How do you get sling stains out?
Discussion in 'Detailing' started by LastCanadianExit, Apr 28, 2018.
  1. Apr 28, 2018 at 1:46 PM
    LastCanadianExit
    LastCanadianExit [OP] The dude abides...
    Bucks County, PA
    2018 Platinum
    ReadyLift 8" Lift Fuel Trophy Wheels Yokohama 37s
    have stains in my white paint from tire sling I put on this week. What works well to get those out? Just clay bar?
  2. Apr 28, 2018 at 2:16 PM
  3. Apr 28, 2018 at 2:20 PM
    Elbow grease? All purpose cleaner? Detail spray?
  4. Apr 28, 2018 at 3:20 PM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    Clay bar, dawn, elbow grease, even a little hand applied cutting compound is not getting the stains out. Uh oh...
    This truck is cursed!!!
    Any ideas is appreciated.
    Black Wolf and Pudge like this.
  5. Apr 28, 2018 at 3:30 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Paint it blue ribbon metallic :p
    SMILE, dandailey, Black Wolf and 4 others like this.
  6. Apr 29, 2018 at 10:25 AM
    15whtrd
    15whtrd Mr. Blonde
    That’s strange. No matter what has been flying up on to the sides of my truck including different types of tire shine as well as whatever road debris has gotten on there, I’ve been able to get off. Do you keep your truck waxed? What kind of tire shine are you using? Maybe you should switch brands once you figure out how to get your paint clean.
  7. Apr 29, 2018 at 10:32 AM
    Grumpy Uncle
    Pat
    CO
    When I had my white Mustang, I used Simple Green and Dawn.
  8. Apr 29, 2018 at 11:30 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Put a bit of lacquer thinner on a rag and wipe those spots off then rewax where you wiped.
    Thinner can be your friend if used correctly
  9. Apr 29, 2018 at 12:19 PM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    This is stuff i used on my last white Tundra. I think my mistake was not waxing it first. I stupidly dressed the tires after getting it from the dealer. Will not so that again!
    I have ordered Tarminator to try. Trying to avoid trying magic eraser and stuff at that level just yet. May need to take to a detailer and just have them try.
    Black Wolf and 15whtrd[QUOTED] like this.
  10. Apr 29, 2018 at 1:14 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m a believer in that first wax. When I brought my truck home I washed, clay bar, and sealed it. I try to hand wax every couple of months but I use spray wax after each wash to give it some type of protection. Lately I’ve been using tech 2.0 Maguires wax which is a type of sealant. I get about six months out of it with spray wax in between.
    Black Wolf and NewImprovedRon like this.
  11. Apr 29, 2018 at 2:12 PM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    Yeah I can’t argue there. I just got excited about the new tires and didn’t do that. Dumb
  12. Apr 29, 2018 at 3:01 PM
    15whtrd
    15whtrd Mr. Blonde
    Completely understandable!
  13. Apr 29, 2018 at 3:05 PM
    I thought super white was so fast..so fast to even get stains....
  14. Apr 29, 2018 at 3:54 PM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
  15. Apr 30, 2018 at 4:24 PM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
  16. Apr 30, 2018 at 5:46 PM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    I am pretty sure. It wasn’t there before and only appeared after I put stuff on the tires. I am going to a detailer if nothing else works.
    SouthBoundSteve likes this.
  17. May 1, 2018 at 7:43 AM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    Had a detailer look at it and tried a little lacquer thinner, but didn't work. He said he has never seen anything like it. Seems like it only stained the plastic surfaces. The metal surfaces seemed to have rubbed off okay.
    Going to try a couple other noninvasive tips, then if that doesn't work I will leave it alone. I think something needs to sit on the surface and penetrate to get the stains out. If nothing works, it will just look up close like a got the truck a little dirty always. Could be worse... Perhaps the sun and our thin ozone layer will help fade them out too, lol.
    15whtrd and SouthBoundSteve like this.
  18. May 1, 2018 at 7:59 AM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    Here you go. Here is the right rear bumper.
  19. May 1, 2018 at 11:35 AM
    15whtrd
    15whtrd Mr. Blonde
    I had some spots like that on my wife’s white XB. I tried different professional polishes. Everything from heavy cut to fine cut. Nothing worked. Clay bar, bug and tar remover. Then one day I tried Maguires cleaner wax. It took that shit right out. Give it a shot I don’t know what it’s got in it, but it worked. Those spots were there from day one and we’ve had the car for eight years.
  20. May 1, 2018 at 11:48 AM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    Paste or liquid?
  21. May 1, 2018 at 11:51 AM
    15whtrd
    15whtrd Mr. Blonde
    Liquid. Found it at O’Reillys. Under 10 bucks I think. I’ve used that stuff in the past on my friends white vehicle and it was pretty impressive how much whiter it got. It might have something to do with a lot of white vehicles are not clear coated so you have to treat them a little differently.
  22. May 1, 2018 at 11:56 AM
    15whtrd
    15whtrd Mr. Blonde
  23. May 1, 2018 at 12:04 PM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    Thanks, I will give it a shot. This is cleared of course, and seems to only stick in the plastic, but at this point I will try anything. The Tarminator was a bust as well..
  24. May 1, 2018 at 12:06 PM
    15whtrd
    15whtrd Mr. Blonde
    Are you sure it’s got clearcoat? I’m pretty sure that Toyota white is a single stage paint. Maybe the bumper ends are different?
  25. May 1, 2018 at 12:08 PM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    I had to get the fender resprayed and they said they have to blend the clear?
  26. May 1, 2018 at 12:12 PM
    15whtrd
    15whtrd Mr. Blonde
    I think most paint shops clear everything. Have you ever seen an old Toyota truck with Miss matched paint? I noticed a white one today that had one fender that was shiny and the rest of the truck was chalky. The shiny fender looked to be an old repair job that they must’ve clearcoated. It probably matched perfectly until the truck got old.
  27. May 1, 2018 at 12:18 PM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    I think you are right, I think it is single stage, they just mix the enamel in instead of a 2 stage process. Makes it really weird why I cant get the spots out. Cleaner Wax is next up!
    15whtrd[QUOTED] likes this.
  28. May 1, 2018 at 12:26 PM
    15whtrd
    15whtrd Mr. Blonde
    Good luck brother. I know it sounds so simple but this stuff worked for me. I hope it works for you too. I was surprised after all the chemicals I threw at it some cheap wax like this worked ha ha
    Bones2012 likes this.
  29. May 1, 2018 at 12:33 PM
    blizz86
    blizz86 New Member
  30. May 1, 2018 at 12:56 PM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    Thanks man. Stranger things have happened. Well worth a shot.
    I bought Tarminator which I think is quite similar. Didn't work.
    I wonder if this would work as it is supposed to pull iron out of paint, maybe it will pull a stain?
    https://www.amazon.com/Carpro-Iron-...525204505&sr=8-3&keywords=iron+x+iron+remover
