JBL Radio swap
Discussion in 'Audio & Video' started by Alaf302, Jan 12, 2019.
  1. Jan 12, 2019 at 2:44 PM
    Alaf302
    Alaf302 [OP] New Member
    Anthony
    Hi I have a 2008 tundra with the JBL Radio system and I have a 2008 tundra jbl navigation head unit and the plug are not all match is it possible to buy a wiring harness to match the navigation head unit
  2. Jan 19, 2019 at 12:50 AM
    Walton
    Walton New Member
    Appleton, Wi
    2010 5.7L FFV LTD CrewMax
    Not sure ive been trying to find info on this as wellnut just for the jbl headunit without nav.
  3. Nov 6, 2021 at 11:35 PM
    Slomoglo
    Slomoglo New Member
    St.Pete , Florida
    2007 Tundra SR5 Dbl Cab 5.7 4x4 w/JBL NAV and leather purchased new. 2011 Toyota 4Runner SR5 4x4 purchased in 2015 used.
    TUNDRA - TRD rear sway bar, thorley headers. Replaced all the speakers recently (2021) 4Runner = Stock
    They do not swap.... but I am looking for a 2007-2010 JBL NAV
  4. Nov 7, 2021 at 3:24 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Hit the wiring diagram thread in my signature and you’ll be able to check and compare the pin outs and connectors for all the different options.
    There are a lot of common connections and some that aren’t. You’ll also need the GPS antenna.
  5. Nov 14, 2021 at 9:50 PM
    HairyKnuckel
    HairyKnuckel New Member
    08 Crewmax
    I came across your comment in my search. I currently have a 2008 CM with JBL and NAV. It doesn't have bluetooth and it drives me crazy. I just spent $250 on this adapter thing that let's me connect my phone via bluetooth to my OEM dash unit. The interface is garbage and I want something different. What I would like to do is just put another stock dash unit into my truck that has bluetooth in it but I don't know if I can. Do you know if I am able to just put a 2013 JBL dash unit into my 2008? I have a feeling that I can't because that would make my life to easy. If I do end up switching it out I'll let you know in case you still want a dash unit.
  6. Nov 14, 2021 at 11:14 PM
    Slomoglo
    Slomoglo New Member
    St.Pete , Florida
    Sad to report... None of the different year models are interchangeable. The E7013 went from 2007-2009, then the E7026 went from 2010-2013 and so on... I have searched for hours. Crutchfield.com did a deep dive and has some solutions. I am going to send mine off to one of the repair companies advertised on E-BAY. My CD player quit 7 years ago so I used the AUX, now that quit 5 months ago, so I am out of luck dj-ing my own music. Funny thing however, the GPS has never stopped working and I was told that was the first feature that quits!
    Sequoia Sunrise likes this.
  7. Nov 14, 2021 at 11:35 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    I've got a 2008 jbl/nav HU with a 2016 nav dvd in it. Never got around to listing it in the 2nd gen marketplace. Hit me up if you're still looking for one.
    tjthomp70 likes this.
  8. Nov 15, 2021 at 6:38 AM
    HairyKnuckel
    08 Crewmax
    What do you mean Crutchfield has a solution? A solution to no bluetooth? What are you getting repaired through Ebay? My system works great I just don't have bluetooth which bugs me. This is the thing I just installed on Saturday.
    https://vaistech.com/product/sl3b-t/
    It works but it is kinda hokey. I had to take the whole dash unit out. At that point I should have just put a new unit in. Have you considered just getting an aftermarket dash unit? I can't decide which one to get and am a little worried about being able to wire it in.
  9. Aug 6, 2022 at 2:18 PM
    tjthomp70
    tjthomp70 New Member
    T J
    2008 Double Cab
    TRD CAI, Gipson exhaust, Opt7 HID, Moto Metal 20" wheels with inserts painted to match the truck. spider wed grille overlay. Changed out wiring harness to run OE JBL navigation and upgraded sub to 10" Kicker. all LED lights inside and out (except for HID headlights).
    Do you still have this? Mine just went haywire and I no longer have a functional screen.
  10. Aug 14, 2022 at 3:45 PM
    Gravy
    Yucaipa, California
    Yeah, I'll send you a message.
