Just installed leer R100 cap. Rougher ride?
Discussion in 'Suspension' started by tiogajoe, Feb 5, 2022.
  1. Feb 5, 2022 at 10:09 AM
    tiogajoe
    tiogajoe [OP] New Member
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    Hi. I have a totally stock 2020 DC TRD OR. It seems the weight of the cap is causing a rougher ride? It weighs less than 200lbs? I'm running 40 psi in my OE Michelin tires. Would air tire air pressure cause this? Maybe shackles or Bump stops? Ideas?
  2. Feb 5, 2022 at 10:11 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    If anything, it would make the ride smoother.
    Half Assed and dpast88 like this.
  3. Feb 5, 2022 at 1:02 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Your tire pressure is too high. Stock tires for OR package 18 inch wheels is 30 front and 33 rear. Running 40 is going to make it ride harder.
    I felt like the stock pressure (sticker on driver door) was too low and ran 33f/35r for best handling and better tire wear. But 40 is too much for a standard load tire. I run that pressure in the 33 inch LT tires on the Tundra.
  4. Feb 5, 2022 at 1:22 PM
    tiogajoe
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    I kinda thought 40 psi was too much. I will try 33f and 35r.
  5. Feb 5, 2022 at 4:34 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I have only found an improved ride from weight in the bed really.
    dpast88 likes this.
