Icon rebound wheels
Discussion in '3rd Gen Tundras (2022+)' started by Tbag1118, May 18, 2022.
  1. May 18, 2022 at 6:12 PM
    Tbag1118
    Tbag1118 [OP] New Member
    TJ
    2022 tundra limited crewmax
    Anyone have icon rebound wheels on their 2022 tundra? I see they have a range of off sets. Is that something you can choose or is it set by the wheel diameter?
  2. May 18, 2022 at 7:04 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    someone on the Facebook group has them I remember seeing. You’ll want somewhere from a 35 to a 10 offset, 0 works as well but gets pretty bro stanced.
  3. May 18, 2022 at 7:05 PM
    Tbag1118
    TJ
    Yea I'm trying to avoid a super wide stance. I'd like flush the the flair or just a sneeze of a poke.
  4. May 18, 2022 at 7:09 PM
    DexterL
    DexterL New Member
    Definitely keep it between 25-60 then (depending on tire width).
    I was going to get 35mm offset methods, but I wanted to shave some weight and found some 12mm offsets that weight 21 lbs and were CHEAP, so I went with them. I’ll put on some aftermarket wide mud flaps and call it a day
    Tbag1118[OP] likes this.
