Hum/drone above 55 mph...Stops when I take my foot off the gas...
Discussion in '2nd Gen Tundras (2007-2013)' started by tundraatx, Mar 26, 2020.
  1. Mar 26, 2020 at 1:31 PM
    tundraatx
    tundraatx [OP] 2008 Limited Double Cab, 5.7L
    Austin, TX
    1) Bought with 225k miles on it, a Westin bullnose bumper, and OEM tundra steps 2) Current Mileage 238k Mods: 1) Dirty Deeds BA Mufflers 8 inch with resonator (as of Feb 2021) - Had the 10 inch with resonator - Prefer the 10 inch without resonator - deeper sound hear it more in the cab 2.) Ranch Hand Summit Front Bumper/Guard 3) Ranch Hand Summit Bumper 4) Billstein 5100s all around 5) TRD front and rear sway bars 6.) Rough Country wheel to wheel steps 7) Pioneer 8400 NEX Wireless ApplePlay 8) Backup Camera: e-raptor 9) LED white lights replaced in headlights, fog lights, inside cabin, and exterior lights 10) Linex (unbranded by Central Texas Truck Coatings) 11) OEM Toyota side panels and generic panel on tailgate Maintenance/Repairs: 1) Valve covers, belt tensioner, alternator belt - $415 2) Evaporation fuel canister and filter replacment $1547 *This was a Toyota TSB for 07-08 AFAIK. Toyota covered in first 3 years of ownership. Mine failed after 13 years of daily regular driving use. Not bad at all. 3) Pioneer Unit - had to ship to Pioneer to replace Output IC - $45 (shipping) free under 1 year warranty fix 4) Pioneer Unit - Electrical feed back coming through speakers when accelerating. Fix was to check all wiring/tighten up/ make connections good again $42. 5.) Rear passenger door actuator replaced. Part was $287 with tax on ebay from Toyota dealer free shipping. 6.) Rack and Pinion, tow mirrors, shocks install, lifetime alignment - $1884.36
    When I am pressing the gas and hit 55 mph and above, I hear this low hum/drone, but it stops when I take my foot off the gas. I can hear it consistently above this especially at 70-75 mph. The issue started about 2 weeks ago.
    I found a similar thread here: https://www.yotatech.com/forums/f2/...hour-stops-when-i-take-my-foot-off-gas-96392/
    Might be the rear differential. This guys sounds way worse than mine, but same issue/description.
    https://www.youtube.com/watch?v=KwoMUejhs_Q
    My shop said the drive shaft and everything else checks out fine. I don't know what everything else means, so I asked if the ujoints and pinions were good.
    What else can cause this hum/drone?
  2. Mar 26, 2020 at 2:03 PM
    AZTundra
    Paul
    Phoenix, AZ
    Could it be the wheel bearings or possibly the differential?
  3. Mar 26, 2020 at 2:03 PM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    How many miles on the truck? 2 or 4wd? If you pop the truck in neutral does the noise go away? There are a lot of moving parts, any cel's or abs codes?
  4. Mar 26, 2020 at 4:18 PM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Following. Same issue, past month. Are you sure it goes away with the gas or is the exhaust covering it up?
