ICON 3.0 Tundra Suspension
Discussion in 'SDHQ Offroad' started by sdhq_offroad, Nov 16, 2016.
  1. Nov 16, 2016 at 10:00 AM
    sdhq_offroad
    sdhq_offroad [OP] New Member Vendor
    GILBERT, AZ
    ICON Vehicle Dynamics Toyota Tundra 3.0 suspension systems are designed with maximum performance and the serious driver in mind. ICON engineers’ primary focus is to increase wheel travel and damping ability, which translates into outstanding vehicle control and ride quality both on and off-road. We wanted give you guys all the information in one location along with somewhere to ask any questions you guys may have.
    ICON Stage 1:
    The Stage 1 system includes vehicle-specific tuned 3.0” coilover shocks featuring a remote reservoir for exceptional cooling properties and includes our CDCV 10 way adjustable compression valve. These coilovers are also height adjustable from 1.63-3” allowing the use of larger, more aggressive wheel and tire combinations. ICON 2.5 VS Piggyback Series rear shocks utilize our CDCV valving that makes your suspension tuneable front and rear. The ICON Vehicle Dynamics 2007 - Up Toyota Tundra Stage 1 3.0 suspension system is an excellent choice for those drivers looking to tune the capabilities of their pickup on the road as well as in the dirt.
    Key Features:
    • Increased wheel travel and ride quality over stock with no change in towing capacity
    • CDC tuned front and rear shocks for a custom tuneable ride
    • Adjustable coilovers from 1.63-3" of lift height
    • 6061 Aircraft grade aluminum CNC machined components
    • Corrosion resistant CAD plated coilover shock body with 7/8 shaft
    • High strength alloy CNC machined lower bar pin
    • FK rod end bearings for extended longevity and minimal deflection
    • 2.5 VS Piggyback Series with 7/8" polished nitro steel shaft and CDC Valve
    • RXT Rear Leaf Pack for 1.5” of lift, increased wheel travel and better ride quality
    • 100% Bolt-on system - no drilling, cutting, or welding necessary for install
    • Made in the USA
    System Components:
    58755 (QTY - 1) - 2007 - Up Toyota Tundra (1.63-3" Lift) 3.0" Remote Reservoir CDC Coilover Shocks
    58560 (QTY – 1) – 2007 – Up Toyota Tundra Uni Ball Billet UCA
    51201 (QTY – 1) – 2007 – Up Toyota Tundra (0-1.5”) Rear RXT Leaf Pack
    57723C (QTY - 2) - 2007 - Up Toyota Tundra (0-1.5" Lift) 2.5 VS Piggyback CDC Series Rear Shock
    ICON Stage 2:
    The Stage 2 system includes vehicle-specific tuned 3.0” coilover shocks featuring a remote reservoir for exceptional cooling properties and includes our CDCV 10 way adjustable compression valve. These coilovers are also height adjustable from 1.63-3” allowing the use of larger, more aggressive wheel and tire combinations. ICON 2.5 VS Piggyback Series rear shocks utilize our CDCV valving that makes your suspension tuneable front and rear. The ICON Vehicle Dynamics 2007 - Up Toyota Tundra Stage 2 3.0 suspension system is an excellent choice for those drivers looking to tune the capabilities of their pickup on the road as well as in the dirt.
    Bolt on a set of ICON Vehicle Dynamics rear hydraulic air bumpstops to improve the on or off road capabilities of your 2007+ Toyota Tundra when using maximum suspension travel. ICON’s race proven hydraulic air bumpstops are tested, tried and true, from Cabo to Canada in all conditions. This vehicle specific tuned hydraulic air bumpstop system offers both smooth engagement, maximum bottom resistance, and smooth controlled return while being used in extreme conditions. The true value to using a compression and rebound tuned bumpstop is the exponentially increasing force is smooth, not abrupt or harsh like the OEM bumpstop.
    System Components:
    56108 (QTY -1) – 2007 – Up Toyota Tundra Rear Air Bump Kit
    ICON Stage 3:
    The Stage 3 system includes vehicle-specific tuned 3.0” coilover shocks featuring a remote reservoir for exceptional cooling properties and includes our CDCV 10 way adjustable compression valve. These coilovers are also height adjustable from 1.63-3” allowing the use of larger, more aggressive wheel and tire combinations. ICON 2.5 Omega Bypasses Remote Reservoir Series rear shocks utilize a vehicle-specific valving with compression and rebound adjustment for a perfectly tuned ride. The ICON Vehicle Dynamics 2007 - Up Toyota Tundra Stage 3 3.0 suspension system is an excellent choice for those drivers looking to tune the capabilities of their pickup on the road as well as in the dirt.
    System Components:
    59923 (QTY - 2) - 2007 - Up Toyota Tundra (0-1.5" Lift) 2.5 VS Omega Series Bypass Rear Shock
    Here is the link to our website with pricing
    http://store.sdhqoffroad.com/toyotatundraiconcompletesuspensionsystems.aspx
    We are taking preorders on these kits, they are expected to be shipping end of January/early February. We will be getting all of ICON's first production run. Prices Billet arms. The tubular option will be added shortly.
    Wvmoonshiner, Viper3G, Law323 and 2 others like this.
  2. Nov 17, 2016 at 11:29 AM
    sdhq_offroad
    GILBERT, AZ
    ICON out there continually testing to get the best valving possible!
    FirstGenTundra likes this.
  3. Nov 17, 2016 at 11:52 AM
    TheBeast The Beach
    very nice. That stage 1 is very tempting...:mudding:
    Law323 likes this.
  4. Nov 17, 2016 at 2:59 PM
    TheBeast The Beach
    are they 3.0 coilovers or 2.5 ?
    stage 1 says "3.0” coilover shocks " but description says "2.5" Remote Reservoir CDC Coilover Shocks "
    sdhq_offroad[OP] likes this.
  5. Nov 17, 2016 at 3:03 PM
    sdhq_offroad
    GILBERT, AZ
    Thanks for catching that. They are 3.0.
  6. Nov 17, 2016 at 3:06 PM
    TheBeast The Beach
    sweet and I assume they are 2 QTY for the coilovers instead of 1 ;)
  7. Nov 17, 2016 at 3:06 PM
    sdhq_offroad
    GILBERT, AZ
    They only sell the coilovers in pairs. So its a QTY of 1 for that part number
    TheBeast[QUOTED] likes this.
  8. Nov 17, 2016 at 3:06 PM
    TheBeast The Beach
    and still 2.5 for rear right ?
  9. Nov 17, 2016 at 4:30 PM
    sdhq_offroad
    GILBERT, AZ
    As of right now, yes. I know they are testing 3.0's but by the sound of it, it wasn't something that was a bolt-in application.
  10. Nov 17, 2016 at 4:36 PM
    jokerftn1018
    jokerftn1018 New Member
    Daniel
    Virginia Beach
    2016 mgm sr5
    @sdhq_offroad I heard from another member that icon is doing something new from sema with there UCA's is this true. I am looking at buying a set of UCA's right now and am stuck between icon, camburg, mcm fab, TC. in your opinion what would you run on a mid travel build without spending over a grand on the billet model.
  11. Nov 17, 2016 at 4:51 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    God those are some sexy coilovers.
    Someday...
    Law323 likes this.
  12. Nov 17, 2016 at 5:23 PM
    Guys in here like
  13. Nov 17, 2016 at 5:29 PM
    CaptTyler
    Tyler
    lol nothing has ever been more true
    trayday and T-Rex266[QUOTED] like this.
  14. Nov 17, 2016 at 5:30 PM
    jokerftn1018
    Daniel
    Virginia Beach
    2016 mgm sr5
    as a single tear hits the floor.
    T-Rex266[QUOTED] likes this.
  15. Nov 18, 2016 at 6:51 AM
    sdhq_offroad
    GILBERT, AZ
    Time for that new zero interest for 21 months Citi Bank card! :rofl:
  16. Nov 18, 2016 at 7:03 AM
    sdhq_offroad
    GILBERT, AZ
    I haven't heard anything of that sort. I will look into it though.
    Personally, I am a fan of the Camburg arms for the price. You get the beefy 1.5" uniball, quality hardware, and you can't beat it being cheaper than the other uppers. I don't do any work with the MCM arms, I have only seen them in photos, never in person. My next option would be ICON, the amount of R&D that they put in to those are crazy! Quality product. We do TC stuff, really nice stuff, but I think a bit over priced for what it is.
    I know there is going to be a ton of arguement over caster as there always is. The caster difference between the arms is very small. If you have a guy who knows how to do alignments correctly, all these arms are completely capable of getting you back within factory alignment specs.
    At the end of the day, it comes down to what color upper arm you want, because they all serve the same purpose and are within a few bucks of each other.
  17. Nov 18, 2016 at 7:21 AM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    Dear santa...
    This year I know I haven't been the best, im quite the shithead... but...
  18. Nov 18, 2016 at 8:00 AM
    jokerftn1018
    Daniel
    Virginia Beach
    2016 mgm sr5
    @sdhq_offroad does the icons having that cap covering the uniball serve any problems with moisture at all because it seems like when i had my camburgs the top of that thing got so disgusting so quick.
  19. Nov 18, 2016 at 8:05 AM
    sdhq_offroad
    GILBERT, AZ
    It keeps all the dust/mud out. The Tubular arms, you can get the cap that 3M adheres to the top of the uniball cup and it seals itself on the top. The billet arms coming with a cap, but I haven't heard of any moisture issues with that.
  20. Nov 18, 2016 at 8:08 AM
    jokerftn1018
    Daniel
    Virginia Beach
    2016 mgm sr5
    Well icon wins
  21. Nov 18, 2016 at 8:11 AM
    jokerftn1018
    Daniel
    Virginia Beach
    2016 mgm sr5
    Anything to promote a cleaner system i am game @sdhq_offroad
  22. Nov 18, 2016 at 9:25 AM
    TheBeast The Beach
    indeed a very nice system, any $$ ball park ?
  23. Nov 18, 2016 at 9:29 AM
    sdhq_offroad
    GILBERT, AZ
  24. Nov 18, 2016 at 9:30 AM
    sdhq_offroad
    GILBERT, AZ
    Sign up for our newsletter on our website as well and keep up to do date on some upcoming "holidays"
    http://sdhqoffroad.com/
  25. Dec 13, 2016 at 3:57 PM
    sdhq_offroad
    GILBERT, AZ
    Coilovers will be shipping mid February.
    Rear suspension is looking it is going to be around Spring before they start shipping out.
  26. Dec 13, 2016 at 7:14 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I'm really interested in those rear leaf springs!
  27. Dec 22, 2016 at 12:57 PM
    sdhq_offroad
    GILBERT, AZ
    ICON just confirmed that coilovers and the rear bump stop kits will be ready to ship out in February!
    CaptTyler likes this.
  28. Jan 7, 2017 at 1:01 PM
    sdhq_offroad
    GILBERT, AZ
    These are getting closer and closer to release! I currently have 2 sets claimed and have 2 more sets up for grabs. We will be receiving the first build of these coilovers from Icon. Throw a deposit down today and lock in your pair!
    These are just the coilovers right now. Rear suspension will be available early spring from what I've been told. I don't know what spring is here in Arizona because we only have hot and cold, no in between. :D
  29. Mar 6, 2017 at 1:08 PM
    sdhq_offroad
    GILBERT, AZ
    Just got word that these are shipping out in a week! I will have these on the shelf ready to go!
    Law323 and T-Rex266 like this.
  30. Mar 6, 2017 at 3:20 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Do you know if there is a difference with the 3.0 from a double versus a crew max? Not for fitment but for overall height
