HYPERTECH IN-LINE SPEEDOMETER CALIBRATOR
Discussion in 'General Tundra Discussion' started by treihing, Jul 20, 2017.
  1. Jul 20, 2017 at 9:03 AM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    2018 Black Limited CrewMax
    Good Morning-
    Has anyone ever successfully used the HYPERTECH IN-LINE SPEEDOMETER CALIBRATOR on their 2014 or greater Platinum Tundra? I have seen a few posts where people are having issues so I want to hear some success stories.
    TR
  2. Jul 20, 2017 at 9:06 AM
    Lilly
    Lilly New Member
    Troy
    North Carolina
    2015 White Tundra 1794 Edition
    4-6" RCD Lift System, 20" Moto Metal Rims. PIAA LED Light bar, Tonneau Cover
    I too am interested! Was on my list as my next install. What are the negative issues that have you heard?
  3. Jul 20, 2017 at 9:07 AM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    A couple of people were having issues with their Check Engine light flashing and shifting issues on their Platinum models. It would be a real shitter if this does not work.
    Lilly likes this.
  4. Jul 20, 2017 at 9:42 AM
    renlo
    renlo New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    I just asked the same question and someone posted a response saying they were sent an updated cable from Hypertech. I actually called hypertech and asked about this and they stated all of the cables have been updated.
    Another member also posted saying he was having issues and the issue ended up being that there were several cables zip tied together and they would get pinched and pulled from the module. He said after he cut the zip tie off, he had no more issues.
    I just ordered one and will post back with update.
    Lilly likes this.
  5. Jul 20, 2017 at 10:13 AM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    Boom. Thanks my Friend. I am ordering mine now!
  6. Jul 20, 2017 at 1:13 PM
    renlo
    renlo New Member
    Rene
    Check with svcustoms, they have a discount for tundra forums.
    Lilly likes this.
  7. Jul 20, 2017 at 1:33 PM
    TRDpro619
    TRDpro619 Follow My Build on Instagram:TRDorcaTUNDRA
    San Diego
    TRD Pro CM
    I'm rolling in 35s and using this, seems to be pretty accurate off about 1mph if anything
    Lilly likes this.
  8. Jul 20, 2017 at 4:09 PM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    I was about to order one but then looked at the detail of the installation and passed.
    Flyinryank likes this.
  9. Jul 20, 2017 at 7:02 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    FYI to anyone doing the install. Leave the cable that plugs into your laptop, connected to the module behind the dash. This way after you do the test drive and the speedo is off a touch, you can plug the cable back into your laptop without ripping the dash apart again. When complete just coil up the cable and zip tie under the dash near the brake controller. Hope this helps.
    DSLKSL and Lilly like this.
  10. Jul 20, 2017 at 7:25 PM
    renlo
    renlo New Member
    Rene
    Its actually not that difficult, appears to be 2 screws to remove gauge cluster, plug in harness, run cable down.
    This is a great tip which I learned the hard way.
  11. Jul 20, 2017 at 7:45 PM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    Good to know. Will this also improve on the hard downshifting I have with my larger tires?
  12. Jul 20, 2017 at 7:47 PM
    renlo
    renlo New Member
    Rene
    Ive heard it does as it brings everything back to stock form.
  13. Jul 21, 2017 at 4:03 AM
    CM-LENNY
    San Diego, CA
    This is a misconception. The speedo calibrator does nothing at all to anything related to engine/trans etc. All it does is correct the speedo. I believe hypertech and bullydog etc do make a unit that tweeks the fuel curve etc, but the speedo calibrator ONLY corrects the speedo.
    Rica25 and PMG like this.
  14. Jul 21, 2017 at 5:29 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I would love to get one, but I don't think it's compatible with Mac.
  15. Jul 21, 2017 at 8:39 AM
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    Thanks for that info. I could care less about the speed change I just want to fix the hard downshifting.
  16. Jul 25, 2017 at 11:54 AM
    Lancedavisaz
    Lancedavisaz New Member
    2015 Tundra Platinum Crewmax
    BDS 4.5 LIFT, Fuel Assult Rims, 35x12.5x20
    I purchased the HYPERTECH IN-LINE SPEEDOMETER CALIBRATOR for my 2015 Crewmax Platinum in May. I installed it and had the check engine light came on and my display read that the Traction Control was Off. Disconnected, checked wiring and reconnected and had the same results. I called Hypertech and they sent me a new wiring harness. I installed it and had the same results. When I called back they told me that the Platinum trim probably has some settings that aren't compatible with the unit. Really disappointed. Did I just got unlucky twice? I have yet to see a post about this unit working with a platinum.
    renlo likes this.
  17. Jul 26, 2017 at 5:42 AM
    renlo
    renlo New Member
    Rene
    Ill let you know Sunday if it works.
  18. Jul 30, 2017 at 12:02 PM
    renlo
    renlo New Member
    Rene
    Well I have some good news and some bad news. The good news is that the recalibrator works perfectly with my platinum. I had no check engine lights or other dash lights. The bad news is that I was unable to find a tire size to even come close to the stock tire speed. I tried my current tire size but that showed on the dash I was going 45mph when gps and local speed radar showed me going 4 mph slower. I went higher and even lower but nothing would work, so unfortunately I am going to return it. On the flip side, with my current tire size, I am only 2 mph off my the speedometer. Ill just leave it as is.
    Anyone interested in a calibrator before I return it?
  19. Jul 30, 2017 at 1:23 PM
    CM-LENNY
    San Diego, CA
    Not sure why you had a problem dialing it in Rene. With the laptop plugged into the calibration cable, you can change the old or new tire sizes to within fractions of an inch and get it dialed in exact. If you are comfortable, that 2MPH is not much at all. Keep in mind that 2mph grows the faster you go. Just a ratio game.
  20. Jul 30, 2017 at 1:35 PM
    renlo
    renlo New Member
    Rene
    I am not sure either. Im going to try again another day, there were other factors that made me revert back to stock also. Hopefully it works out.
  21. Feb 8, 2021 at 5:05 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    I installed mine in my SR5 and now my cluster is lit up like Christmas and the truck wont start. Of course I have to go to work so thats a nice plus.
  22. Feb 8, 2021 at 5:43 PM
    Ryuu
    Ryuu New Member
    Oscar
    SouthEast, TX
    17 TRD PRO Barcelona Red
    just threw stuff at it
    did you disconnect the battery before installing it?
  23. Feb 8, 2021 at 6:08 PM
    Tracker
    Tracker New Member
    Shane
    No, I ready the directions and followed. It didnt say to.
  24. Feb 8, 2021 at 6:18 PM
    Ryuu
    Ryuu New Member
    Oscar
    SouthEast, TX
    Yea for some reason the instructions don't mention it but its a good thing to do anytime you mess with anything electrical. I disconnected the battery when I installed mine and no issues with it. I'd say just give it a try, no harm in doing it.
  25. Feb 8, 2021 at 6:23 PM
    Tracker
    Tracker New Member
    Shane
    My thought was to disconnect the battery tomorrow and see if it helps reset. Im guessing now.
  26. Feb 8, 2021 at 6:28 PM
    Ryuu
    Ryuu New Member
    Oscar
    SouthEast, TX
    Yea hopefully that fixes it, saw somewhere else that someone had the same issue with their dash lighting up and disconnecting the battery for a few seconds fixed it.
    If that doesn't do it then its back into the dash and checking all the connections but just leave the battery disconnected. Also hooking up the black module back to your computer/laptop just to make sure it didn't reset itself.
    Tracker[QUOTED] likes this.
  27. Feb 12, 2021 at 10:40 AM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    WHEELS MotoMetal 962’s 20x12 -44 offset SUSPENSION Energy Suspension Bump Stops Pro Comp 6” Lift Kit Body mount chop - BMC King Front Shocks with Remote Resi King Rear Shocks with Remote Resi Toyota TRD Rear Sway Bar Pro Comp ProRunner UCA's Toytec Adjustable Lift Shackles DRIVETRAIN Energy Suspension Rack Bushings (progress) TIRES Fuel Mudder M/T 37x13.5x20 EXTERIOR BulletLiner Truck Bed Liner PerformanceAccessories 3" Body Lift Performance Accessories Gap Guards Go Rhino Dominator D2 Nerf Bars Undercover SE Tonneau Cover AUDIO JL Audio HD900/5 JL Audio HD750/1 Dynamat Extreme Closed Cell Foam Install (progress) JL Audio Stealthbox Pioneer SPH-DA120 (AppRadio 4) INTERIOR Black Suede Headliner Carbon Fiber Vinyl Wrap Suede Door Panel Insets Steering Wheel Cover AJT Design Shift Knob AJT Design Key Fob LIGHTING Door panel accent lighting Swapped all interior lights to LED Morimoto Custom Retrofit Headlights Morimoto XB LED Fog Lights COSMETIC Debadged All Emblems Powdercoated ProComp Lift Parts Envy Grille (progress) G2 Brake Caliper Paint - Gold Toyota Fender Flares PERFORMANCE Unichip programmer StopTech Drilled and Slotted Rotors Borla Turbo XL Muffler K&N Air Filter STORAGE Rotopax 4 gallon fuel pack Diesel Power Hang A Hitch TOWING Elevated Suspension Tow Brackets Razor Auto Aluminum Shackles ELECTRICAL Optima Yellow Top Battery
    I recently installed the speedo calibrator in my 09 limited and it didn’t change the speedo at all. I’m about 8mph slow at 60mph according to the gps in my radar detector. Hypertech said it must be a bad unit and sent a new one. Getting the same thing with the new unit as well. I’m running 37’s but increased the tire size to 45’s and made no difference. I’m going to try disconnecting the battery to see if that helps.
  28. Feb 12, 2021 at 12:17 PM
    gan
    gan New Member
    Rgv Texas
    2021 Black Tundra Pro
    installed it on my 21 and was able to get it within 1mph so I called it good. I did disconnect the battery while I installed it.
    Ryuu likes this.
  29. Feb 14, 2021 at 2:31 AM
    Tracker
    Tracker New Member
    Shane
    My battery was dead in the morning, I gave it a good 25 minute charge at idle and the speedometer recalibrator seems to be functioning properly now after what became a natural reset. I drove it past a speed trailer and it registered 30mph on the trailer and the truck. No issues anymore!
    Ryuu likes this.
  30. Feb 14, 2021 at 8:43 PM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    Anyone know where one can find a decent install video? Or does someone want to make one? ;):bananadance:
    I know others will be very appreciative!
