Key too long for glove box
Discussion in 'General Tundra Discussion' started by Brad L, Feb 26, 2020.
  1. Feb 26, 2020 at 2:41 PM
    Brad L
    Brad L [OP] New Member
    Brad
    2017 Tundra SR5 TRD
    none
    I bought a used 2017 Tundra and just received two keys (with chips). I didn't notice until today that the keys will only go about half way into the glove box lock. I opened the glove box and looked at the depth of the lock. Apparently the key used on it is about 3/4" long, as the lock mechanism is too short for the ignition key. The keys work fine on the tailgate. Now I am wondering what all I am missing. I suspect that there should be a key fob, too, because it is a SR5 TRD trim level, and the specs show that remote entry was standard. Please enlighten me.
  2. Feb 26, 2020 at 3:35 PM
    The key in the glove box is correct. It is not supposed to go in any more than that. I believe that you can order a key fob from Amazon and have it programmed at a locksmith or by someone that has TechStream software.....or see if the dealer will throw one in on the deal.
  3. Feb 26, 2020 at 3:40 PM
    Brad L
    Brad
    2017 Tundra SR5 TRD
    none
    Thank you for that information. Am I correct in my assumption that all of these trucks also came with a remote entry fob?
  4. Feb 26, 2020 at 5:05 PM
    Yes you should have one.
  5. Feb 26, 2020 at 5:13 PM
    Brad L
    Brad
    2017 Tundra SR5 TRD
    none
    Thanks again. I will look into getting one.
  6. Feb 26, 2020 at 5:16 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Unless you got a SR "work truck" package you should have two fobs.
  7. Feb 26, 2020 at 5:21 PM
    Brad L
    Brad
    2017 Tundra SR5 TRD
    none
    I bought this from a dealer in Lubbock. I asked about fobs prior to buying and they were really evasive. Wouldn't even tell me if it was equipped to use remote entry. I did get a screaming good deal on it and am pleased as can be. I guess that I'm going to give up a few of those dollars saved to get it up to spec.
