Just joined the Tundra club
Discussion in 'New Member Introductions' started by Hotrodney, May 3, 2021.
  1. May 3, 2021 at 7:01 PM
    Hotrodney
    Hotrodney [OP] New Member
    TJ
    2021 Tundra Crewmax
    Hi all. I just took delivery on my 2021 Tundra crew max. Getting ready to haul our 24 ft travel trailer in a couple weeks. any advice on best use of the new truck? Anything you would suggest for getting set up? Thanks all.
    MTRock, Prostar 190 and Metro14536 like this.
  2. May 3, 2021 at 7:14 PM
    Metro14536
    Metro14536 New Member
    Brandon
    Las Vegas, NV
    2021 Army Green SR5 CM TRDOR 4x4
  3. May 3, 2021 at 7:30 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    Welcome! Is the trailer new too? I upgraded from a Tacoma to a Tundra for the purpose of better towing for our travel trailer. It has been night and day.
  4. May 3, 2021 at 7:30 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from so cal
  5. May 3, 2021 at 7:36 PM
    Welcome from NY.
  6. May 3, 2021 at 8:44 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Welcome from Alaska
  7. May 3, 2021 at 8:51 PM
    LuvniForce
    LuvniForce New Member
    2008 Silver Crewmax 2wd ARE topper
    Welcome from Nebraska
    Advice- use your stimulus checks to pay for the fuel while towing… other wise you’ll go broke haha . No, seriously I’ll bet you’ll like the truck!
  8. May 3, 2021 at 9:05 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  9. May 3, 2021 at 9:54 PM
    2Tundras
    2Tundras New Member
    Jeff
    2015 1794 Edition
    Welcome from Idaho! Thanx 4 Joining Our Grupe! (hooked on phonics)
    I have a 2015 CM 1794 Edition and thought it had the full towing pkg. because of the built-in trailer harness connections and the Tow/Haul button. Either it did and no ability to engage trailer brakes, or it didn't(most likely). I made a 12-mile haul with a 3,000 lb trailer and 8,500 lb excavator and found no trailer brakes working...you downshift to slow down, pretty much. Took it in to a car dealer to install an after-market brake controller, they couldn't get it to talk to the trucks systems and uninstalled it. I then found a mechanic to install one that worked. Quite helpful.
    My manual says the factory brake controller (if mine had it) would have readouts on the instrument panel, which it doesn't.
    I haul a lot for work. 3 weeks ago pulled a 6,500 lb skidsteer + 2,500 lb trailer + 400 lbs cement mix 100 mi., r.t. and it pulled well, though I kept the speed down for safety.
  10. May 3, 2021 at 10:09 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Welcome from GA!
  11. May 3, 2021 at 10:14 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome from Dallas...
  12. May 4, 2021 at 12:49 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
  13. May 4, 2021 at 2:44 AM
    Welcome from Ohio
  14. May 4, 2021 at 2:45 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Welcome on board from Delaware
  15. May 4, 2021 at 4:53 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  16. May 4, 2021 at 5:06 AM
    Use a weight distribution hitch. https://www.amazon.com/EAZ-LIFT-480...istribution+hitch+48058&qid=1620129827&sr=8-5
  17. May 4, 2021 at 6:50 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
  18. May 4, 2021 at 11:51 AM
    SheChirple
    SheChirple New Member
    Mary
    2013 Tundra Black
    Over bed Kayak racks, e-brakes for trailer, tow package, heavy duty tow hitch
    Welcome. I just joined today. My 2013 is a little older, but is perfect for us. We also tow a 24' trailer. I recommend before you tow you verify that you have e-brake controller working properly. Use your tow/haul button and check brakes every single time you hook up that trailer. Also, make sure you have a good stablizer/sway bar set up ~ thatis #1 critical. I towed with a Durango for about 6 months and took one trip to Yosemite from So. Cal.. I thought I was going to die! Seriously, I was stupid. We immediately went out and bought our Tundra and the proper set up installed made it soooooooooo much better. Hardly know the trailer is there, except when the gas tank drains.......Avg 9 mpg with trailer.
  19. May 4, 2021 at 5:02 PM
  20. May 4, 2021 at 8:55 PM
    Marshal
    Marshal Newd Member
    Marshal
    Petoskey, MI
    2014 SR5 MGM 5.7 4x4
    Welcome, and congratulations
