Husky Liner Passenger Side
Discussion in '2.5 Gen Tundras (2014-2021)' started by sgrounds22, Jan 9, 2019.
  1. Jan 9, 2019 at 9:04 AM
    sgrounds22
    sgrounds22 [OP] New Member
    2018 Tundra Limited
    The piece you screw down into the carpet to keep the liner is place doesn't work very well for me. I picked up some velcro, but the adhesive wouldn't hold. Same with Gorilla glue and epoxy. Anyone know what type of adhesive will work on the material or some other way to secure the liner?
    TIA
  2. Jan 9, 2019 at 9:20 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    sgrounds22[OP] likes this.
  3. Jan 9, 2019 at 9:24 AM
    sgrounds22
    2018 Tundra Limited
    Nice! Thanks a lot.
  4. Jan 9, 2019 at 10:20 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Did you take the screw apart?
    1. Mark the spot, use a flathead and secure the screw only
    2. THEN put the mat down over the nub
    3. Followed by the screw top
    Whenever you want to wash the mat, you just need to remove the top. The screw is always in place.
  5. Jan 9, 2019 at 12:06 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I used the course side of one price of Velcro and it stays in place right to the carpet.
  6. Jan 9, 2019 at 12:27 PM
    JDHolliday27
    JDHolliday27 New Member
    2018 CM
    Does anybody know if you can purchase a replacement screw for the passenger side from Husky? Last time I had my truck detailed, the guy pulled up the mat and accidentally broke the bottom screw piece that goes into the carpet...
  7. Jan 15, 2019 at 1:15 PM
    sgrounds22
    2018 Tundra Limited
    I didn't know it came apart. Probably should have read the directions.
    I purchased the eagle klaw linked above and it works like a champ!
  8. Jan 15, 2019 at 1:16 PM
    sgrounds22
    2018 Tundra Limited
    I tried that. The course side stayed right in place. However, the mat didn't :)
