Issues with radio in 2014 tundra
Discussion in 'Audio & Video' started by USMC7051, Nov 12, 2020.
  1. Nov 12, 2020 at 6:24 AM
    USMC7051
    USMC7051 [OP] New Member
    Just yesterday, my radio display went black, but, the radio still works. Although, the only thing that will work as of now is my Bluetooth, I assume since that's what it was set on when it went black. Tried disconnecting battery, checked fuses, even tried a hard reboot. I never knew I had a "screen off" setting, but not sure if that's the problem, because I cant see the screen to access the settings.
  2. Nov 12, 2020 at 6:41 AM
    timsp8
    NY
    Sounds possible that the screen failed. Do you live where it’s hot and park in the sun?
    Is it touch screen? If so, does it change when you touch it even with the black screen? If it does then your screen backlight could have failed.
  3. Nov 12, 2020 at 6:45 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    There is a screen off function on my HU although its a 2017. However, any mode change on the side buttons will turn it back on.
  4. Nov 12, 2020 at 6:48 AM
    USMC7051
    Yes, I live in Texas!! So, very hot. And yes, when I touch the screen, I can hear the beeping sound of icons being pressed.
  5. Nov 12, 2020 at 7:11 AM
    timsp8
    NY
    Sounds like the back light for the lcd burned out.
  6. Nov 12, 2020 at 7:17 AM
    USMC7051
    Do you know if that's repairable or not? I haven't found anything on the internet yet.
  7. Nov 12, 2020 at 7:21 AM
    timsp8
    NY
    I don’t think it is. It could be the backlight itself or the controller. But before you spend money, see if anyone has other opinions. It could be something else.
    https://en.m.wikipedia.org/wiki/Backlight
  8. Nov 12, 2020 at 7:35 AM
    USMC7051
    Thanks for the info. It doesn't look repairable unfortunately
  9. Nov 12, 2020 at 7:54 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Look thru these and you may find a solution..
    https://www.google.com/search?q=ent...ome..69i57.10753j0j1&sourceid=chrome&ie=UTF-8
    One guy said his SD card was bad and it caused this error.
    Make sure you don't have anything plugged into the USB or AUX port and restart.
    Another said if you hold down the AUDIO button, the unit will reset.
    I remember when I had the Entune there was a dark screen setting and you had to touch the screen in a certain place to get it back on.
    I just don't remember where you had to touch it..
    If you don't get it fixed, it's time for an after market HU and a Maestro for the steering wheel controls.
    Way better than the Entune anyway.
  10. Nov 12, 2020 at 8:34 AM
    USMC7051
    I'm going to try a few things that you suggested. Hopefully one of them works. If not, Looks like I will purchasing a new HU. Any, not crazy expensive, units you can suggest?
  11. Nov 14, 2020 at 12:27 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    What is your budget and what options are you looking for in a new H/U?
  12. Nov 18, 2020 at 12:20 PM
    13 tundra 5.7
    13 tundra 5.7 New Member
    2013 Black Tundra SR5
    mine just started doing that, the radio still works only controllable thru the steering wheel now, screen is black and the buttons on the radio do not function. i not sure its the back light burned out as mine comes back on after driving a while.
  13. Nov 18, 2020 at 2:18 PM
    ezdog
    ezdog New Member
    Gateway To The West
    What year radio is this?
    I have one out of a 2015 that might work but we need more details to be able to help?
  14. Nov 19, 2020 at 8:58 AM
    Wweeks
    Wweeks New Member
    I recently pulled the JBL out of my 2014 1794 Tundra to install a pioneer HU. It’s in perfect working condition. I could ship it to you. I’m not sure what a fair price would be, so if you are interested, make me an offer.
    Wyatt
