Intermittent horn
Discussion in '2nd Gen Tundras (2007-2013)' started by jmckmb, Mar 1, 2021.
  1. Mar 1, 2021 at 8:57 AM
    jmckmb
    jmckmb [OP] New Member
    2013 Pyrite Mica Tundra TSS
    Anyone have any ideas on what would be causing intermittent horn issues on my 2013? I thought maybe it was a loose fuse, but I replaced/verified fuse connection as good. I can adjust the steering wheel adjustment lock and sometimes it will work and sometimes not.
  2. Mar 1, 2021 at 9:07 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Search " clock switch".
    That should get you there.
    Mine's been broken/ no horn for some time.
  3. Mar 1, 2021 at 10:35 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Did you check if the connector on the horn itself is secure?
  4. Mar 1, 2021 at 10:42 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Clock Spring might be where you want to start searching.
