Inspecting a tundra for sale...
Discussion in '2nd Gen Tundras (2007-2013)' started by Redkaz04, Dec 8, 2019.
  1. Dec 8, 2019 at 4:21 AM
    Redkaz04
    Redkaz04 [OP] New Member
    In the tundra market
    Going to look at an 08 5.7L 4x4 DC tomorrow with 165k on the odometer.
    Any tundra specific things I should check or look for when Inspect the truck?
    water pump seems to be an area of concern that might have more problems in the tundra?
    Anything other typical concerns at this mileage?
  2. Dec 8, 2019 at 5:25 AM
    Good luck with your search.
    Check for
    Cam tower leaks
    Water pump
    Frame
    BlackSheep and GODZILLA like this.
  3. Dec 8, 2019 at 3:30 PM
    avt007
    avt007 New Member
    Rob
    2010 Silver Tundra Double Cab
    Drive it in a straight line in 4HI. Mine is just as quiet in 2wd and 4wd, but others I test drove were loud and whiny.
    Redkaz04[OP] and GODZILLA like this.
  4. Dec 9, 2019 at 4:55 AM
    Redkaz04
    Thanks fellas
  5. Dec 9, 2019 at 10:38 AM
    avt007
    avt007 New Member
    Rob
    Sit and operate every switch, every option, window, seat, lights, interior lights, heater, mirrors, it takes a while but worth it.
  6. Dec 9, 2019 at 2:21 PM
    Lifeislarge
    Lifeislarge New Member
    2007 Tundra 4X4 TRD 5.7L
    Study all Tundra forums on internet and then start freaking out over what could possibly go wrong and listen for the ghost of things to come (maybe).
  7. Dec 9, 2019 at 2:24 PM
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    Check the four corners around where the bed mounts to the frame for rust, look at the top side and bottom side. Some tundras from 08-12 were known to have the beds rusting from the underside up because of a manufacturing defect. Also rec doing a search for that issue if you are unsure where or what to look for.
  8. Dec 9, 2019 at 3:24 PM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Personally, I would spend the money and have it checked at a Toyota dealer.
    focal likes this.
