HyperTech Interceptor Issues
Discussion in 'Performance and Tuning' started by 650h1, Sep 18, 2016.
  1. Sep 18, 2016 at 6:26 AM
    650h1
    650h1 [OP] New Member
    2013 Rock Warrior C/M
    So I bought one of these interceptors, opened it, downloaded the software, plugged it in, hit update, and it gave me the error 0x040A - couldnt contact update server. Tried it on my surface pro running windows 10, and a shitty windows 7 laptop at work. I've tried a bunch of times, and I get the same error every time.
    I bought this on craigslist, the guy that had it never plugged it into the computer as he just ran it on his stock truck. So, fuck me right?
  2. Sep 18, 2016 at 6:35 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Call hypertech and see if they can walk you through the update or confirm it is broken.
  3. Sep 18, 2016 at 6:37 AM
    650h1
    well my truck is stock, do I absolutely NEED it to be plugged in or can I just run it the way it is?
  4. Sep 18, 2016 at 6:40 AM
    csuviper
    Broomfield, CO
    Don't need to update then. Plug it in and see what happens. If it's working you will get a little added power. If not then you will prob see a CEL
  5. Sep 18, 2016 at 6:41 AM
    650h1
    Cool, I like surprises.
    T-Rex266 likes this.
  6. Sep 18, 2016 at 6:44 AM
    csuviper
    Broomfield, CO
  7. Sep 18, 2016 at 6:49 AM
    650h1
    I dont understand how failing to contact the update server would indicate an issue with the actual tuner. It gives me some error message about JIT debugging and an unhandled exception. Like I am supposed to know what either of those things are.
  8. Sep 19, 2016 at 9:50 AM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    Plug that sicker into your truck and run it!!
    T-Rex266 and 650h1[OP] like this.
  9. Sep 19, 2016 at 10:21 AM
    650h1
    I did! works great! So I noticed that the truck sounds a little different, I know you have a lot of experience with these, is that somewhat normal? It's subtly different. Also, the performance increase is subtle until you get into it - then you will pitch a pants tent almost immediately. I like it, wish it would work with the computer though...
  10. Sep 21, 2016 at 11:21 AM
    dirtydeeds
    Keith
    USA
    our ecu has the ability to adjust cam phasing, ign. timing etc. very precisely.
    cam phasing and ignition timing are the 2 biggest changes that can be made which will change the way an engine sounds.
    you are literally hearing the hypertech work:)
    650h1[OP] likes this.
  11. Sep 21, 2016 at 11:23 AM
    650h1
    Cool, I did notice there doesn't seem to be the annoying clicking valve noise anymore either... thanks for the info @dirtydeeds!
  12. Sep 21, 2016 at 3:52 PM
    07tacoswb
    07tacoswb New Member
    2016 Super White Tundra Crewmax XSP-X
    Glad to hear your is working too.
    650h1[QUOTED][OP] likes this.
  13. Nov 6, 2016 at 5:25 AM
    tommytran83
    tommytran83 New Member
    Did you noticed any changes on the gas pedal?
