How do I install the rear brake line relocation kit?
Discussion in 'Ekstrom Design' started by Netmonkey, Aug 25, 2020.
  1. Aug 25, 2020 at 3:22 PM
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
  2. Aug 25, 2020 at 3:24 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    YouTube
  3. Aug 25, 2020 at 3:24 PM
    AZTundra
    Paul
    Phoenix, AZ
    Let me grab a picture of mine for you...just a min.
  4. Aug 25, 2020 at 3:28 PM
    AZTundra
    Paul
    Phoenix, AZ
    Here you go.
  5. Aug 25, 2020 at 3:47 PM
    Vizsla
    Vizsla ☠️☠️☠️
    ARB directions, but same thing.
    C0A3BBE2-542D-4B20-9DB0-7D0E3259786E.jpg 84BE58AB-6E44-4318-BC76-D661182F6FB5.jpg
    batman900 and AZTundra like this.
  6. Aug 25, 2020 at 3:48 PM
    Zero One Actual
    Awesome help guys. That’s bad ass.
    Bob likes this.
  7. Aug 25, 2020 at 4:01 PM
    Netmonkey
    Georgetown, TX
    With the brake line positioned higher on the axle, I wonder if I would still be able to rotate the sway up 90 degrees?
    AZTundra[QUOTED] likes this.
  8. Aug 25, 2020 at 4:05 PM
    AZTundra
    Paul
    Phoenix, AZ
    Not sure on that. My sway bar is mounted in the normal orientation. Even with the +3 shackles and trd dual exhaust i had no issues with leaving the sway bar in the normal position.
    Netmonkey[QUOTED][OP] likes this.
  9. Apr 12, 2022 at 6:04 PM
    Flockem
    Flockem New Member
    Remington
    2016 Crewmax 4x4
    6112/5160 +CB shims SPC UCA and Diff Drop Toytec Shackles 35x12.50 BFG ATs on factory 20s Spidertrax 1.25s BMC Headlight Revolution SM LED Breather Mod Dents in the body due to trees...
    Bump @Coachbuilder1
    bought this kit and if I want to install the extension on top of the diff it’s pulling the hard lines up so high I wouldn’t be able to get the side bolts in. Also looking over to the leaves those “holders” underneath look like they would be severely stressed.
    confused….
    I’m running the icon stage 8 so assuming it’s the RXT leaves and on option, so 2”-3” range of lift.
    Any advise?
    Coachbuilder1 likes this.
  10. Apr 12, 2022 at 6:09 PM
    Flockem
    Flockem New Member
    Remington
    2016 Crewmax 4x4
    Option 2*
  11. Apr 12, 2022 at 6:23 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Thanks for posting, The arrow shaped bracket bolts to the top of pumpkin and will need to remove the bolts on each side of pumpkin before installing this bracket. just as you mentioned the hard lines are tight and will physically bend the hard lines in order the reach the bracket. after you have pulled the hard lines up you'll need to rotate the metal tabs 180 degrees on each side of pumpkin. this will allow the har lines to mount higher than they were originally. after you've done this follow the speed sensor wire up ( just left of pumpkin ) up to the pre filter box on the underside of bed. there is a threaded stud that is holding the speed sensor wire. the Z shaped brake will allow this wire to drop down and back providing addition length. Hope this helps. Let me know if you need pics.
    Flockem[QUOTED] likes this.
  12. May 31, 2022 at 5:43 PM
    Cthulhu
    YES! Pics of both brackets properly installed would be MOST helpful. Thank you @Coachbuilder1 !! Here are some pics of the way I installed them without instructions. Basically, the side of each bracket that has "Coachbuilder" written on it is facing the front of the vehicle, i.e., when you look at the brackets from the rear, you can't see the Coachbuilder writing:
    2point5seconds likes this.
  13. Jul 9, 2022 at 6:36 AM
    2point5seconds
    2point5seconds Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    Sorry. I know old post...
    I just found out that the place who installed my Icon Stage 9 kit just left everything hanging. Brake line and ABS wires. Didn't even notice it until last weekend. Was going the route to get longer brake lines down the center to the rear differential. But this may be easier and cheaper.
    Is 2 inches of extra length enough though to consider the flexing while going off road?
