Installing air intake...
Discussion in 'Performance and Tuning' started by atlpinoy08, Apr 9, 2019.
  1. Apr 9, 2019 at 4:18 AM
    atlpinoy08
    atlpinoy08 [OP] Everything happens for a reason
    Rob
    Land of ATL
    2016 Gray SR5 TRD 4x4 5.7liter Tundra
    Quick question... it requires me to remove the negative side of the battery..... will this mess up my remote starter in any way? Thanks for the help guys!
    Rica25 likes this.
  2. Apr 9, 2019 at 5:12 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
  3. Apr 9, 2019 at 5:48 AM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    You should get in the habit of removing battery cable before doing any maintenance on any vehicle now a days! Theres a lot of expensive computerized pieces you could muck up in a flash ( no pun intended) if you accidently ground something.
  4. Apr 9, 2019 at 6:21 AM
    atlpinoy08
    Rob
    Land of ATL
    Thanks for the response guys! I usually remove the negative terminal whenever I usually install something electrical. I just didn’t know if it would mess with my remote starter in any way. Thanks for the responses!
