ICON S2 Tundra Suspension
Discussion in 'SDHQ Offroad' started by sdhq_offroad, Nov 16, 2016.
  1. Nov 16, 2016 at 10:15 AM
    sdhq_offroad
    sdhq_offroad [OP] New Member Vendor
    GILBERT, AZ
    The ICON Vehicle Dynamics S2 Modular Performance shock system redefines the offroad capability of the Toyota Tundra by enhancing the front suspension with the addition of a secondary shock to an existing ICON coilover setup. A common misconception is that overly-complicated and expensive long-travel kits are to achieve the ultimate in offroad performance. This has been put to rest with the development of the ICON S2 system. The S2 Modular Performance shock system system utilizes the factory lower control arm and maintains OE track width while providing excellent suspension damping capabilities and an exceptional build quality you would expect from any ICON Vehicle Dynamics product. All of these features come at a fraction of the cost of a long-travel setup.
    This bolt-on system was developed to significantly enhance the drivability of the Tundra in extreme offroad conditions while at the same time eliminating the need for any major alteration of the frame or any other factory suspension components. Minor welding required for lower shock mount on the stock lower control arm.
    The modular aspect of this system allows for modifications to the vehicle to be achieved in stages, so the user can build their vehicle as desired rather than all at once. Multiple secondary shock options also provide even more tuneabity of the system as a whole, as ICON 2.5” Remote Reservoir Shocks, 2.5” Remote Reservoir CDC Valve Shocks, or 2.5” Two-Tube Bypasses may be used to attain any level of performance desired.
    ICON Stage 1:
    System Components:
    56109 07–Up Toyota Tundra S2 Shock Hoop Kit
    57722 Toyota S2 Secondary 2.5 VS Reservoir Shocks
    ICON Stage 2:
    System Components:
    57722C Toyota S2 Secondary 2.5 VS CDC Reservoir Shocks
    ICON Stage 3:
    System Components:
    59922 Toyota S2 Secondary 2.5 Omega Bypass Shocks
    All prices and kits are located on our website
    http://store.sdhqoffroad.com/toyotatundraiconcompletesuspensionsystems.aspx
    We are taking preorders on these kits, they are expected to be shipping end of January/early February. We will be getting ICON's first production run.
    Law323 likes this.
  2. Jun 2, 2017 at 7:36 AM
    sdhq_offroad
    GILBERT, AZ
    These kits are on the shelf!
    T-Rex266 and Law323 like this.
  3. Sep 24, 2023 at 7:32 PM
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    Have we found a lower control arm that is compatible?
  4. Sep 24, 2023 at 8:47 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    there are many stock length lower control arms…
    dirtking, chaos fab, lsk all come to mind…
  5. Sep 24, 2023 at 10:41 PM
    NoMoreGreen
    Robert
    2020 Tundra
    Total chaos fab is non compatible apparently.
    I have not checked LSK, I’ll have to do some research on theirs.
  6. Sep 24, 2023 at 11:28 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    says?
  7. Sep 24, 2023 at 11:43 PM
    SAGE63
    San Diego County
    What is the compatibility issue? I have the 3.0 CDCV RR coilovers with the Stage 3 S2 Piggyback , Billet UCA and Stock LCA up front and The RXT Leafs and 2.5 Omega bypass rear20230912_150317.jpg 20220910_135619.jpg
  8. Sep 24, 2023 at 11:48 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    show off! :rofl:
    SAGE63[QUOTED] likes this.
  9. Sep 24, 2023 at 11:56 PM
    SAGE63
    San Diego County
    Trying to compete with @KevinK
    except for the S2s (NEW) the 3.0 coilovers and rear 2.5 Omegas are take-offs from Joon rebuilt by LK and cruzer Leafs. The S2s I had 2 $500 Gift certs from T2S raffle to apply to the purchase.
    KevinK and BiggHertz[QUOTED] like this.
  10. Sep 25, 2023 at 12:34 AM
    NoMoreGreen
    Robert
    2020 Tundra
  11. Sep 25, 2023 at 1:06 AM
    SAGE63
    San Diego County
  12. Sep 25, 2023 at 5:55 AM
    NoMoreGreen
    Robert
    2020 Tundra
  13. Oct 5, 2023 at 10:50 AM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Take a hair of caution of you decide to run the camburg spindles or the Total Chaos spindle gussets. I argued with Zaiden for a while about whether or not Tundras needed reinforced spindles - he said they don’t and I said the do because a bunch of my friends had bent their stock spindles. Eventually he made the Camburg units and they’re great.
    Buuuuuuut, the issue is, I’ve changed my mind. With a stronger spindle, you’re now transmitting the energy that would have bent a spindle and putting it someplace else. The next place that can absorb that much energy is the frame.
    And now I and a bunch of friends have bent frames instead of bent spindles. Spindles are way easier and cheaper to replace than frame straightening.
    So what I’m saying is, choose your points of failure carefully. When the time comes for me to redo the front end, I’m going back to stock non-reinforced spindles.
    n0rth, reywcms, SAGE63 and 1 other person like this.
  14. Oct 5, 2023 at 10:52 AM
    NoMoreGreen
    Robert
    2020 Tundra
    Kevin, thanks for that advice! I am going to knock the spindles off the list.
    KevinK likes this.
  15. Oct 5, 2023 at 11:05 AM
    SAGE63
    San Diego County
    I have been thinking of the Total Chaos gussets. guess I will reconsider. and purchase a backup set of spindles. @KevinK Thanks for the food for thought
    KevinK likes this.
  16. Oct 5, 2023 at 11:08 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Then the snowball effect of frame plating and reinforcement all over.
  17. Oct 5, 2023 at 11:08 AM
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    Sounds like what the guy told me while installing mine. Tried to talk me out of it but it did not work
    NoMoreGreen likes this.
  18. Oct 5, 2023 at 12:00 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Aaaaand that's where experience comes into play. Just a bummer that someone(s) gets to learn the hard way.
  19. Oct 5, 2023 at 2:11 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Still have yours, be more than happy to trade them back if you would like.
    KevinK, SAGE63, reywcms and 1 other person like this.
  20. Oct 5, 2023 at 3:57 PM
    azTony
    Tony
    Sun Lakes, AZ
    Nope, I am good. They have been on for a few years and no bent frame so I am not looking to remove them
    SAGE63 likes this.
  21. Oct 5, 2023 at 7:21 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    must drive harder!
    Vizsla and azTony[QUOTED] like this.
  22. Oct 5, 2023 at 8:29 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Good, but if you change your mind offer stands, wanted to keep them just to look at. Lol. Frame will be fine, spindle gussets are piece of mind and save a little money on less alignments imo., but nobody should buy or not buy based on my opinion. Big heavy ass truck hitting the bump stops too hard bends the frame, if you hit one side hard enough, and the engine weight transfer hits just right, the motor mount breaks. Then the frame folds in like a cheap card table.
    KevinK and SAGE63 like this.
  23. Oct 5, 2023 at 8:36 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I think we know someone on stock spindles that still managed to bend frame… **cough** @BiggHertz **cough**
    KevinK[QUOTED], SAGE63 and Vizsla like this.
  24. Oct 5, 2023 at 8:47 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  25. Oct 9, 2023 at 11:56 AM
    KevinK
    Tundras to Sedona
    Yeah, more bracing creates more weight, which requires more bracing, which creates more weight, which requires more bracing…….
    Learning is fun, kids! Our favorite trips are always the ones where someone breaks and/or gets stuck.
    case in point: yesterday. Blown coilover bottoms rod end in the whoops for one of the leadership guys. We’re swapping coilovers to a set that Jimmy brought up.
    Yep. We need mini cages or engine braces. I know a guy with one. It’s pretty nice. ;)
  26. Oct 9, 2023 at 4:32 PM
    Vizsla
    Vizsla ☠️☠️☠️
    It’s not that bad. Just need to know what needs reinforced, how, and what material. I prefer it vs. pushing the chassis way past its design, also hated how it handled as a giant wet noodle and those awful horrible sounds all of you listen to from tires eating stuff from said wet noodle.:D
    Oh damn Kevin, that coulda been bad not much damage. Zoomed in on the pic of it, was the pocket in the lower not opened up, or not enough?
    I don’t know about that. Fwiw my frame bent on stock knuckles, the knuckles did not. Wanted to share what my truck does to gusseted knuckles, the gussets fatigue and crack random places, but always end up with the big crack in the pic.. Once it turns the corner I don’t weld it up, goes in the scrap pile, figure that’s enough fatigue in the knuckle. Haven’t had any be measurable bent yet, but it’s clear imo the knuckles are trying to push out and back under compression loads.
  27. Oct 10, 2023 at 10:14 PM
    KevinK
    Tundras to Sedona
    Yeah we decided to embrace the wet noodle aspect for our build, although I agree the handling can be adventurous at high speeds. We can’t eat up the whoops at the same speed as the full LT guys, but we get maybe 90% of the speed as long as they’er not too tall.
    Apparently the early ADS coilovers didn’t use 7130 aluminum for the rod ends and aren’t as strong as their newer ones. Matt is sending him a replacement.
    And yeah, we have the same crack at that spot in the gusset. I dunno, maybe now I’m torn since I’ve heard a couple people bend their frames anyway even without spindle gussets. I imagine the bump horn geometry is really the culprit.
    NoMoreGreen, reywcms and TRDFerguson like this.
