Hypertech vs. Bully Dog
Discussion in 'Performance and Tuning' started by DocsTundra, May 7, 2016.
  1. Dec 22, 2016 at 4:24 PM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    The hypertech doesn't crack the ecu. It works now. But 16-17 seems to have a higher chance of a check engine light.
    Hattori likes this.
  2. Dec 22, 2016 at 4:37 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Let me clarify for those who may get the "cracked" term way out of context. The PCM on 09 production month of this year and later is not fully accessible which leads to CEL codes and will put the engine in limp mode( in time ). Can you put it on your truck and count on it to start up, yes you can but you will have problems later down the road. The pedal module with the HT Interceptor isn't needed because of the signal changes that the throttle gets on the 07-13 models which are different on the 14+ models. It changed in 2014 to current. BullyDog has said they will have a solution in the spring/summer 2017 for the non-supercharged vehicles and non FFV. As far as any others like Superchips and Egde, I haven't heard much on but I am always checking due to the popularity of this mod.
  3. Dec 22, 2016 at 5:03 PM
    dirtydeeds
    Keith
    USA
    did toyota change the pin out on their mass air meter or something? because the interceptor doesn't do anything to the ecu, it only intercepts and modifies the signal from the mass air meter and iat
  4. Dec 22, 2016 at 5:51 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Well, I'm interested in a tuner. My '16 cut power to the engine today when I accelerated hard to get around a one man obstruction to traffic. My other Tundras never did that.
  5. Dec 23, 2016 at 12:28 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    A tuner won't stop that. Your traction and stability control is the culprit.
  6. Dec 23, 2016 at 5:11 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Well yes, nannies were on, but I wasn't spinning the tires or cornering. It's something I'm gonna have to play with to figure out since you've gotta be stopped to turn off vsc and I don't usually plan in advance to punch it like that.
  7. Dec 23, 2016 at 6:06 AM
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
    so what is the general consensus? BD or HT?
    I already have the HT speedo healer so I'm not concerned with that.
    WOW! I just read about the BD Platinum Gas programmer. It seems that it does EVERYTHING but start the truck.
  8. Dec 23, 2016 at 6:40 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    BD is the way to go. With all of its features plus the ability to upload the SC program for those going with the Magnuson kit ( on certain truck models ), its to me the best all around tuner out right now.
    FlashCulprit and 831Tun like this.
  9. Dec 23, 2016 at 8:03 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I have the Bullydog GT tuner (40417) for my '14, I would recommend it as it changes vehicle settings, calibrates for bigger tires, hp/tq, performance monitor. The biggest benefit I feel from the tuner is when it shifts, it does way better even under heavy acceleration.
    Samoan Thor and 831Tun like this.
  10. Dec 23, 2016 at 8:58 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    This is a great informational thread! subed
  11. Dec 23, 2016 at 5:34 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    I haven't done that yet, I should though, I never leave without putting it on. It gets really annoying when something heavy is in the passenger seat and it keeps on beeping faster and faster.
  12. Dec 23, 2016 at 7:49 PM
    TruckyTruck
    Gary
    I was surprised when mind did that after I bought it. You're truck doesn't have to spin or be out of control for it to shut down power. It just has to calculate that it's going to. Test it out from a stop. Punch it and when it goes to shift, it will do it Everytime until you turn off the nannies.
  13. Dec 23, 2016 at 8:14 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep seemed like it cut at the shift point. I'm looking for a safe opportunity to try it with nannies on in sport mode as suggested by Hattori. I don't turn the nannies off every time I get in the truck. Nor can I predict when I might need/wand to accelerate like that. I got my truck a year ago yesterday and have only had the problem occur 2 maybe 3 times. I just want to know how to get around the issue, in case.
  14. Dec 23, 2016 at 8:36 PM
    TruckyTruck
    Gary
    Yeah, turning them off Every time is unrealistic. Plus, the truck really does a pretty good job at keeping you on the road. I was able to miss 4 deer in the road before the sun came up and not go into a ditch or worse, a few months ago. I consider myself a good driver, but I know the truck safety controls kept me from wrecking.
    831Tun[QUOTED] likes this.
  15. Apr 23, 2017 at 8:23 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    What's the different between the gt model and the box? Which one is better?
    @dirtydeeds
  16. Apr 23, 2017 at 8:35 PM
    crishard
    Cris
    Mine cut out on me last week when accelerating hard up an on-ramp to get on the interstate. Conditions were dry and it was a strait line. This is some bs in my opinion! This type of computer controlled crap could have got me killed.
  17. Apr 23, 2017 at 9:32 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That's how I feel. I wonder if the older power control module would work in the newer trucks
  18. Apr 29, 2017 at 6:25 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    After i get my lift done i was curuous...I know the BullyDog has a lot of features but If I don't really mind the speedometer being off would it be necessary to get both BullyDog and the Speedo calibrator? I guess a better way to put it is besides the Speedo is there anything that the hypertext Speedo calibrator does that the BullyDog doesn't? Or would I be ok getting the BullyDog and just dealing with the Speedo being off?
  19. Apr 29, 2017 at 8:09 AM
    #49
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I don't know what size tires you're planning to run but, several times now, I've driven by those digital things that the Highway Patrol puts up to tell you your speeding. I've been shocked to see that even with 295 70 18s my speedo is very close or spot on. So, I don't see the need for the speedo calibrator in my future. Before you think about the Hypertech, make sure you need it.
    Dustydirt19[QUOTED] likes this.
  20. Apr 30, 2017 at 12:33 PM
    #50
    crishard
    Cris
    If you get the BD you won't need the HT. I wish I would have known that before I got the speedo recalibrator. I plan to get the BD soon so I will most likely sell the HT if anyone would want it.
    Dustydirt19 and Hattori like this.
  21. Jun 23, 2017 at 7:18 PM
    #51
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    So.... I'm reading crazy mixed feelings... I have a BD on the way... I'm so excited but now have mixed feelings. Time will tell! I'll update after I install it
    Harris1881 likes this.
  22. Mar 8, 2018 at 3:35 PM
    #52
    walter93
    walter93 a Newbie: speak slowly and use small words
    Walter
    Houston
    2017 White Tundra SR5 crewmax 4x4 5.7
    TRD air filter TRD air maximizer TRD dual exhaust Gatortraxx MX rolling tonneau cover
    Well, what's your opinion after having it 9 months? I'm looking at a BD over a HT after reading all of these comments. I have a '17 5.7 flex.
  23. Mar 9, 2018 at 7:46 PM
    #53
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Definitely more responsive, shifts better, and like the settings I can change. I have everything in performane mode and I don't care what people say I do notice a difference. My tundra is more awake now
    Samoan Thor and 15whtrd like this.
  24. Mar 9, 2018 at 8:40 PM
    #54
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I noticed on performance everything for me on steep sharp uphill turns going up and down it downshifted pretty hard, plus too aggressive on the skinny pedal, slightest touch and it moved fast which is kind of annoying but I try to ease into it.
    Maybe I need to love my BD again, I haven't used it for a while, I almost wanted the DAP tune but then after much reading the BD offers the same thing but with more features.
  25. Apr 15, 2018 at 12:48 AM
    #55
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Reviving this thread. BD states it calibrates the speedo meter now and includes many functions for the FFV. I am hoghly considering this option as an easy plug n play.
  26. Apr 17, 2018 at 3:39 AM
    #56
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    What's the price for the BD?
  27. Apr 17, 2018 at 4:29 AM
    #57
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Yes BD is a good investment. Like stated, better shifts, more responsive and I have any info I want on my truck with the click of a button. Just my .02
  28. Apr 17, 2018 at 4:30 AM
    #58
    seniramsu
    Nate
    VA
    If you want a deal on the BD hit up dirtydeeds
    15whtrd likes this.
  29. Apr 17, 2018 at 5:07 AM
    #59
    Tracker
    Tracker New Member
    Shane
    $399
  30. May 6, 2018 at 9:34 PM
    #60
    Lars
    Lars Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    I just upgraded to 315x70-R17 (34.4" x 12.4") this last Thursday. Today I set the cruise control at an indicated 70mph, and gps verified my speed was 73/74mph
    I'm considering leaving it alone It's close enough.
    What I'm interested in though, is folks without a Supercharger. Have you seen any fuel economy improvements, OR shift point improvements after going to 35" tires? :)
