Installed Kleinn train horn kit TUN-734
Discussion in '2.5 Gen Tundras (2014-2021)' started by Timlindz, Apr 3, 2019.
  1. Apr 3, 2019 at 7:04 PM
    Timlindz
    Timlindz [OP] New Member
    2018 Tundra Limited double cab AKA BIGBLUE
    Amp research power steps and rear bed step, 12 volt solutions remote starter. Klien TUN-734 train horn with pro blaster upgrade and sniper remote, Gator trax electric Tonneau cover
    I got picked for the Kleinn Tundra pretester so I was excited to install this direct bolt on TUN-734 train horn kit and it is loud. the install took about 5 hours and everything fit as planned. it all mounted in front of the rear axle on the cross member it is a lot to tuck in there but it does fit I placed the horn button and the compressor on/off button on the center arm rest and that worked out great it is right at the finger tips ready to blow at anytime. they also offer a remote control to blow the horns while away from the truck it is called the sniper. 20190327_195255.jpg 20190327_194730.jpg 20190327_195141.jpg 20190327_200152.jpg
    Darkness, mlucas555, Les7311 and 7 others like this.
  2. Apr 3, 2019 at 7:07 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Why would you need that?
    Scpringle likes this.
  3. Apr 3, 2019 at 7:24 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    To get other drivers off their phones!
  4. Apr 3, 2019 at 7:26 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Fixed that for ya.
  5. Apr 3, 2019 at 7:27 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Thanks
  6. Apr 3, 2019 at 7:32 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    So he can blow his own horn. Duh!
  7. Apr 3, 2019 at 7:36 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    I was thinking it would be great to blow the horn just as someone is taking a sip of their morning McD's coffee on their way to work........
  8. Apr 3, 2019 at 7:43 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Congrats me too. Only issue was I have dual TRD exhaust so only other option was to remove my spare tire. Worked
    Out great plenty of room and remote line just mounted exit passenger rear tail pipe
    Les7311 and Timlindz[OP] like this.
  9. Apr 3, 2019 at 7:55 PM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
  10. Apr 3, 2019 at 8:07 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Damn that just brutal. I’m saving it for bad drivers
  11. Apr 4, 2019 at 8:20 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Just curios why these are wired with a separate switch instead of using a relay off the OEM horn. I'm assuming these are incredibly loud. I've been looking at some of the smaller 150dB versions with built in compressor, but none really have great reviews..... or are not $400+.
  12. Apr 4, 2019 at 8:30 AM
    GMGood
    GMGood New Member
    2017 SC CM PRO
    SC, TRD Dual Exhaust, AFE drop in, Upgraded intercooler.
    Well if you ever go the air locker route and have a train horn some of the pricier kits might be worth the extra $.
  13. Apr 4, 2019 at 8:55 AM
    Trooper2
    JR
    Probably more amps required for compressor and solenoid valves.
  14. Apr 12, 2019 at 9:00 AM
    Baoser
    Baoser New Member
    Bao
    2016 Lifted Tundra Ltd Crew Max
    XD Wheels, 4" lift, All new speakers except center channel, T1000 and T400 amps, infinity doors and dash. JL subs. NSV knight rider light bar, LED heat lights, fog lights and interior lights.
    Timlindz,
    I'm interested in adding this to my 2016. Did you get the blast master upgrade? My truck is lifted but I don't really want to take out my spare tire. In case of emergency, I would still like to at least hobble to a tire shop. Does this all fit pretty well without taking out the spare? Any tips and tricks I need to know about? Any drawbacks to having this horn? Your install looks great.
  15. Apr 13, 2019 at 7:01 AM
    Fishinstud
    Fishinstud New Member
    San Antonio, Texas
    2016 TSS Off Road 4x4
    Oh poop! Driver's handle Lock'er Down Console Safe BAMUFFLER standard 6” stainless steel exhaust
    Nice...I wonder how many car alarms you can set off with that thing?
    :yes:
  16. Apr 13, 2019 at 7:23 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    I have been looking into this very thing
    Mama says “no”.
    This may have to be a stealth install.
  17. Apr 13, 2019 at 8:03 AM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I want one too, but at that price, it’s well down the priority list....next to the NSV light bar :(
    831Tun and texasrho83 like this.
  18. Apr 15, 2019 at 11:36 AM
    Baoser
    Baoser New Member
    Bao
    Deedubb,
    Make sure you really want that NSV light bar. I've had 2 warning tickets as Arkansas does not permit any running lights that wasn't factory on the vehicle. The day time running lights are bright as hell (even in the day time) and hat turned heads. Unfortunately some police ones. The day time running lights do dim in the evening but I still get pissed off drivers flashing me. I've found that if I drive with the parking lights on, it fools the Light Bar to dimming to night time settings. Also, the light bar gives you a new face where your aux is now. Looks nice and works great. Problem is you can't move to the tesla style head unit if you make this purchase. I've called Jansen who sold this to me and we talked at length at finding some way to turn these day time running lights off but I think the only way to do that is to put a toggle switch on the power line. Meaning you'll have to have 2 switches to operate. One for power and then 1/3 light options on the bar. I still love having it. Love showing it off when most other tundras in my city have some sort of bs rigged led light. Hopefully you can get an upgraded light bar from NSV that has the option of turning off the day time running lights when not in use. Good luck
    Kaloza87 and deedubb like this.
  19. Apr 15, 2019 at 12:08 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Should I even ask how much?
    TXRailRoadBandit73 likes this.
  20. Apr 16, 2019 at 10:02 AM
    Baoser
    Baoser New Member
    Bao
    I believe the lights cost about $1,000
  21. Apr 16, 2019 at 10:04 AM
    TXRailRoadBandit73 YOTAS,RAILROADER,RÖKnRÖLLN',BEER,MAX/GEMMA
    Baoser likes this.
  22. Apr 16, 2019 at 10:22 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2008 Nautical Blue Tundra SR5 CM 4x4 Beauty
    Toytec Boss coilover, Ray10’s ,Ridge Grapplers,Bilstein 5100,BAM 8”,TRD sway,
    Can you even hear it mounted out the rear of the truck? Peace. D
  23. Apr 16, 2019 at 6:33 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Meant the horn kit.
  24. Apr 17, 2019 at 4:52 AM
    Stig
    Stig New Member
    I wouldn't be able to use that around here. Even a simple small honk to get someone moving at a red>green light could turn into a violent road rage incident quickly.
    I had an aftermarket horn on my previous car that was a bit louder than stock. I had top stop using it because more often than not I thought the other driver wanted to run into me or pull out a gun!
    Darkness and Baoser like this.
  25. Apr 17, 2019 at 5:41 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Am installed and loving it.....
  26. Apr 17, 2019 at 9:26 AM
    Baoser
    Baoser New Member
    Bao
  27. Apr 17, 2019 at 9:41 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    I dont even have train horns on my pete. The 4 up top are good enough
  28. Apr 17, 2019 at 11:35 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Nothing will get the attention of local LEO’s faster than a set of loud train horns...:rofl:nah, I will pass.
    Darkness likes this.
  29. Apr 17, 2019 at 7:10 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I know what you mean but that's why I carry heat as well.
  30. Sep 6, 2019 at 11:03 AM
    Mark18TRD
    Mark18TRD New Member
    Mark
    Cypress TX
    2018 White Tundra TRD
    6" RC lift, 20" Fuels, RC rear bumper w/ lights, RC front bumper light bar, (NSV light bar ordered and on the way)
    i'm currently really in the market for one of these train/air horns! my largest concern is it being mounted under the truck, i do freeway driving and a whole lot of offroad/high water crossings/excessive mud! how would these horns hold up in those conditions? does anyone know of another location to mount besides under the body?
