I’m a dumb ass that needed a rack and pinion replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by Parker519, Oct 15, 2019.
  1. Oct 15, 2019 at 6:40 PM
    Parker519
    Parker519 [OP] New Member
    Tom
    2008 Toyota Tundra Crew Max 4x4
    I have a 2008 tundra 4x4 with 190,000 miles on it. I was getting my tires replaced when the mechanic showed me my rack was about to fail. They said they could do it for $1300. I went to all the sites to get a idea of how much of a pain it would be to get this done. The rack cost $300 from Detroit axle. I got all the lines bolts and anything else attached removed. I can’t get it out from under the truck. I’m about to torch the old rack into small pieces. Does anybody know how to get this out. The internet says to slide it up towards the steering wheel fire wall then take the passenger side out the front. There is absolutely no room. Let me know if you have any ideas.
  2. Oct 15, 2019 at 6:59 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome! Wish I could help but someone on here with an answer will surely respond.... Bump
  3. Oct 15, 2019 at 7:07 PM
    LML 3500HD
    Have you taken out the oil filter housing assembly?
    jeremyd and Black Wolf like this.
  4. Oct 15, 2019 at 7:08 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    @csuviper ...Vipe had two replaced if I remember correctly. There is a post or more from a member/s who did it themselves...
    ColoradoTJ likes this.
  5. Oct 15, 2019 at 7:13 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Ok I don’t have a Tundra in front of me but up to 2013 it’s the same procedure it suppose to come out easy only 2 bolts holding it with the 2 lines and steering shaft but what I seen in my alldata is that in the 5.7 you have to remove the oil filter housing so it has room to come out make sure u keep the wheels straight at all times do not spin the steering wheel whit it’s disconnected from the rack you will damage the clock spring
  6. Oct 15, 2019 at 7:16 PM
    Aurora CO
    Bingo!!!^^^^:thumbsup:
    jeremyd and ColoradoTJ like this.
  7. Oct 15, 2019 at 7:20 PM
    LML 3500HD
    Once you take out the oil filter housing assembly, you should have ample enough room.
    I can’t believe the dealership wants to remove engines (book time).
  8. Oct 15, 2019 at 7:25 PM
    Aurora CO
    I can't believe there are no unicorns...
  9. Oct 15, 2019 at 7:27 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Love this forum ! Learn something new all the time !
  10. Oct 15, 2019 at 7:28 PM
    Aurora CO
    The Best Tundra Forum for sure!
    @Bob......
    jeremyd[QUOTED] likes this.
  11. Oct 15, 2019 at 7:30 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    @LOTSOFTOYS did my first at Toyota and the second I just traded in the truck. Front diff and all sterling components were pretty much removed
    Black Wolf and ColoradoTJ like this.
  12. Oct 15, 2019 at 7:33 PM
    csuviper
    Broomfield, CO
  13. Oct 15, 2019 at 7:34 PM
    Aurora CO
    On that note..where is "he" lately?
  14. Oct 15, 2019 at 7:34 PM
    Aurora CO
  15. Oct 15, 2019 at 7:35 PM
    LML 3500HD
    For you Sir. Rainbow and gun added for your pleasure.
  16. Oct 15, 2019 at 7:36 PM
    Aurora CO
    Got rainbow eggs yet? Asking for a friend...:anonymous:
  17. Oct 15, 2019 at 7:38 PM
    csuviper
    Broomfield, CO
  18. Oct 15, 2019 at 7:49 PM
    LML 3500HD
    Not yet. I’m thinking I have free loading hens.
  19. Oct 15, 2019 at 7:55 PM
    Aurora CO
    Lots of hen chickens in the sea. Free loading hens....quite tasty...:fistbump:
  20. Oct 15, 2019 at 7:55 PM
    Aurora CO
