How high did you get your bed liner sprayed?
Discussion in 'General Tundra Discussion' started by KW88, Mar 12, 2019.
  1. Mar 12, 2019 at 11:49 AM
    KW88
    KW88 [OP] New Member
    Keegan
    Houston TX
    2019 Super White Tundra SR5
    About to get bed liner sprayed tomorrow. How high did y'all go? Just the interior of the bed or did you go outside of the bed to where the plastic runners are?
  2. Mar 12, 2019 at 11:50 AM
    15whtrd
    15whtrd Mr. Blonde
    I left the plastic runners on in just had them go all the way under the lip. Although if done right it wouldn’t be a bad idea to remove the plastic top and have them spray the top of the bed rail. Then reinstall the plastic caps. But that’s probably overkill.
    KW88[OP] likes this.
  3. Mar 12, 2019 at 12:04 PM
    KW88
    Keegan
    Houston TX
    I wouldn't put the caps back on if I went that high. I just saw this picture and it made me start to wonder. And that sucks they rushed it. Overall are you happy with it?
    Black Wolf and Rex Kramer like this.
  4. Mar 12, 2019 at 12:08 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  5. Mar 12, 2019 at 12:09 PM
    15whtrd
    15whtrd Mr. Blonde
    I didn’t have my accessory rails on when I got it sprayed. But I would’ve made them take it off before they sprayed. I do think the caps would go back on as they are only held on buy some arrow shaped snaps. Nothing a little clearancing wouldn’t take care of. I actually took mine off and silicone them back down because I didn’t like how they shifted.
  6. Mar 12, 2019 at 12:10 PM
    15whtrd
    15whtrd Mr. Blonde
    You don’t have to put the caps back on but there are holes that are used to snap the caps on that would look funny without them.
    OR18TRD likes this.
  7. Mar 12, 2019 at 12:12 PM
    KW88
    Keegan
    Houston TX
    Good point. I didn't like the exposed holes that I saw on some of them.
    OR18TRD and 15whtrd[QUOTED] like this.
  8. Mar 12, 2019 at 12:12 PM
    15whtrd
    15whtrd Mr. Blonde
    My guys were pretty great. They did get a little overspray on my cab but it came right off because I had a fresh coat of wax on. They even removed my bed bolts and tiedown points. They did forget to tighten the bed bolts enough but I took care of that myself.
    If I lay down and look under the rail I can see a few holidays in the spray, but it’s no big deal as I’m sure it would be hard to get those spots and they will never see any abuse up under the rails.
    OR18TRD and KW88[OP] like this.
  9. Mar 13, 2019 at 4:19 AM
    rsgt
    rsgt New Member
    2019 crew cab TRD sport 4x4
    all stock
    I have Toyota factory spray liner. Very happy nice clean edge every where. Looks like they sprayed before my rails because it ends just under the rails> Nice clean edge all around. Wouldn't be possible if rails were there! Plus I they embossed the name.
  10. Mar 13, 2019 at 4:30 AM
    Sunnier
    Sunny
    San Diego, CA
    If you care about your painted tie-down hoops inside the tailgate, take them out before you go; otherwise Line-X will use a compressor drill and F' them up (wish I'd known).
    Also, let them know about the plastic covers on the oval cut outs at the front of the bed-- whether to Line-X or not. Same with the bed bolts. Anything you don't specify, expect the installer to handle whichever way is most expedient.
    KW88[OP] and 15whtrd like this.
  11. Mar 13, 2019 at 12:11 PM
    dlos
    dlos Truckin'
    2019 Cement Off-Road
    Mods Mods Mods....
    Mine was factory or port sprayed, maybe even locally by dealer. All in all whoever did it applied it nice and even and it looks great. However, while installing my tonneau cover I noticed that the rails went in before the spray and there was no spray under the rails, disappointing at best. Since I had to lower the rails to install the cover, I just went to Home Depot and bought some "bed liner spray" in a rattle can, did the job it needed to and overall everything looks fine.
    15whtrd likes this.
  12. Mar 13, 2019 at 4:15 PM
    KW88
    Keegan
    Houston TX
    Thanks for the help guys
  13. Mar 14, 2019 at 3:34 AM
    rsgt
    rsgt New Member
    all stock
    I read some where in the description that the liner is applied in the factory while the truck is being made. Also mentions that you get Toyotas quality, and even application, if you get the liner.
    Mnorris1206 likes this.
  14. Mar 14, 2019 at 4:17 AM
    Mnorris1206
    08 tundra
    Well Toyota needs to do the bottom of the bed as well then . That's where the bed rust issue starts .
  15. Mar 14, 2019 at 4:54 AM
    15whtrd
    15whtrd Mr. Blonde
    Never heard of that. It’s usually done at the port, or once at the dealer it will be sent out to a private shop.
    OR18TRD likes this.
  16. Mar 14, 2019 at 5:17 AM
    rsgt
    rsgt New Member
    all stock
    I asked the dealer said no ! Look at the 2019 catalog . No worries with me under bed rust i got Krowned its coated with the product.
  17. Mar 14, 2019 at 5:19 AM
    rsgt
    rsgt New Member
    all stock
    Big plus TUNDRA in bossed on the front of the bed.
  18. Mar 14, 2019 at 5:28 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Mine is LineX up to the underside of the top lip. When you get yours done, make sure that they take the panel on the inside of the tailgate off and do that separately. If they don't it will be a bear to get off if you ever need to and it will mess up the finish of the spray-on liner when you do get it off.
    NewImprovedRon, OR18TRD and 15whtrd like this.
  19. Mar 14, 2019 at 5:33 AM
    15whtrd
    15whtrd Mr. Blonde
    Pay for it through the dealer it can come with Toyota bossed in the front. Been that way for a while. But I have never ever heard of it being done while it’s being assembled. Like I said it’s either done at the port or private shop. Of course you can order it through the catalog but that doesn’t mean it’s done at the factory. They farm it out. But it really doesn’t matter. Your dealer is blowing smoke up your ass.
  20. Mar 14, 2019 at 5:46 AM
    KW88
    Keegan
    Houston TX
    I got the bed liner through the dealership here in Houston, and they outsourced it to private shop at a discount. Paid $330 flat.
  21. Mar 14, 2019 at 5:48 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I sprayed mine the highest possible :rasta:
    Rex Kramer likes this.
  22. Mar 14, 2019 at 12:03 PM
    Rex Kramer
    Georgia
    I believe my Line-X tech was high when he sprayed mine, sloppy enough to cause a $250 discount.
  23. Mar 14, 2019 at 12:13 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Ouch! That’s too bad. At least you got a discount.
    OR18TRD and Rex Kramer[QUOTED] like this.
  24. Mar 14, 2019 at 1:06 PM
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    Mountun Goat, Rex Kramer and 15whtrd like this.
  25. Mar 14, 2019 at 1:34 PM
    TheBeast The Beach
    yep. the line-x shop that did mine was also doing the new trucks for the local Toyota dealership. With a big markup from the dealership off course :) for the same work as mine.
  26. Mar 14, 2019 at 1:53 PM
    KW88
    Keegan
    Houston TX
    So this is the first bed liner I've had. Are you able to get your truck waxed like normal at a car wash with a bed liner or no?
  27. Mar 15, 2019 at 4:00 AM
    rsgt
    rsgt New Member
    all stock
    HOW COME MY WINDOW STICKER SHOWS TOYOTA SPRAYED IN BED LINER? I have known my dealer along time so no smoking up my ass. My liner goes all the way up up and under the lip of my inside rails straight ass line no over stray. impossible without rails removed !
  28. Mar 15, 2019 at 4:09 AM
    rsgt
    rsgt New Member
    all stock
    Just looked at my window sticker price listed $579 code LB Bed liner lol
  29. Mar 15, 2019 at 5:32 AM
    15whtrd
    15whtrd Mr. Blonde
    Sprayed at the port (farmed out) by a good installer. Any installer can add the Toyota in the bed. It’s ok... don’t believe me. Believe a car salesmen, or some guy on the internet.
    tomsinamerica likes this.
  30. Mar 15, 2019 at 6:21 AM
    rsgt
    rsgt New Member
    all stock
    Im glad its ok not to believe you lol Yes Im 61 years old and ret LE not some kid who thinks who is impressed in a 5800 poster my view well you don't want to know! Your whole premise on this subject is "you never heard of the spray liner done at the factory" . Yep your authority alright !
