Installing AMP bed step on 2020?
Discussion in '2.5 Gen Tundras (2014-2021)' started by DIYDad, Apr 16, 2020.
  1. Apr 16, 2020 at 11:48 AM
    DIYDad
    DIYDad [OP] New Member
    2020 Tundra 1794
    Anyone install an AMP bed step on a 2020 CM?
    https://www.amp-research.com/amp-research-75309-01a-bedstep-rear-bumper-access
    From what I can tell, the unit includes parts that may have been necessary for earlier tundras, but may NOT be necessary for more recent trucks.
    It's been raining every time I had time to crawl under the truck, so I appreciate any tips from existing owners.
    Thanks
  2. Apr 16, 2020 at 6:54 PM
    CH1NO
    CH1NO New Member
    TEXAS
    2016 SR5 CM
    https://youtu.be/2FKkYTwjKtQ
    Here's a video showing the installation of the AMP bed step. I don't have one my self but looking into it, I might get one... Looks really helpful!
  3. Apr 17, 2020 at 6:05 AM
    DIYDad
    2020 Tundra 1794
    Thanks, that is helpful even if it is not on a Tundra.
    I'm still not clear on the point of removing one steel bracket and replacing it with one that looks so similar....
    I'll call tech support - there is snow in the forecast again tomorrow!
  4. Apr 24, 2020 at 10:56 AM
    Steel825
    Steel825 New Member
    2013 tundra gray rock warrior edition
  5. Apr 24, 2020 at 2:11 PM
    DIYDad
    2020 Tundra 1794
    I have not had time to get back to it. It's been raining or snowing! whenever I haven't been working.
  6. Apr 24, 2020 at 2:32 PM
    cquilichini
    cquilichini New Member
    I installed mine and definitely you need to remove the inside metal bracket and replace it with the one in the kit. It was a PITA to install.
    bjp likes this.
  7. Apr 24, 2020 at 2:33 PM
    DIYDad
    2020 Tundra 1794
    What year is your ride? was the bracket you removed plastic or steel?
    Thanks,
    -Dan
  8. Apr 24, 2020 at 2:55 PM
    cquilichini
    My Tundra is a 2019 DC with the new bumper, I had to remove the drivers side inside metal bracket. I had to call the factory to clarify some doubts, I found the instructions not to be very clear as with all instruction from AMP.
    I ordered the 75309-01A P/N.
    Beesta likes this.
  9. Apr 25, 2020 at 2:33 PM
    DIYDad
    2020 Tundra 1794
    Yep! it was a PITA to install!!!
    I did get it done, but it took a lot longer than I thought - several hours.
    Looks good now and is easy to use. I hope it holds up, and I hope I never get rear-ended, I don't want to do this again.
  10. Apr 25, 2020 at 2:47 PM
    70fj4045
    70fj4045 New Member
    Carl
    Connecticut
    2019 White Trunda TRD PRO
    Driver side grab handle, AMP Power steps, Front window tints, TRD Front & Rear Sway Bars, rear bumper step,TruXedo Tonneau cover.
    I installed one on my 2019 crew cab pro, took 30 minutes, i did not use the metal bracket that came with the kit, used my cutoff wheel matched up the new bracket , made three little cuts on the old bracket touched up the paint and done, works great.
    Jtundra81 and texasrho83 like this.
  11. Apr 25, 2020 at 3:02 PM
    cquilichini
    I'm glad it worked out well for you. I kinda use the bed more now that i have it.
  12. Apr 25, 2020 at 10:31 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Yep, only way to do it.
  13. Apr 27, 2020 at 6:57 AM
    DIYDad
    2020 Tundra 1794
    I started to consider that about halfway into the job. By then, I was pretty much committed, but it's a not a bad idea!
  14. Apr 27, 2020 at 4:32 PM
    Flytrap50
    Flytrap50 New Member
    2019 Toyota Tundra TRD PRO Voodoo Blue
    Agreed. The instructions were clear as mud and it was a pain in the ass to install.
    I wasn't able to get a torque wrench in there to tighten one of the bolts.
    I just tightened it as much as I could with a small wrench that fit in there.
  15. Apr 28, 2020 at 5:44 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Doesn't Toyota make one? The AMP one seems kind of fragile.
  16. Apr 28, 2020 at 6:11 AM
    co2owen
    co2owen New Member
    VA
    2020 Cement Limited CM TRD Off-Road
    Trans Cooler. 5100's up front at mid-setting. ESP Plastic Storage.
    I'm looking into this mod so this is good information to have!
  17. Apr 28, 2020 at 7:55 AM
    DIYDad
    2020 Tundra 1794
    The Toyota one is made by Amp. Mine had Amp instructions and a Toyota PN on the box.
    co2owen likes this.
  18. Apr 28, 2020 at 2:27 PM
    70fj4045
    70fj4045 New Member
    Carl
    Connecticut
    yes it is made by Amp, I purchased mine from a vendor here, Sparks Toyota, they had a good price and quick shipping, good people.....
  19. Apr 28, 2020 at 2:49 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
  20. Apr 28, 2020 at 3:31 PM
    cquilichini
  21. Nov 2, 2021 at 3:43 PM
    BhamDadTundra
    BhamDadTundra New Member
    2021 MGM Tundra CM SR5
    Could someone post a close up of where this bar attaches? I did the hack like you where I left the OEM support bracket and cut off the corner to make room for this, and this piece isn’tlining up how I thought it would.
    diablodalton likes this.
  22. Nov 2, 2021 at 4:18 PM
    bjp
    bjp Hello, kitty……
    Ben
    White ‘21 Double-cab Tundra SR5 w/TRD off-road
    GoFast Camper, TRD skid plate, Valhalla cat plates, LT265/70r18 Nokian Rotiivas, buncha shit under the seat, you know how it is
    The AMP instructions are absolute shit. I put this on my ‘21 over the weekend and spent more time figuring out what steps were missing than I did actually working.
    As far as that arm, I put it over that bolt just above your yellow circle, where the bottom of bed attaches to underlying steel. That bolt is long enough that I am going to try and find a nut to secure the arm to the bolt (bolt screws into an integral bolt, so can’t just screw it off and stack the arm like I would prefer). So far so good without it actually being secured, but I don’t wanna push my luck.
    The step is awesome. The AMP instructions are truly awful.
  23. Nov 2, 2021 at 6:35 PM
    BhamDadTundra
    Thanks man! I had to loosen the bolt that it said “don’t torque.” I didn’t torque but definitely tightened it down but left it where that bar could swing just not enough apparently. Once I got it loose enough I was able to put it where it’s supposed to go and clamp it down with one of the nuts they included. Posting pictures in case it helps anyone else in the future! BTW cutting the OEM bracket was so worth it very glad I did it. Just used my sawzall took it nice and easy. Painted the cuts after this picture.
    edit: I didn’t think the instructions were completely awful especially after installing the rough country DS2 where the instructions basically were *parts list* “bolt on drivers side. Repeat passenger side” haha. But it definitely didn’t show a great picture on step ten. Always room for improvement haha.
    Mike59 and diablodalton like this.
  24. Nov 7, 2021 at 6:44 PM
    diablodalton
    diablodalton New Member
    Dalton
    Oregon
    2021 Crewmax Platinum MGM
    8" Ready Lift, SPC UCA's., Bilstein B8 8125, Amp Steps, 37/12.5R 20 Cooper STT PRO, On order: Valhalla Armor, Dirty Deeds Exhaust
    I did but my step opens from the side not rear. I used all of my parts btw.
  25. Jan 14, 2023 at 7:50 AM
    DJC
    DJC New Member
    2020 double cab
    I think you have to take the old bracket out to make room for the linkage and the swing arm that acts as a brace for the linkage. I am almost done with mine. I have to break those bolts loose from the frame that help support the bumper. Does anyone know the easiest way to do that? Those bolts are factory installed and seem pretty hard to loosen up.
  26. Jan 14, 2023 at 8:00 AM
    CMikeB
    CMikeB New Member
    There's another option besides the "OEM:rolleyes:" Amp Research step. Bestop Bed Step has a larger 'footprint' and better anti-slipping resistance.Functions the same and US made. I've had one on my truck for 11 years.
  27. Jan 14, 2023 at 12:49 PM
    seydou
    seydou Distinguished Member
    This is incorrect. All you have to do is cut the old bracket.
  28. Jan 14, 2023 at 12:53 PM
    seydou
    It's a cleaner install, in a place that you can't see, does not affect the strength of the unit and is a much greater PITA to install. Seems like the only reason to do it that way is to satisfy one's OCD.
  29. Jan 15, 2023 at 10:00 AM
    LR_PRO_PHD
    LR_PRO_PHD New Member
    Phil
    Long Island
    Soon to be ‘21 LUNAR ROCK PRO CREWMAX
    Definitely cut the existing bracket…..installing the provided bracket makes zero sense
