aug 5, 2024 at 4:28 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Sounds like the typical series of events when key battery goes out. Exact thing happened to me couple of months ago to include horn blasting.
    This truck never alerted for a low battery. Just died one day out of the blue. My wife's Nissan will come up with a warning message for weeks each start until you change it. We with all the nanny ware in this truck they forgot that one
  11. Aug 5, 2024 at 3:03 PM
    PNW Tundra Mike
    Southern Cal
    Agree. The Toyota App told me my Fob battery was low right when it died. ( I did notice its range getting shorter a few days before - next time I’ll check it )
  12. Aug 5, 2024 at 3:07 PM
    PNW Tundra Mike
    Southern Cal
    One little tip I learned a couple Toyotas ago for your spare, in case you didn’t know, put it to sleep for storage. In one hand, Push Lock twice and hold it down, with the other hand push and hold Unlock. The red light will flash and stop. It’s now asleep. Not transmitting or receiving. To Wake, just push any button.
    Tundrastruck91 and ChucklesToy like this.
  13. Aug 5, 2024 at 11:14 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    Don't know if it's a battery issue with mine, but I've noticed over the last few weeks that when I press the door handle to lock the truck, there's about a 2-3 second delay before it locks, when it used to lock in under a second. Don't know what brought on the change, but my son's truck also started doing it about a week or so after mine.
  14. Sep 2, 2024 at 8:16 PM
    LLL
    LLL New Member
    2023 Tundra Limited TRD Off Road
    Same issue occurring for me now. One of my two key fobs died. The other seemingly died, but the car alarm went off. This evening, while doing nothing with the key fob or the truck, the truck alarm went off. Something is very wrong with these fobs. I've never had to replace batteries for one, let alone two, key fobs. And why would it stop working and the car alarm randomly go off. It's happened three times today. I'm dropping it off at the dealer tomorrow. Their problem.
  15. Sep 2, 2024 at 9:37 PM
    LunarRockAgave
    LunarRockAgave New Member
    LimitedCrewMaxLunarRock24
    I'm really interested in what you hear back from this. I have the same problem. Only additional symptom I have though is that my horn honks rapidly 3 times randomly. Not frequently but every so often, and I have had my alarm go off randomly. Only thing I can think of is the non factory alarm systems dealers are adding. I'm thinking of removing that module from Rockledge securities. Anyways keep us posted, thanks!!
