I need .75” of rear lift.
Discussion in 'Suspension' started by 1999cutiger, Feb 10, 2019.
  1. Feb 10, 2019 at 5:33 PM
    1999cutiger
    1999cutiger [OP] Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    I have Bilstein 5100’s all the way around on my 2017 SR5 Crewmax. To finish it off, I want .75” of rear lift. Coachbuilder has shackles for $285 but my budget won’t cover those right now.
    Any other more cost effective good options out there?
    Thanks in advance for your help.
  2. Feb 10, 2019 at 5:36 PM
    Jrfor0
    Jrfor0 New Member
    James
  3. Feb 10, 2019 at 5:46 PM
    1999cutiger
  4. Feb 10, 2019 at 5:51 PM
    Jrfor0
    Jrfor0 New Member
    James
    They have been on my truck for about 30k miles with no problems. However, I don't know much about the quality compared to other options out there. Each side of the shackle is a single plate instead of a 1-piece or welded shackle that other companies offer. I don't know how that would affect ride quality, other members on here may know better than I. They came with my suspension kit and I saw no reason to change them out at the time.
  5. Feb 10, 2019 at 5:53 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Toytec
  6. Feb 10, 2019 at 6:28 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Bunch of options on Ebay in $100 range, should be just fine. I would get 1" for when the springs start to soften.
  7. Feb 10, 2019 at 7:16 PM
    1999cutiger
  8. Feb 10, 2019 at 7:24 PM
    1999cutiger
    Does anybody know if these TC shackles can be installed with my TRD rear sway bar installed or does the sway bar need to be removed to get these shackles on?
  9. Feb 10, 2019 at 9:37 PM
    NW Elevated
    NW Elevated New Member
    Seattle
    18' 5.7 Superwhite TRD Sport CM
    King 2.5's front & rear, TC shackles, Methods, Toyos
    You’ll need to disconnect the end links during the install.
  10. Feb 10, 2019 at 10:24 PM
    TheBeast The Beach
    they are excellent.
    Total Chaos has great reputation
    @TOTAL CHAOS
  11. Feb 10, 2019 at 11:00 PM
    Jhayxian
    Jhayxian New Member
  12. Feb 11, 2019 at 2:26 AM
    Tundramoney
    Tundramoney Old school
    Earth
    I have a pair of 7/8” blocks if your interested
  13. Feb 11, 2019 at 5:07 AM
    1999cutiger
    Good to know...thanks.
  14. Feb 12, 2019 at 1:08 PM
    TOTAL CHAOS
    TOTAL CHAOS WWW.CHAOSFAB.COM Vendor
    Corona, CA
    We'd love to get a set of TOTAL CHAOS 3/4" Lift Shackles on your Tundra!
    $135.24 (#49704)
    These are laser cut from 3/8" steel and include all necessary hardware for an easy install. Below are the installation instructions for you to get an idea on the install. Don't hesitate to contact us if you have any questions
    Installation Instructions
    info@chaosfab.com | 951-737-9682
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    040Tundra likes this.
  15. Feb 17, 2019 at 6:09 PM
    1999cutiger
    I will probably attempt to install my shackles tomorrow night after work.
    Do I need to apply any grease to the bolts...to reduce binding?
    Any tips for a first-timer? I do have a factory TRD rear sway bar installed...
  16. Feb 17, 2019 at 6:17 PM
    Trooper2
    JR
    YouTube how to is worth a watch.
  17. Apr 22, 2020 at 11:48 PM
    mightyowl
    mightyowl New Member
    How did your install turn out? I am looking to get these too. exactly 0.75" lift?
