How much torque do I need in impact wrench?
Discussion in 'Off-Topic Discussion' started by Doxiedad, Mar 5, 2023.
  1. Mar 5, 2023 at 4:46 AM
    Doxiedad
    Doxiedad [OP] Distinguished Member
    James
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    So I’m taking over oil changes/ tire rotations for my Tundra and wife’s Rav4.
    Looking to get a cordless impact wrench to take tires off. I’ve seen advertised specs for “breakaway” torque from 200-1200 ft/lbs depending on how much $$$ you want to shell out.
    Looks like both vehicles should be torqued to under 100 ft/lbs so realistically how much oomph should I need to get them off. I’ll be using torque wrench at house when I put them back on.
    I have a couple Dewalt tools now, so I’m leaning that way since I can buy a tool only, but if there is another brand that’s compelling I’ll consider it.
    thanks
  2. Mar 5, 2023 at 5:05 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’ve got a dewalt cordless impact that takes the lug nuts off easily. I also have a corded impact (kobalt I think), haven’t touched it since I got the cordless.
    Doxiedad[OP] likes this.
  3. Mar 5, 2023 at 5:07 AM
    centex
    centex New Member
    Toyotoholic and Silver17 like this.
  4. Mar 5, 2023 at 5:08 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Eibach pro 2.0s, toytec progressive mini AAL, ARE CX cap, Airlift bags, Harrop Supercharger, 650cc injectors, 77.5mm pulley, TRD Dual exhaust, J&L catchcan, Powertrax LSD, RRW RR7-H, 305/70r17 Toyo AT3s
    In the past I always used a cheap ryobi 1/2” impact rated at 300 ft/lbs and it always worked. Recently upgraded to a mid torque Milwaukee that’s good for 650 ft/lbs and it’s definitely overkill for the lug nuts anyway.
  5. Mar 5, 2023 at 5:36 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I have the high torque dewalt impact and its fantastic. I'm sure the mid range one would work as well, I don't think there's much of a price difference so I opted for the large one just in case I would need a little more torque down the road for something.
  6. Mar 5, 2023 at 6:42 AM
    Doxiedad
    James
  7. Mar 5, 2023 at 6:55 AM
    Doxiedad
    James
  8. Mar 5, 2023 at 7:02 AM
    Silver17
    Eastern PA
    That ryobi one is newer and more powerful than mine. I guess it depends if you already have invested money into other tools and batteries for one of the brands. I’m now a Milwaukee snob, and that’s what I’m switching everything over to. If spending $250 id sooner buy the Milwaukee mid torque impact like I bought.
    dittothat likes this.
  9. Mar 5, 2023 at 7:27 AM
    Doxiedad
    James
    I’m looking for $250 or under. I have a couple dewalt 20V tools so I could go tool only on one of them. But anything else I need tool and battery for $250
  10. Mar 5, 2023 at 7:30 AM
    vtl
    vtl New Member
    Boston 'burbs
    19 Red SR5
    Corded 450 ft/lbs is enough to deal with decades old 30 mm crankshaft nut in my non-Toyota vehicle. The rest of bolts/nuts are much smaller.
  11. Mar 5, 2023 at 7:37 AM
    Silver17
    Eastern PA
    I’d go that route in that case, if you like your dewalt stuff.
    EDDO likes this.
  12. Mar 5, 2023 at 7:41 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Plenty of torque to tighten down those oil drain bolts lol
    don’t do that I’m joking lol
  13. Mar 5, 2023 at 7:42 AM
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    landphil likes this.
  14. Mar 5, 2023 at 7:55 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Once you have broken everything free the first time and it is in your hands, just dab the lug studs and threads with a little anti seize and you will be fine even without the impact wrench. Buying a good torque wrench would be higher on the priority list to ensure proper tightening, and practically eliminate the need of a HD "breaker impact". I have a Milwaukee and I barely use use it's power to release the lugs.... BUT it is nice never having to struggle with them again. I was replacing the rear bumper on my 06' Taco and boy did the impact wrench earn it's salt when removing those rusted monster bolts. All you have to do is put some ear protection on and pull the trigger!!! Still took a while for them to release, but every one of them did eventually break free. Regardless of intended use, it's a great tool.
  15. Mar 5, 2023 at 8:49 AM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    The little guy for lugs, big one for the really stubborn stuff.
  16. Mar 5, 2023 at 8:52 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    How much torque can your arms do without wimpering?
  17. Mar 5, 2023 at 8:59 AM
    Doxiedad
    James
    Yeah I think I have 2 AH batteries for them. Its a drill/impact driver i've had for years. So I guess I need to get something with 4AH minimum. Not overly attached to Dewalt, and if i have to get larger batteries anyway I might as well look else where. I've kinda got it narrowed down to Ryobi P262K1 that comes with 4AH battery for $169 or the Ridgid R86012K with a 4AH battery and a brushless 3/8 Ratchet / or an additional 6AH battery for $249.
    They look almost identical spec wise, and If I remember right they are made by same company.
  18. Mar 5, 2023 at 9:28 AM
    Doxiedad
    James
    Yeah I have a torque wrench I'll use to set them once i run them down lightly. But I'm 47 years old now and if I don't have to break them loose and run them off by hand everytime I'm going to go that route LOL
    Toyotoholic[QUOTED] likes this.
  19. Mar 5, 2023 at 9:43 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    a compact "mid" torque (350-450 lbs/ft) and a good 1/2" (+600 lbs/ft) will likely be more than enough for anything you can do to your truck, unless you're doing axle nuts, then you need north of 900 lbs/ft.
    Team yellow has impact wrenches in those ranges, I'm pretty happy with mine.
  20. Mar 5, 2023 at 9:49 AM
    centex
    centex New Member
    More than enough but I’ve paid my dues to use power tools.
    Mr.bee[QUOTED] likes this.
  21. Mar 5, 2023 at 9:49 AM
    Doxiedad
    James
    Thanks for all the input everyone. I ordered the Ridgid I linked with the extra 6AH battery
    Toyotoholic likes this.
