Is anyone running an active audio system?
Discussion in 'Audio & Video' started by jwatt, Feb 17, 2021.
  1. Feb 17, 2021 at 1:43 AM
    jwatt
    jwatt [OP] I heart men
    Jack
    Oregon
    I need to replace front door speakers cause one got fried from rain water, so I m seriously considering doing an active setup. My thought is to use a 4ch amp to run 4 channels in front, (2 mids, and 2 tweeters). I assume gain setting on a 4 ch amp applies to all 4 channels, so Im just not certain the gain for mids will be appropriate for the tweeters. I will be using a sound processor, so I can properly adjust frequencies for tweeters. My only concern is the power of the 4 ch amp hitting the tweeters. It seems like tweeters should be ran off a seperate 2 ch amp of lesser power. I d appreciate any advise in this matter.
  2. Feb 17, 2021 at 4:11 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Your amp should have separate gain control for front and rear channels. If it does not, it’s probably not worth using it for anything sound quality related.
    1lowlife and Saltyhero13 like this.
  3. Feb 17, 2021 at 5:55 AM
    jwatt
    Jack
    Oregon
    Maybe my intent isnt obvious to you, but a rear channel is not even part of my scenerio. Do you know what an active system is?
  4. Feb 17, 2021 at 5:57 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Do you mean an actively controlled Active DSP System?
  5. Feb 17, 2021 at 6:28 AM
    jwatt
    Jack
    Oregon
    What? WTF does that question even mean?
  6. Feb 17, 2021 at 6:56 AM
    ezdog
    ezdog New Member
    Gateway To The West
    It means exactly WTF it asks,what do you mean exactly by "Active"?
    What I am thinking you mean is that a DSP in one of the system components actively manages the Amp channel levels and steering by listening to the interior with a Microphone inside the cab and making adjustments actively on the fly to the speaker output to compensate for noise inside the truck..
    The only other thing that "Active" can really mean is that the speakers are powered by amplifiers which every speaker anywhere has to be in any system where you can actually hear sound from the speakers.
    So this may be what you mean?
    https://www.caraudioinc.com/going-active
    An active crossover vs a passive crossover system,not the way we might talk about this in the pro audio world that I am in.
    You would also need to have dedicated speaker components for each crossover band to make it worthwhile usually so dedicated Low,Mid and High frequency speakers to be crossed over to.
    Of course people use systems like this and the crossover should have level controls for each output and likewise so should any amp worth the money.
    saybng, Darkness and TRDFerguson like this.
  7. Feb 17, 2021 at 7:00 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    I would say it depends on the tweeters. These are:
    • Sensitivity : 90 dB
    • Frequency Response : 5000-25000 Hz
    • RMS Power Range : 80 Watts
    • Peak Power Handling : 160 Watts
  8. Feb 17, 2021 at 7:32 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
  9. Feb 17, 2021 at 7:35 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Some of the folks in this thread really need to chill out.
    saybng likes this.
  10. Feb 17, 2021 at 8:20 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You can run a 4 channel without connecting to the rear input on the amp?
    You are going to use front and rear channels on the amp, they should have separate gain for each.
    1lowlife likes this.
  11. Feb 17, 2021 at 8:37 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I was just trying to help really.
  12. Feb 17, 2021 at 10:33 AM
    kyle112006
    kyle112006 New Member
    Kyle
    LOL not sure what his problem is.....you were generally trying to help out and he was the one decided to be a smart ass. I knew what you meant and i wasnt even apart of the conversation lol
    Kung and aparker813 like this.
  13. Feb 17, 2021 at 12:08 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I tried running active back in the days of trying to make the stock Entune HU work with an Audiocontrol LC6i LCI using a PDX V9 amp.
    Ran my Focal PS 165FX bi-amped through the Focal crossover on 4 channels.
    Even tried bypassing the Focal passive crossover and ran the components straight from the amp using the amp crossovers.
    Really didn't sound any better than running them off 1/2 channels with the Focal passive crossover.
    I never used a DSP on that setup.
    Only DSP I ever tried was a JBL MS-8 and it was an epic fail.
    After that I only bought aftermarket HUs.
    Every HU I've bought has the option of 2 way or 3 way speaker setup on the initial settings.
    I don't know much about DSPs, I wouldn't have time or patience to tune one..
    As others stated, it seems it would be better to have a 4 channel amp with separate 1/2 and 3/4 channel gains to go active.
    My Alpine PDX V9 1/2 channel high pass crossover is X10 settable to use with a high frequencies but I guess your DSP will handle that.
    It would be nice to have separate gains to give you more control of your tuning between mids and highs, unless your DSP will do that.
  14. Feb 17, 2021 at 3:04 PM
    Danman34
    Danman34 New Member
    Danny
    Lol. Yes. Very familiar. Are you even familiar with a 4 channel amp? You must not since you don’t even know what your amp has......
  15. Feb 17, 2021 at 6:22 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Let’s all grab a beer and chill.:hattip:
  16. Feb 17, 2021 at 6:42 PM
    jwatt
    Jack
    Oregon
    I got hammered yesterday. I only rememeber making the initial comment. I meant no dis respect, and I m sorry if I offended anyone.
    Darkness likes this.
  17. Feb 17, 2021 at 7:38 PM
    crewmaxlmt
    scott
    Things tend to get heated every now and then but the members on this forum are great about getting back to normal quicker than most. This last weekend was a bit tough on all of us in the PNW as well as some areas in the south.
  18. Feb 17, 2021 at 8:48 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I'm running 3 way active in the front, 2 way passive in the rear and 2 subs. Powered by 2 5ch amps.
    It sounds amazing.
    Just put your tweeters on the front channel and the midbass on the rear channel
  19. Feb 19, 2021 at 10:44 AM
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    2018 White SR5 5.7 4x4 TSS Tundra
    For your sceneario you would get a 4ch or 6ch amp. Two channels for the front drivers, two channels for the front tweeters, and if you choose a 6ch amp, two for the rear. The 6ch would be the way to go IMO unless you're not even going to run rear door speakers. You can split the RCAs to double them up for the inputs. Each set of channels should have it's own gain setting. Should be pretty simple but you'll have to run new power/ground wire for the amp and get some wire harness adapters to hook into the stock speaker wire if you're not running new wires.
  20. Feb 20, 2021 at 8:59 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    See thread in my signature.
