Installing Noico and Killmat in my doors of crew. Need advice.
Discussion in 'Audio & Video' started by SiberianTundra, Nov 14, 2019.
  1. Nov 14, 2019 at 1:39 PM
    SiberianTundra
    SiberianTundra [OP] I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    Hi All,
    Installing sound material in my 2018 Crewmax SR5
    I just got a box of 50 mil 50 sqft of killmat
    https://www.amazon.com/gp/product/B0751G6TMV
    also
    Noico 150 mil 36 sqft
    https://www.amazon.com/gp/product/B07TKXMPH7/
    Saw a few folks installing both on this forum but cant seem to find threat with install pictures. Looking to install on and in the doors.
    edit:
    Installed rear doors.
    Front doors coming up next weekend!
  2. Nov 14, 2019 at 1:50 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
  3. Nov 14, 2019 at 3:51 PM
    SiberianTundra
    Greg
    War Machine
    Pinay and Trooper2[QUOTED] like this.
  4. Nov 14, 2019 at 5:23 PM
    longcat
    longcat New Member
    Jon
    DFW / Texas
    2019 Cavalry Blue Tundra CrewMax
    I just put that Red Noico 150 on top of some Noico 80 on my back wall. That stuff is awesome, and a box of it goes a long way.
    SiberianTundra[OP] likes this.
  5. Nov 14, 2019 at 6:37 PM
    EAK
    EAK New Member
    KY
    ‘15 White 1794
    BAMuffler 8” SS Bilstein 6112/5160 Icon UCAs
    Thanks for posting. I’m about to tackle this as well.
  6. Nov 14, 2019 at 6:37 PM
    SiberianTundra
    Greg
    War Machine
    what about the front wall or the opening ?
  7. Nov 14, 2019 at 7:06 PM
    longcat
    longcat New Member
    Jon
    DFW / Texas
    Sorry I was referring to the back wall of the cab. for the doors I just did the inside wall with a layer of 80 where I could get my roller and then measured and cut the 150 to fit on top and just pressed it down by hand. The back of the foam is sticky and I just pushed it down flat with my hand on top of the 80. For the inside panel I just did a layer of 80 over the whole door, under the part the interior panel goes over. Doors are solid now and damn heavy. I still need to do the floor and then the roof but those are weekend projects that I'll eventually get around to...
  8. Nov 14, 2019 at 9:00 PM
    SiberianTundra
    Greg
    War Machine
    I never realized that both KillMat and Noico is made in Russian Federation
  9. Nov 14, 2019 at 9:09 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    FWIW - a good shear and some gloves will make your life better during the install. I can't believe how many little cuts I got when installing and I work with sheet metal everyday...:thumbsup:
  10. Nov 14, 2019 at 11:08 PM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    Checkout the tundra installs on YouTube under Rob *********. Very detailed install of sound proofing. Might give you some tips and tricks to make things easier. I've got the noico sitting in storage on standby.
    SiberianTundra[OP] and Pbear1454 like this.
  11. Nov 15, 2019 at 12:10 PM
    SiberianTundra
    Greg
    War Machine
    I actually did see those videos.
  12. Nov 15, 2019 at 1:05 PM
    SiberianTundra
    Greg
    War Machine
    Yes I got a leather cutting wheel that will be used to slice through this. Also got good gloves for the job.
  13. Nov 16, 2019 at 9:22 PM
    SiberianTundra
    Greg
    War Machine
    Ok Installed rear doors for now. Took 4 hours to do it right. Day and night difference! Next front doors. Saving for next weekend.
    After that rear seat and follow up with a 70% front window ceramic tint. This should keep car from heating up in the sun.
    Not sure if I need to do the headliner. But might consider it. We shall see
    Great results so far!
    BakNBlk2014 likes this.
  14. Nov 16, 2019 at 10:15 PM
    BakNBlk2014
    Donald
    Virginia Beach VA
    Post up some "What I learned installing" info when you're finished. I have the products just need the time and a decent temperature to install.
  15. Nov 17, 2019 at 9:52 AM
    SiberianTundra
    Greg
    War Machine
    Well just on rear doors my hands are torn up.
    I wore gloves and used a roller.
    You don't need to plaster the whole outside skin of the door too much.
    Just where the holes are and where metal is thin.
    The way this material works is to stop the reverberation from resinating.
    I used 4 sheets of KillerMat 50mil on inside of the door and 4 on the outside with only 2 sheets of the Noico 150mil per inside of the door.
    Left over material will be applied to all doors.
    Starting carefully. I don't want to over use the material. Most videos on youtube over do it with skinning the whole door. My take on that is that it is not how sound deadening works.
    Use tapping the metal technic. Tap and listen if it sounds dull your ok if it gives out hollow metallic drum sound cover it.
    Over all I am pleased. Also my stereo sounds so much better. I have an upgraded system with OEM head unit. You can see it here ( https://www.tundras.com/threads/2017-tundra-sr5-sound-system-upgrade-proposed.21657/page-3 )
    Pictures are coming soon. Next weekend front doors.
    Most likely I will purchase more material for roof. Not sure if I need rear seat done.
    BakNBlk2014[QUOTED] likes this.
