INSTALLED LED REVERSE LIGHTS AND DOESNT WORK NOW
Discussion in '2.5 Gen Tundras (2014-2021)' started by abraham, Oct 25, 2016.
  1. Oct 25, 2016 at 1:25 PM
    abraham
    abraham [OP] New Member
    ABRAHAM
    2014 toyota tundra
    led lights, wheels, lift, tires, sound system, underbody lights
    I installed led reverse lights and when I put the car in reverse to check them it worked and then installed the other and I believe a fuse was blown because reverse lights don't work as well as the backup camera. Can anyone help me figure out which fuse was blown...
  2. Oct 25, 2016 at 1:28 PM
    TheBeast The Beach
    yep..those LEDs install can be tricky..did you disconnect battery before install ? same happened to me last week end trying to install interior LED.
    Law323 likes this.
  3. Oct 25, 2016 at 1:29 PM
    abraham
    ABRAHAM
    2014 toyota tundra
    thanks for the reply. no I didn't disconnect battery...but im trying to figure out which fuse it was so I can fix it
  4. Oct 25, 2016 at 1:31 PM
    TheBeast The Beach
    yeah just have to find fuse. It's probably on the same circuit. did you check the fuse box in the engine bay ?it has diagram and names on the cover
  5. Oct 25, 2016 at 1:33 PM
    abraham
    ABRAHAM
    2014 toyota tundra
    there are 2 fuse boxes one in the floor beside driver feet and in the engine. just trying to find out which fuse it is or do I have to check everyone until I find a blown one?
  6. Oct 25, 2016 at 1:38 PM
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    LED bulbs can be put in backwards, did you try flipping them around in the socket?
    NewImprovedRon, rons23 and Law323 like this.
  7. Oct 25, 2016 at 1:40 PM
    abraham
    ABRAHAM
    2014 toyota tundra
    yes I flipped it then it flashed like it was the right way then both went out...I already had one installed. then also the backup camera stopped working and the PRND dash as well. im guessing it was a fuse that was blown but wanting to know which fuse it was so I can replace it
  8. Oct 25, 2016 at 1:41 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    That's odd, I didn't have any trouble doing LEDs and I didn't disconnect the battery. Like mentioned above, they do have to go a certain way, so flip them if they dont work. Not sure why your backup camera wouldn't be working though. Maybe it did burn a fuse. Should have a diagram in the manual, and on underneath of the case near the engine. Just pull each one until you find it.
  9. Oct 25, 2016 at 1:43 PM
    abraham
    ABRAHAM
    2014 toyota tundra
    I installed all my interior lights, cargo lights and license plate lights with no issue, when I did the reverse lights it gave me a problem and I think it blew a fuse but idk which one. sounds like I need to check for possible ones that could have blown but just trying to find out if it happened to anyone else or if anyone would know which ones to check because theres a bunch.
  10. Oct 25, 2016 at 1:53 PM
    TheBeast The Beach
    sounds like a blown fuse
  11. Oct 25, 2016 at 1:55 PM
    ToyotaTundraMike
    2015 Tundra
    There is a fuse diagram underneath the lid of each fusebox.
    SouthBoundSteve and Law323 like this.
  12. Oct 25, 2016 at 2:05 PM
    abraham
    ABRAHAM
    2014 toyota tundra
    I saw that but there are none listed for any of those options. I saw one that said BK/UP...would that be it?
  13. Oct 25, 2016 at 2:09 PM
    TheBeast The Beach
    check the fuse then see if it's broken.
    SouthBoundSteve likes this.
  14. Oct 25, 2016 at 2:12 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yeah bk/up is backup, and under the hood is reverse lights.
  15. Oct 25, 2016 at 2:15 PM
    abraham
    ABRAHAM
    2014 toyota tundra
    thank you for your help. I will check it when I get off work tonight. do you know which one is reverse lights?
    Law323 likes this.
  16. Oct 25, 2016 at 2:22 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Take the lid off the box directly in front of the battery, they have a diagram that tells you which one it is.
    If it's not in there, try BKUP/LP BKUP/tow or tail fuses in the cab fuse box.
    I have a 2nd gen so I'm not sure if it's different or not in the 3rd gen setup. I don't see why it would be, but then again I'm not an electricial engineer LOL
  17. Oct 25, 2016 at 2:24 PM
    abraham
    ABRAHAM
    2014 toyota tundra
    alright I appreciate all the help. when I get off work I will check them...hopefully it works!
    Law323 likes this.
  18. Oct 25, 2016 at 2:28 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    No problem Abe. If that isn't the case, I'm sure there are plenty of guys on here that can offer some insight or a solution.
  19. Oct 25, 2016 at 2:40 PM
    TheBeast The Beach
    yes the DOME one is for interior, dashboard and DRL ( for gen 2)..how do I know? ..LOL
  20. Oct 25, 2016 at 2:44 PM
    abraham
    ABRAHAM
    2014 toyota tundra
    I need reverse lights not interior...
  21. Oct 25, 2016 at 2:44 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  22. Oct 25, 2016 at 2:48 PM
    abraham
    ABRAHAM
    2014 toyota tundra
    only one I see it would be is the BK/UP LP on the interior fuse box
