1st Time Tundra Owner - Help me with my build!
Discussion in '2.5 Gen Builds (2014-2021)' started by jnelas, Feb 15, 2019.
  1. Feb 15, 2019 at 2:53 PM
    jnelas
    jnelas [OP] New Member
    2019 Magnetic Grey TRD Sport
    Hi Everyone,
    New member and 1st time Tundra owner here. Looking to start tackling my top priority mods soon. I’ve been doing my homework and have come up with a partial plan that I want to share with everyone and get feedback before I pull the trigger on anything. My top priority is lift/wheels/tires/skid plate.
    Goals and uses
    90% of my driving will be on the street as this is my daily commuter vehicle. My off-road use is pretty much limited to hunting trips in south and east TX mostly dealing with muddy conditions. I have dreams of hunting elk out west in NM and CO in the coming years and would like my rig to be ready to handle some more mountainous/rocky terrain if needed. I don’t anticipate hitting off-road trails but I guess you never know what kind of hobbies I’ll get into. :thumbsup: As far as ride – I’d like to stay as close to my factory ride as possible but realize there will be some give and take here. For looks I want the truck to look “beefy” but have even proportions of lift and tire size. I definitely want to keep the tires as even with the fenders as possible, going no more than ½ inch outside the fender. I’d like to avoid having to do any major cutting/trimming to keep from rubbing. With that said here are my thoughts and questions…
    Wheels
    I like a thicker side wall so I’m thinking an 18x9. I could go 20x9 if I end up with 35’s but I am not anticipating that (see tires below). From what I have learned I think +18 to +25 offset is probably what I need to keep from sticking out too far beyond the fender. Am I correct on this? I’ve read a bunch on the offset and all that but have zero experience here.
    Tires
    I was between the Nitto Trail Grapplers and the Cooper Discoverer SST Pro’s but I think I’ve settled with the Cooper. From what I’ve read I can’t go wrong either way on these. I think I like the look of the Coopers slightly better and they are quite a bit cheaper at Discount so that’s how I’m leaning right now.
    As far as size… I’m thinking a 295/70/18 (34.57x11.73) – to me this is a happy medium between 35x12.5’s or 33’s and will hopefully give me a good fit and look per my goals above.
    Lift
    This is where I think I need the most help and am currently undecided. I think 3-4 inches will be about right. Here are my current top options:
    1. Readylift 3”F / 1”R https://www.readylift.com/3-f-1-r-sst-lift-kit-toyota-tundra-trd-sr5-rock-warrior-2012-2018.html - cheapest option
    2. Readylift 4”F / 2”R https://www.readylift.com/4-f-2-r-sst-lift-kit-toyota-tundra-2007-2018.html - in case I need an extra inch. Says it will allow for a 35X12.5 with no rubbing with a +25 offset
    3. Toytec BOSS - from what I have read there are a lot of folks running these. Seems like it might be a good option for better performance off road than the Readylift but I might sacrifice a little of the factory ride?? Looks like there are multiple option for the rear setup. Not sure if I need different shocks back there or not…
    I’ll probably be making phone calls to talk to both these companies directly but would appreciate any advice on these or any others.
    Skid plate
    Was initially just thinking I’d put a TRD one on since it wasn’t included in the Sport package – but looks like a better option might be to just go with the RCI. Unsure if I need all the various coverages or just the front for my needs. Probably better to be safe than sorry. Any other considerations here besides just spending more cash?
    Other things
    Any advice is appreciated with regard to speedo calibration and/or re-gearing. No idea if this is necessary with my anticipated mods but want to be sure I’m taking everything into consideration.
    Any other factors to consider in all this I’m not thinking of?
    I appreciate the feedback!!
    :mudding:
    TOYOTRD8 likes this.
  2. Feb 15, 2019 at 4:28 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from NC. You've come to the right place to ask those questions. I'm sure someone will be along shortly to help you.
  3. Feb 15, 2019 at 5:21 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Out of those lifts you posted, the boss kit will be your best. Stay away from the spacer lifts, ride will suffer. For the size tires you want 3" is plenty. 90% on the road look into bilstein 5100s, they're adjustable too. Bilstein 6112s are a step up from 5100s.
    zcarpenter92 likes this.
  4. Feb 15, 2019 at 6:13 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
  5. Feb 16, 2019 at 6:23 AM
    jnelas
    Thanks for the tips! Will look into the Bilsteins!
    Berdine[QUOTED] likes this.
  6. Feb 16, 2019 at 6:29 AM
    jnelas
  7. Feb 18, 2019 at 9:10 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Welcome!!!
    Check out my build below vvv
  8. Feb 18, 2019 at 9:56 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Sounds like you've got a pretty good idea on what you want to do already! Either the Boss or Toytec/Radflo kit from Toytec would be good choices, I have the latter, and 295/70R18's are a good size for that lift. Like others have said before, stay away from spacers. Have heard nothing but good things about the Cooper MT's.
  9. Feb 18, 2019 at 11:12 AM
    jnelas
    ok - no spacers it is! Now to decide which Toytec! Thanks for the advice! Any thoughts on the wheel offset for the Boss/Radflo with 295/70/18? +18 sound good for no rubbing but not too far past the fender?
  10. Feb 18, 2019 at 12:14 PM
    Berdine
    Binghamton, NY
    This is +18
  11. Feb 18, 2019 at 2:17 PM
    jnelas
    Awesome, thank you for that reference! 295 tire?
  12. Feb 18, 2019 at 5:54 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
    You’ll get great advice here. My advice is to get the limit your credit card raised as high as possible.
    :spending:
  13. Feb 20, 2019 at 12:39 AM
    Beni36ti
    Beni36ti New Member
    2017 SR5 CrewMax
    Since the primary use of your rig will be communting I would choose a tire that is not too loud...
