How much would the 5100 settle
Discussion in 'Suspension' started by tundras00, Jun 12, 2018.
  1. Jun 12, 2018 at 2:45 PM
    tundras00
    tundras00 [OP] New Member
    Just did the 5100 front in the middle setting and also the rears in 5100. The front seats at 41.5" and rear at 39.5". I know the front will settle but will it settle 2"?
  2. Jun 12, 2018 at 2:47 PM
    Presuming you have a 3rd gen, the front, by factory sits at 22". The rear is usually 24-24.5". How are you measuring?
  3. Jun 12, 2018 at 2:52 PM
    tundras00
    I'm measuring from fender down. Currently measuring from there the front sits 2" higher. Is that the wrong way to measure them?
  4. Jun 12, 2018 at 3:05 PM
    Measure from center hub up to fender.
  5. Jun 12, 2018 at 3:06 PM
    LML 3500HD
    Same factory springs?
    If so, nope.
  6. Jun 12, 2018 at 3:08 PM
    Also, are you using factory coils?
  7. Jun 12, 2018 at 3:18 PM
    tundras00
    Factory springs. There is also some rubbing.
  8. Jun 12, 2018 at 3:26 PM
    How much lift are you trying to get? The Eibach coils would probably serve you better all around.
    Stroke250 likes this.
  9. Jun 12, 2018 at 3:29 PM
    tundras00
    I'm just trying to level the truck out. From reading here, the middle seems to do the trick but this is more than a level in height. Is the model # ending in 173 the right shock for the fronts in a 1794 Tundra?
  10. Jun 12, 2018 at 3:34 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    5100's at the middle setting should only left the front ~1.57". When I had mine installed they had settled by the time that I had driven home. If your lift is more than 2" on the middle setting, check to see if the collars that hold the springs were installed upside down or that they were not installed on the top setting. They should look like this:
    Backslider likes this.
  11. Jun 12, 2018 at 3:35 PM
    Level, as in lift it but keep it level or factory height?
  12. Jun 12, 2018 at 3:40 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I was going to recommend the same, I think the OP has their perches backwards..
    sr5shark[QUOTED] likes this.
  13. Jun 12, 2018 at 3:41 PM
    tundras00
    Just to level it
  14. Jun 12, 2018 at 3:42 PM
    Have you gone back to re-measure it from center hub to fender?
  15. Jun 12, 2018 at 4:47 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    check that spring perch, maybe take a pic similar to the pic above in the thread, something doesnt sound right
  16. Jun 12, 2018 at 6:52 PM
    tundras00
    It was done by
    I did. 24" at rear and 26.25" at front now at middle setting. I didn't do it myself and had my cousin do it which has his own shop. It's not his first rodeo, so the next thing would be to contact Bilstein tomorrow. Going from high to middle lowered it about 2 inches, but it is still too high. It also needs an alignment badly as it looks like its toeing in.
  17. Jun 12, 2018 at 6:55 PM
    Backslider
    Tooele, UT
    You shouldn't be getting 2" per level.. I would bet mucho pesos that the perches are on backwards. I've seen it happen to people online multiple times..
    Curious to know what you find out or how Bilstein responds! Good luck!
  18. Jun 12, 2018 at 7:00 PM
    tundras00
    Im afraid you and others are right. There's no other explanation.
  19. Jun 13, 2018 at 7:22 PM
    Jason808
    Jason808 "Thrust you can Trust"
    2012 Platinum crewmax
    Something is installed wrong for sure. I just did some 5100s 2 weeks ago on the middle setting and it raised it a little less then 1.5 inches.
  20. Jun 13, 2018 at 8:06 PM
    tundras00
    Yep, they were backwards and now everything is well. Thanks to all!:bananadance:
  21. Jun 13, 2018 at 9:47 PM
    15whtrd
    15whtrd Mr. Blonde
