Husky Compressor Help
Discussion in 'Off-Topic Discussion' started by gman31, Jan 4, 2021.
  1. Jan 4, 2021 at 11:00 AM
    gman31
    gman31 [OP] New Member
    New Orleans
    My 8 year old, lightly used, Husky, 20 gallon compressor just took a dump. The motor just stopped while filling the tank and won't come back on. It's used for filling tires, blowing out home AC drains, impact gun, and maybe a few more small tools. I can't believe it died already. My questions are:
    1. Should I try to have it repaired or by a new one? (I wish I were smart enough to fix it myself).
    2. If I were to buy a new one, what do you guys recomend? Budget friendly of course.
  2. Jan 4, 2021 at 11:08 AM
    RobertD
    Robert
    DFW, Texas
    I'd try and troubleshoot it, if that doesn't work get a quote for a repair. A new 20 gallon compressor will not be cheap.
  3. Jan 4, 2021 at 11:11 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Probably start capacitor i think its called...I replaced one on my cheapo Walmart one.
  4. Jan 4, 2021 at 11:17 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    I have nice smaller portable compressors for using nail guns at work. But for my garage, I only need one for filling tires, impact gun for lug nuts and blowing off whatever I’m working on.
    Based on my needs, I got the 20 or 21 gallon vertical Harbor Freight one that is oil lubricated. Only $160. Change the oil frequently at beginning and put in a quality synthetic. It’s loud but I’m sure that Husky is also.
    I don’t think it will be cost effective to be repaired. These oil-less compressors can die at any time and most are too cheaply made to repair, unless done diy and labor is not valued.
    I would look for a reset button or hit it a few good times with a hammer. Otherwise save the hose and try to sell it for cheap.
  5. Jan 4, 2021 at 11:24 AM
    TheBeast The Beach
    I first bought a Husky and it was DOA. I returned it to HD then got myself a DEWALT pancake style. Works great for around the house and vehicles.
  6. Jan 4, 2021 at 11:34 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    The Harbor Freight compressors are usually rated pretty well in the sub $1000 range. I have a 60 gallon 2 stage and run it a ton and no issues, I know that's a bit higher weight class but so far no issues with their compressor.
