HU/Speakers/Sub/Amp/Accessories for 1K(ish)?
Discussion in 'Audio & Video' started by treetreego, Aug 3, 2020.
  1. Aug 3, 2020 at 6:00 PM
    treetreego
    treetreego [OP] New Member
    MS
    2020 Tundra Crewmax TSS 4x4
    295/65/20 Nitto Trail Grappler MT on Fuel Mavericks, Leveled
    Is it possible to upgrade my audio system for about $1000 and have a good sounding setup?
    I'd like to keep all the functionality (camera, steering wheel controls, bluetooth mic, etc) but upgrade the system and have it sound good.
    What would you guys recommend as far as specific items to get if it's possible. Thanks
  2. Aug 3, 2020 at 6:33 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Would you consider keeping the head unit?
  3. Aug 3, 2020 at 6:36 PM
    treetreego
    MS
    I’ve read multiple people say it’s garbage. Is that not the case?
  4. Aug 3, 2020 at 6:39 PM
    purplenova
    Tom
    Ohio
    The amp under the pass seat is the problem
    Here's my setup, with factory HU. Factory door speakers, sub and JL Audio c1 tweeters in dash. Also it's non JBL system.
    jlewis44 likes this.
  5. Aug 3, 2020 at 7:05 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    The head unit is going to be your big ticket item.
    If you are ok with keeping the factory head unit you should easily be able to have a nice system for 1k. You could always swap the head unit down the road.
    Line Out Converter (like a Lc7i)
    5 channel amp
    4 sets of 6.5" components w/ speaker adapters
    1 10" sub in a ported box.
    Amp wiring kit
  6. Aug 3, 2020 at 7:24 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    jlewis44, Trooper2 and treetreego[OP] like this.
  7. Aug 3, 2020 at 8:27 PM
    dspilot
    dspilot Professional Nomad
    North Mississippi
    2019 SR5 4X4 Silver Sky Metallic
    I'd definitely recommend going through tech12volts. I did a complete system through him for right at 1k. I did keep the head unit with the mindset that I could always change it out later pretty easily. The new system sounds SOOO much better, even with the factory HU.
    treetreego[OP] likes this.
  8. Aug 3, 2020 at 8:55 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Alpine shallow mount - $300
    5 Channel amp - $350
    2 pair hertz components - $200
    2 10” subs - $200
    Box - $200
    Wiring/Install parts/harnesses- $300
    probably about minimum for decent stuff $1600 ish
    treetreego[OP] and AZBoatHauler like this.
  9. Aug 3, 2020 at 10:14 PM
    AZBoatHauler
    So.Arizona
    This is a realistic budget for a conservative full build. I went buy once cry once approach and spent $2k on a full setup from James at Tech12volts. Kenwood HU with wireless CarPlay, and JL Audio amp/speaker package. Throw in another couple hundred for sound deadening material and a couple days for install and you’re all set.
  10. Aug 3, 2020 at 11:20 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    Yeah I’m probably in the $2400-$2500 range all in including sound deadening.
    AZBoatHauler[QUOTED] likes this.
  11. Aug 4, 2020 at 2:09 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    A "good sounding setup" is not only ambiguous, but it s a pretty subjective way to put it. It really depends on your expectations. One also has to consider upgradability. Will you be satisfied with you end up with? Probably not. Will, what you bought, work if you decide to go bigger/better...there s a lot to consider.
  12. Aug 4, 2020 at 6:41 AM
    treetreego
    MS
    Thanks for all the replies. I definitely have some things to consider going forward.
    @jwatt yea I realize "good sounding" is relative and broad but to me it just means quality of sound overall and some bass. I love bass but I also love quality sound. I don't need to blow my doors off with the thump. I'm not a teenager anymore LOL!
    purplenova likes this.
  13. Aug 4, 2020 at 8:33 AM
    Danimal86
    Daniel
    Sacramento, CA
    you should email james at tech12volt (tech12volt@gmail.com) and see if this is still available.
    https://shop.tech12volts.com/product.sc?productId=574&categoryId=137
    Even if its not, just let james know what you are trying to accomplish and let him know how much you want to spend. He will do what he can to make sure you've got the best bang for your buck. He's gotten more of my money than i'd like to admit.
  14. Aug 4, 2020 at 11:49 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    panicman and treetreego[OP] like this.
