Installed 2104-17 trd pro grill on 2019
Discussion in '2.5 Gen Tundras (2014-2021)' started by shawn474, May 13, 2020.
  1. May 13, 2020 at 2:34 PM
    shawn474
    shawn474 [OP] Lego connoisseur
    MoCo, Maryland
    C8E8CD04-C21F-4D8B-AA72-1B1613B2AFBE.jpg Thanks to @Roman. I am waiting on the Ajt relocation bracket but decided to just zip tie the sensor to the radiator support for now. Drove for 5 miles with no problems at all. VERY happy with the look and will mount the bracket whenever it arrives.
  2. May 13, 2020 at 4:34 PM
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    Nice. I did the exact same thing about two weeks and I love it.
  3. May 13, 2020 at 4:45 PM
    shawn474
    MoCo, Maryland
    Also got the avs aeroskin deflector; goes with the lines of the hood much better than the other Ones I have had
  4. Jan 18, 2023 at 1:07 PM
    I don't remember if you chimed in on any of the TSS posts lately but did the AJT bracket work out for you? I just picked this grille up today. Any tips on the zip tie process for a temp install? Thanks.
  5. Jan 18, 2023 at 2:15 PM
    shawn474
    MoCo, Maryland
    Nope; was lucky enough to get in on one of the last jomax production runs. The ajt three errors all the time for me unfortunately
  6. Jan 18, 2023 at 2:24 PM
    I'm wondering why the AJT is hit and miss...installation angle maybe?
  7. Jan 18, 2023 at 2:36 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Looks good! While we're on the topic, does anyone know where i can find some replacement plastic tabs that are used on the backend of the TRD pro grill? I had one pop off and I need it replaced.
  8. Jan 18, 2023 at 2:39 PM
    shawn474
    MoCo, Maryland
    I tried many different ways to mount it. There really isn’t any way to install it wrong as it sits right against the existing parts. It’s a quality product but doesn’t work for some. Hit and miss. I even lid Toyota a lot of money to recalibrate the tss after installation (my buddy works at the dealership and allowed the techs to do the calibration on an aftermarket part). I think it has to do with the thickness of the front plate honestly but that was just a guess when I had it.
  9. Jan 18, 2023 at 2:42 PM
    The method that @2020Platinum did on his has worked for many people. The TSS is a strange animal I guess.
    2020Platinum likes this.
  10. Jan 30, 2023 at 5:24 AM
    I have a combined 18 miles or so with the AJT....no issues so far. I have a direct 20 mile drive to work today so we will see how it goes. I'll use radar cruise if traffic allows it. Lane departure is working fine as well.
  11. Jan 30, 2023 at 8:32 AM
    shawn474
    MoCo, Maryland
    Good luck........mine didn't last much longer before it started throwing errors and nothing I could do would fix it (even got it recalibrated at the dealership). I put the jomax on and haven't had an error since. Hopefully the AJT mount continues to work for you - seems to be very hit and miss for many members.
  12. Jan 30, 2023 at 8:50 AM
    So at 35 miles, I got a clean sensor going up the bridge. I take the same route daily so I'll be able to monitor it. I'm going to try a couple of things.....remove the cover and see what happens, or make a cover with thin plexiglass. Isn't the cover on the Jomax a thin sheet metal and it mounts in the same spot as the AJT? I do have a some thin sheet metal at home.
  13. Jan 30, 2023 at 9:23 AM
    shawn474
    MoCo, Maryland
    I actually don’t remember what type of faceplate the jomax has, or if it actually has one. I will try to look today. My bet is you can try anything you want with the ajt and it won’t work. Many on here have tried after getting the error with no luck.
  14. Jan 30, 2023 at 2:48 PM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    I have that same deflector.. provides a nice look along with protecting the front of the hood. I also want that grill you got.. will be my next purchase before some 2018+ LED’s988A3ACC-4923-47B7-BE38-ED38ABC0BA39.jpg
  15. Jan 30, 2023 at 4:28 PM
    shawn474
    MoCo, Maryland
    I ended up taking that deflector off; it was coming up on one end and underneath was getting scratched up
    Tundrastruck91 likes this.
  16. Jan 30, 2023 at 4:33 PM
    SPOirish28
    Ontario, Canada
    2014 SSM SR5 DC
    Yeah this one might end up coming off too. It’s starting to show some age.. I do like the look tho haha
