How to turn off key in the ignition and door open chime?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cement, Mar 2, 2019.
  1. Mar 2, 2019 at 8:39 AM
    Cement
    Cement [OP] ...
    2019 Cement Trundra TRD
    Would love not to have to hear the damn thing when I'm listening to the radio and have the driver's door open. Any suggestions?
  2. Mar 2, 2019 at 8:57 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    On my 2010 ,I unhooked the White Connector(there's only one) behind the steering wheel shroud to silence the 'dinger'. What I lost(or gained) though, was being able to lock Driver's Side Door WITH the key in ignition, so that's part of the trade-off. My key stays in the ignition most of the time anyway, so it didn't matter to me. On a newer truck, this is all probably a moot point though:confused:
    WrigglingWilly likes this.
  3. Mar 2, 2019 at 8:57 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I believe your dealer can do it or you can do it with TechStream
  4. Mar 2, 2019 at 9:32 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    I saw years ago a small metal piece attached with a screw that slides over the switch. I think it was in JC Witney catalog
  5. Mar 2, 2019 at 9:36 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    You leave your keys where!!!:eek::eek::eek:
  6. Mar 2, 2019 at 11:07 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    this ^ works on 2015 and prob up
    just turn the steering wheel, remove the two screws that hold the lower plastic cover of the column surround, disconnect the wire from the bottom of the ignition tumbler. done. enjoy the peace.
    Drainbung and 831Tun like this.
  7. Mar 4, 2019 at 12:06 PM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    What do you mean you lost the ability to lock the driver side door while key is in the ignition? So the door lock button doesn’t work on the door once you do this? That would be a terrible result
  8. Mar 4, 2019 at 12:07 PM
    Cement
    Cement [OP] ...
    ^^Good question, and also the cover on my 2019 is one solid piece. It doesn't come apart in the center. Seems like I'd have to pull the entire steering wheel to get it off. Am I looking at it wrong somehow?
  9. Mar 4, 2019 at 12:13 PM
    B737
    Jersey Shore
    you do not need to remove the steering wheel, the trim is removable around the column
    if you unplug the key sensor you lose the chime, and you will be able to lock yourself out of your truck while the keys are in the ignition.
    Cement[OP] likes this.
  10. Mar 4, 2019 at 12:29 PM
    CMB
    CMB New Member
    Cecil County MD.
    As my 2010 came stock, the Driver's Side door wouldn't lock, if the key was in the ignition(not a bad feature) After unhooking the connector and disabling the 'dinger', all doors lock, even with the key in the switch.
  11. Mar 4, 2019 at 12:31 PM
    cmiller219
    Nashville, TN
    Oh ok got it now. I was reading it as you lose the lock unlock button feature all together if you did this
  12. Mar 4, 2019 at 12:43 PM
    Cement
    Cement [OP] ...
    Duh. Of course you're right. I was looking at the wrong mold line in the plastic. Halves came apart just as you said, white connector pulled and no more chime. Thank you!
  13. Mar 4, 2019 at 12:44 PM
    koditten
    koditten New Member
    You can't lock the doors with the keys in the ignition. You didn't lose that feature because you never had it.
    But, yeah the Tech Stream program will give you what you want...mostly.
    You can turn off the seatbelt chime completely.
    You can only turn the key in the ignition/open door minder to it's quietest setting. They come from the factory at their loudest unfortunately.
  14. Mar 4, 2019 at 12:49 PM
    B737
    Jersey Shore
    techstream will not turn off key in the ignition chime with door open. OP isnt asking about seatbelt.
    locking logic has been discussed above in this thread. What @Cement shows is the way to disable the key chime.
  15. Mar 4, 2019 at 1:09 PM
    CMB
    CMB New Member
    Cecil County MD.
    Like I posted. On my 2010, it came stock with driver's side door staying unlocked, if a key is in the switch. After unhooking the connector, ALL DOORS are locked WITH key in switch. YES,that feature was lost with the chime/dinger....on my 2010. Am I not explaining this clearly enough:confused:
    B737 likes this.
  16. Mar 4, 2019 at 1:15 PM
    Cement
    Cement [OP] ...
    FWIW: after pulling the white connector, with the driver's door open, my doors WILL NOT lock with the key in and turned to Accessory. My doors WILL lock with the key in and in the key-lock position. Maybe that's part of the confusion?
    Also FWIW I used Carista to do the same as TechStream will (TechStream kept crashing when I tried to use it. Didn't feel like screwing with TS when Carista does the same jobs I was looking to do, and with the same diagnostics, but with my phone and tiny dongle that'll live in the truck rather than a cable and laptop needed for TS). Carista also allows you to quiet down the chime, but its still louder than I care to hear so the white connector pull works best for me.
    koditten and B737 like this.
  17. Mar 4, 2019 at 1:18 PM
    B737
    Jersey Shore
    no you are, he's not reading enough :)
    Black Wolf likes this.
  18. Mar 4, 2019 at 1:33 PM
    koditten
    koditten New Member
    I got it now.:thumbsup:
  19. Mar 5, 2019 at 11:30 AM
    stevep1794
    stevep1794 New Member
    2019 Tundra Limited 2WD - Cement
    So.....about that seat belt chime???
  20. Mar 5, 2019 at 12:03 PM
    CMB
    CMB New Member
    Cecil County MD.
    I can only speak about my 2010. After choosing which "Customizable Features" I wanted done from my Owner's Manual. I made an appointment with my dealership's service department and their Tech Stream Guy. 90 minutes later, I was rolling out with my list completed. Even back then, there was post after post on all the Forums, telling how dealers weren't budging on The "Federal Mandate" of "[A] Seatbelt Warning Must Remain." My dealership's Service Manager, being one who had a grasp of the English Language, realized that the text stated "A" seatbelt warning. We have a flashing light AND a chime, the Flashing Light remained and the chime went away....A Seatbelt Warning remained. As of yet, myself and the Service Manager, have both managed to stay out of Federal Prison!
  21. Mar 5, 2019 at 3:04 PM
    Cement
    Cement [OP] ...
    Carista takes care of it (iOS / Android app + wireless OBD adapter ($20, tops)). Or Tech Stream (plus an OBD cable).
  22. Jul 3, 2019 at 7:51 AM
    Justin Case
    Justin Case New Member
    TX
    Any reason not to unplug the plunger at the door frame. Seems to do the same thing as steering column approach.
    Can use door button to lock doors with truck running but have to use an actual key in door handle to unlock.
  23. Jul 26, 2019 at 7:36 AM
    speakeasyltd
    speakeasyltd New Member
    2018 Tundra
    Door chime fix...I took out the screw that holds the rubber button in the door frame and replaced it with a plastic drywall insert. This disables the wire ( ground) and still keeps the rubber button attached to the frame. You do lose the lights on when the door opens with this fix...just this door tho.
    Seat belt chime...I purchased two seat belt extenders) chime.eliminators ($10) and voila. ..no more chime! Good luck...
  24. Jul 26, 2019 at 7:40 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Turn the truck around and open the passenger door.
  25. Aug 1, 2019 at 11:25 AM
    Bif
    Bif New Member
    Bif
    2014-1794 Edition
    Stock
    I unhooked this connector on my 14 ,model and it disabled my steering wheel motor. Gonna plastic the door jamb screw, disable the ground.
  26. Aug 1, 2019 at 11:27 AM
    Cement
    Cement [OP] ...
    What is a steering wheel motor and what does it do? I've noticed no change in mine, but its a 19...
  27. Aug 1, 2019 at 1:15 PM
    Bif
    Bif New Member
    Bif
    2014-1794 Edition
    Stock
    On my truck it is just for tilt and retract. If you unground the jamb switch works same way.
  28. Aug 1, 2019 at 7:14 PM
    Bif
    Bif New Member
    Bif
    2014-1794 Edition
    Stock
    Just an update I took the metal screw out of each door jamb switch and put plastic push pins in place of the OEM metal screws. The switch is made to ground by the metal inside the screw placement. So, no more grounded door jamb switch and no more chimes. It was the only and easiest way to keep the steering wheel tilt motor working. Now if I could only get the seat belt chime to shut off?!
  29. Aug 2, 2019 at 7:42 AM
    Cement
    Cement [OP] ...
    @Bif search these forums on "Carista". Should do the trick.
  30. Aug 7, 2019 at 10:36 AM
    Bif
    Bif New Member
    Bif
    2014-1794 Edition
    Stock
    Ok thanks finding some stuff appreciate it,
